I have take a look at it and even when the tail gear are (its not) in the right angle its still tipped backwards. Even when the aft gear extends all out its barely vertical. But looking at the main-shaft its bending forwards in comparison with the cockpit / doghouse or how you call it? but its not enough and it was almost good as I remember, so why its now changed Its not really a big deal but its also fun to fix this. Jan, |
Ok, I was just having you check to make sure that it is tipped back when in the proper location. Maybe a hard landing settled things inside or if there was a slight mis-alignment from the front mount - mid mount - tail mount, vibrations may have settled one of them. Although the wood parts of a lot of these new birds are laser cut, they are not heavy duty plywood and spacers formed from them can easily collapse (seen this in my Jet Ranger) so maybe some replacements are needed made from 4 or 5 ply birch? It's almost like you need to have the landing gear just move rather than have any shock absorbing from taxi angle to full flying angle and forget about whether it functions like the real thing. At least that way, you know you are on the correct angle for take-off and taxi so there will be no tendency for the heli to "back up" while spooling up. Just thinking out loud there. I see you have the adjustabe torque tube drive so shimming the back end of the chassis a bit higher should not be too, too hard. You may want to see if a stiffener along the bottom of the chassis mounting area to the tail area would help prevent sag. Again, just thinking out loud. Of all the tail blade systems I have seen modeled, yours seems to be the most simple and rugged of the "X" blade rotors. I have now really looked at how you did it and I know where a few of those tail grips are stashed. Take care.
Don |
Thanks for your input .I have take out the mechanics last night and as you said shimming the back end of the chassis a bit higher and is done with nylon bushes 5mm high. And that a lot I can tell.. ![]() Then I also adjusted the tail gear so now its always extended. And that's also helping, The frame inside the fuse are a bit reinforced at the back, so its holding the mechanics a bit better at the same angle. ![]() Photo is not that explainable sorry. But after mounting the mechanics its looks dramatically better, ![]() But I also need to lower the aft raised tail boom because when the front mech are tilted more upwards at the back the horizontal boom must move upwards to at the back of the mech causing the aft raised tail boom to lower. Because its a real pain to adjust the hole lot if I adjusted the tail-roter head output I simple grind the hole in the side of the tail fin larger. ![]() When its fly by with 80km/u nobody will see it ![]() Well it became a bit late this morning but I'm happy with the results.It has not test flown (the neighbors and for sure my wife) would have kill me . And it was dark and freezing cold. ![]() ![]() I think that taking off will be a lot easier now because the Apache was always tending to move backwards. Not a real problem, you get used to it, however this looks much better and I had to do it. Regards, Jan, |
Thanks Guys
![]() I have done some hovering because flying was not possible due the bad wind circumstances but taxiing are fun to do now, just pulling the tail-gear from the ground and the rolling starts. And the most important issue the lift of is now great. It just take off with a tendency to go forwards instead of backwards ![]() ![]() ![]() So mission accomplished. ![]() Greetings from a rainy, windy, Grey, unpleasant Holland. Jan, |
im have been into helis for about 2 years but have never done a 4 bladed head and tail and i want to do it on this heli. as of right now my 600 has a stock motor with a castle 100 esc a castle 20 pro bec and all stock servos. my gyro will be a AR7200BX 7CH DSMX Flybarless Control System. my question is what motor. main gear, pinion gear, head, blades well just about everything i will need to do this plus rx settings like pitch curve, th curve swash mix so on an so on if anyone can help me out please. I have always wanted to do this but never had a chance to do it.
Joined Mar 2012
a 4 blade head with torque driven tail rotor inc smartmodel raised tail unit & 5deg angled output unit requires a lot more torque than stock align motor will deliver, so you will need a better power train.: 120A HV ESC 500/550kv motor 14-15T PINION (6mm shaft) 1x 6 cell 1 x 4 cell 4200mah lipo (10 cell total) stock servos are fine. u will not be performing hard 3d...i hope. Pitch, well, that really depends on what blades you are using and how much lift is generated. i went from using wide chord soft scale blades which required minimal 5+ / 3- deg pitch, then when i went to stiff thin chord semi symmetrical blades i had to increase my + pitch to 7up, and 5-down. i run a 1600rpm headspeed. thats high for a scale machine, but the performance is much better than when using a lower headspeed. Hope this helps some. bear in mind you are going to need to spend a lot of money to tune your heli, as did horseman and i, as you realize along the way that nothing is straight forward simplicity. theres a huge amount of teething problems that come into play when you are setting up but once you have her flying correctly it all seems like a dream. |
Joined Jun 2008
Hey guys,
It's been awhile! ![]() I finally have her flying without fuse yet and still working on the 4 blade tail. (trying to secure the tail gear on the shaft with a pin so I have to drill a very strait and small hole.) I test flew her this whole week. she fly's pretty good I have to say. I will have to tinker with the Governor as it is bogging on high fast pitch. I have never used one before. and the skookum has one build in. I have a 12 degree pos pitch, she does not lift very fast and you can hear the motor trying to pull its part. is this normal in scale? I am using a 13 tooth pinion, might try a 14 or 15. All electrics are cool to the touch after 11 min flights with 2 5cell 3800 lipos. but thats outside the fuse were it gets air. I have to say after a little over a year it feels really good to get her up in the air!!!! Hope all is well with Jay and Horseman. |
Hi Bud,
All is fine with me thanks, You wrote (trying to secure the tail gear on the shaft with a pin so I have to drill a very strait and small hole.) I did not drill a hole at all I just glued the gear with CA glue and its holding great. Regarding the heat build up, well if I was you (I'm not ) it check the heat directly on the motor, esc and battery's.I'm struggling with my blades at the moment and I have found that the TF blades are indeed bend as Jay already told me because he mentioned that the way I stored the blades on the Apache can cause that problem. This one of the blades and they are all four of them bend like this one. ![]() So I have used two other sets off indentical blades and used them as a fourblade set and now the shaking is gone. ![]() So I will order a set of Spinblades in the near future as Jay suggested me a wile ago. Greetings from Holland, Jan, |
| Thread Tools | |
| Discussion Smartmodel Apache AH64 + T-Rex 600 ESP | Hummerfresse | Scale Helicopters | 33 | Feb 18, 2012 12:47 PM |
| For Sale SYMA S009G AH-64 Apache 3 Channel Indoor Helicopter with Gyroscope $25.00 Shipped! | Hellihawk | Aircraft - Electric - Helis (FS/W) | 2 | Jul 06, 2011 03:13 AM |
| Discussion 1st Look: HeliArtist 500 Size AH-64 Apache Fuselage | BlackTitanium | Scale Helicopters | 18 | Jan 16, 2010 03:14 AM |
| Rant AirHogs Reflex AH-64 3ch vs. other AH-64 Apache 3ch Sandbox\Hangar | Jay-viator | Micro RTF | 56 | Feb 01, 2009 04:21 PM |
| Video AH-64 Apache 450 size | darthdrk | Electric Heli Talk | 3 | Aug 07, 2008 12:37 AM |
