Old Nov 03, 2012, 01:06 PM
Sweden, Gothenburg
Joined Aug 2005
Beautiful....
Cheers
Jack
viggen65 is offline Find More Posts by viggen65
Old Nov 05, 2012, 05:46 PM
Joined Jun 2008
Jan,
I just received a copter-x head for my apache after 2 different heads not working out for me. the apache head and the double cats. now Im on the copter-x and it seems pretty nice, but my swash is so dang stiff. Any input on yours. I mean really stiff. I wouldn't fly it until I figure out why it's so stiff.
I have to put some serious force to move the swash toward the swash follower?? Like as if something is bend inside the swash, but it will move fine in other directions??
thanks
Buddy
buddertoast is offline Find More Posts by buddertoast
Old Nov 06, 2012, 01:08 AM
Horseman's Avatar
The Netherlands
Joined Aug 2008
Hi Buddy,
In my case the grip of the suppled ballinks are really tight So I will use Align bol- links for it.
But can you point it on a photo what you mean? is giving pitch a problem?
Jan,
Horseman is offline Find More Posts by Horseman
Old Nov 06, 2012, 05:26 AM
Joined Jun 2008
It does move around freely at all! It has not been installed on my heli yet, but im sure it will bounce my head around with servo movements.
Old Nov 06, 2012, 06:33 AM
Horseman's Avatar
The Netherlands
Joined Aug 2008
Hi so you say that the round shape ring can rotate freely but get stuck when you move it up or down, correct ?
My head (the Xcopter) not my own. has some play moving up and down I guess 0.5mm a bit to much by my feeling.
But how much play do you have when moving this ring up and down.
Jan,
Old Nov 06, 2012, 08:54 AM
Joined Jun 2008
There is no play up and down. If I put the shaft through it and move the awash around it gets stuck when the shaft would come to the part of the swash were the swash stay would connect to the swash.
copter-x swash movement (0 min 25 sec)
Old Nov 06, 2012, 09:47 AM
Horseman's Avatar
The Netherlands
Joined Aug 2008
Hi I would suggest to dismantle this part and take a close look at it,
There a little scrub screw at the side what holds the bearings thats support this ring.
Dont forget to loosen this one
Jan,
Old Nov 06, 2012, 01:20 PM
USA, CA, Red Bluff
Joined Dec 2007
If it was Mine, I would find some fine lapping compound and light oil and put that on the tight part and work it around a bit. You have to carefull though and not get it to loose That would be as bad as to tight. Ed
prop bender is offline Find More Posts by prop bender
Old Nov 06, 2012, 02:09 PM
Horseman's Avatar
The Netherlands
Joined Aug 2008
That's an option and you can use the cleaning paste you use to clean your kitchen-sink
Jan,
Old Nov 06, 2012, 04:59 PM
Joined Jun 2008
I cannot dismantal this swash without breaking it. How do I separate the top from the bottom
Old Nov 07, 2012, 05:04 AM
Horseman's Avatar
The Netherlands
Joined Aug 2008
Hi Buddy,
If you are using the cleaning paste you do not need to dismantle the swash.
Insert the paste inside the tight area and move it as you did on your video.
Along moving around you should get more space and a smoother travel.
Besides that you can push the ring downwards out the swash, don't forget the scrub screw.
Jan,
Old Nov 09, 2012, 02:11 AM
Horseman's Avatar
The Netherlands
Joined Aug 2008
Hi Buddy,
Any news regarding the X-Copter head issue you have?
Jan,
Old Nov 30, 2012, 12:58 PM
Joined Jun 2008
Originally Posted by Horseman View Post
Hi Buddy,
Jan,
this is funny, I have been checking to see if you answered me, but just today noticed that the thread went to another page. LOL.
I emailed ehobby and they are sending me a new swash. Been real busy and will be till January with X-mas at work and all. I haven't tried the paste yet, but I will have to. Will give results asap.
thanks
Buddy
Old Dec 12, 2012, 08:40 AM
Horseman's Avatar
The Netherlands
Joined Aug 2008
Hi all,
I'm a bit annoying myself because I have seen that the main rotor shaft is not vertical when the Apache is resting on his landing gear.
Best is that the main shaft is tilted a bit forwards, now its a bit tilting backwards.
Just not right I know that for a wile but its annoying me more and more.
So I will take out the mechanics and fix it the coming weeks.
I will keep you guys posted.
Kind regards,
Jan,
Old Dec 12, 2012, 11:46 AM
Love my scale Whirlybirds
Keyrigger's Avatar
Mississauga, Ont., Can.
Joined Sep 2009
Before beating yourself up, does your landing gear collapse to the same angle as the landed AH-64? If not, the body will be slightly tipped aft and your mast will not be perpendicular to the ground. Just checking. Take care.
Don
Keyrigger is offline Find More Posts by Keyrigger
Discussion Smartmodel Apache AH64 + T-Rex 600 ESP Hummerfresse Scale Helicopters 33 Feb 18, 2012 12:47 PM
For Sale SYMA S009G AH-64 Apache 3 Channel Indoor Helicopter with Gyroscope $25.00 Shipped! Hellihawk Aircraft - Electric - Helis (FS/W) 2 Jul 06, 2011 03:13 AM
Discussion 1st Look: HeliArtist 500 Size AH-64 Apache Fuselage BlackTitanium Scale Helicopters 18 Jan 16, 2010 03:14 AM
Rant AirHogs Reflex AH-64 3ch vs. other AH-64 Apache 3ch Sandbox\Hangar Jay-viator Micro RTF 56 Feb 01, 2009 04:21 PM
Video AH-64 Apache 450 size darthdrk Electric Heli Talk 3 Aug 07, 2008 12:37 AM
