Old Sep 30, 2012, 05:23 PM
Horseman is offline
Find More Posts by Horseman
Horseman's Avatar
The Netherlands, FR
Joined Aug 2008
Hi Jay,
If you ask me, you have an geometry issue. because I had have the same problem.
I also has had the blades even when at zero pitch but when at 8 degree at 1 set of blades the other set was something differed aproxx 10 degree and the blades make a lot of noise and poor stopping power.
The cause in my case was not a proper geometry between the two blade sets and the sulution was to make the linkage between the blades parallel with the tail shaft.
Just by adding spacers (two M2 nuts) between the blade grips pivots see photo,
and shorten the other blade grips pivots by apros 1.5mm
Now the blades are staying nearly paralleled between the two sets and the noise are (almost) gone by max stroke with hard rudder, but now the stopping power are enough but keep the head speed high as possible.
Now its OK
Then your X tail can not make it to the real scale degree because your linkage will bind then so you have to make it the best out of two given facts
The next photo was the old setup without the spacers giving the bad results.
You can easily seen that the linkage are not parallel at all with the tail shaft.
POOR geometry.
Hope this will answer your question Jay,
Regards from Holland,
Jan,
Horseman is offline Find More Posts by Horseman
Old Oct 09, 2012, 01:01 AM
JayNZ is offline
Find More Posts by JayNZ
Joined Mar 2012
Originally Posted by Horseman View Post
Hi Jay,
Now the blades are staying nearly paralleled between the two sets and the noise are (almost) gone by max stroke with hard rudder, but now stopping power enough but keep the head speed high as possible.
Now its OK
POOR geometry.
Jan,
thanks jan i might give this a shot tomorrow. cheers!
JayNZ is offline Find More Posts by JayNZ
Old Oct 09, 2012, 01:11 AM
Horseman is offline
Horseman's Avatar
The Netherlands, FR
Joined Aug 2008
Hi Jay,
Kin is making a new tail drive with an other ratio 1 to 1.25 if I'm correct so with that gear we can (if we like) bring the main gear speed down without losing tail response.
Jan,
Old Oct 09, 2012, 07:18 AM
jdm2ner is online now
Find More Posts by jdm2ner
flying is everything
jdm2ner's Avatar
United States, FL, Hollywood
Joined Oct 2010
does anyone remember the length they used on the shafts for the long and short section of the raised tail kit
jdm2ner is online now Find More Posts by jdm2ner
Old Oct 09, 2012, 07:20 AM
Horseman is offline
Horseman's Avatar
The Netherlands, FR
Joined Aug 2008
Sorry I did not make a note of it
Jan,
Old Oct 09, 2012, 11:56 AM
kin is offline
kin
Find More Posts by kin
kin
Composite factory
Joined Sep 2007
No need ask ! i can special make the length for you , i can cut the length you like !
kin is offline Find More Posts by kin
Old Nov 01, 2012, 05:11 AM
Horseman is offline
Horseman's Avatar
The Netherlands, FR
Joined Aug 2008
Hi Jay,
Jan,
Hi Kin,
Any news about your new gears?
Jan,
Old Nov 02, 2012, 05:10 PM
Horseman is offline
Horseman's Avatar
The Netherlands, FR
Joined Aug 2008
Hi guys,
Here some more detail photos from my work I did at the fuse,
As you can see these little pencil lines and dots can do a lot on a model.
Now some more dirt on it and it starts to get really nice.
Regards,
Jan,
Old Nov 02, 2012, 05:23 PM
viggen65 is offline
Find More Posts by viggen65
Sweden, Gothenburg
Joined Aug 2005
What did you use as rivets?
/jack
viggen65 is offline Find More Posts by viggen65
Old Nov 02, 2012, 09:00 PM
JayNZ is offline
Joined Mar 2012
such fine detail jan looks awesome!
Old Nov 03, 2012, 05:42 AM
Horseman is offline
Horseman's Avatar
The Netherlands, FR
Joined Aug 2008
/jack
Hi Jack,
Just a pencil, I draw the rivets
Jan,
Old Nov 03, 2012, 06:10 AM
viggen65 is offline
Sweden, Gothenburg
Joined Aug 2005
thats interesting, how do you make them permanent..clearcoat?
cheers
Jack
Old Nov 03, 2012, 08:41 AM
Horseman is offline
Horseman's Avatar
The Netherlands, FR
Joined Aug 2008
cheers
Jack
Yep if you don't it will fade away but I also want to weather it a bit more.
But not to much what always is a difficult one with weathering.
After I done that I will use a matt clearcoat to protect the paint.
Regards,
Jan,
Old Nov 03, 2012, 09:27 AM
viggen65 is offline
Sweden, Gothenburg
Joined Aug 2005
Regards,
Jan,
Ok,never seen that inovative method before,congrats to very a nice rivetjob!
Cheers
Jack
Old Nov 03, 2012, 09:54 AM
Horseman is offline
Horseman's Avatar
The Netherlands, FR
Joined Aug 2008
Cheers
Jack
Thanks Jack,
I have done it ones before (and for the first time) on a ME 262
And that turned out very well so why not on a helicopter
Jan,
Discussion Smartmodel Apache AH64 + T-Rex 600 ESP Hummerfresse Scale Helicopters 33 Feb 18, 2012 12:47 PM
For Sale SYMA S009G AH-64 Apache 3 Channel Indoor Helicopter with Gyroscope $25.00 Shipped! Hellihawk Aircraft - Electric - Helis (FS/W) 2 Jul 06, 2011 03:13 AM
Discussion 1st Look: HeliArtist 500 Size AH-64 Apache Fuselage BlackTitanium Scale Helicopters 18 Jan 16, 2010 03:14 AM
Rant AirHogs Reflex AH-64 3ch vs. other AH-64 Apache 3ch Sandbox\Hangar Jay-viator Micro Ready-to-Fly 56 Feb 01, 2009 04:21 PM
Video AH-64 Apache 450 size darthdrk Electric Heli Talk 3 Aug 07, 2008 12:37 AM
