Old Sep 10, 2012, 12:21 PM
kin is offline
kin
Find More Posts by kin
kin
Composite factory
Joined Sep 2007
Just one tips ! don't let the battery weight separate with the machanic frame .it mean you don't put all the battert weight in thre front , and the fuselage to load all the weight for the battery , it is a virbation, and so easy to damage your fuselage , it not damage but hard landing and bad landing , it is the battery hot will let the fuselage bend and let the epoxy soft again in heat souce ! . the second is the weight too far with the mechanic frame .the virbation from a side frame . but the side frame is light weight ,the fuselage is heavy weight , the vibration nothing to (stable it ) , I mean don't let the mechanic light anf fuselage heavy , you should let the mechanic heavy and fuselage loading light ! the problem will less ! it is our experience . you can build a long battery tray to let the battey sit there .don't make the battery no relation with machanic !
kin is offline Find More Posts by kin
Old Sep 10, 2012, 03:32 PM
Horseman is offline
Find More Posts by Horseman
Horseman's Avatar
The Netherlands, FR
Joined Aug 2008
Hi Kin, and the other rotorheads
Thank you for your recommendation about to spread the load from the battery's of the fuselage.
I shall see if I can connect the weight from the battery's to the mechanic instead laying at the fuselage floor as it is doing now, its reinforced but just a bit.
Fuselage work,
Then I did a bit off an experiment and I want to let you guys see this and I want to know your opinion
This one side off the Apache,
This the other side,
It looks on the photo's bigger than in real (looks in real nicer)
The dots are pensil circles / dots and about 0,5 to 1 mm big most of them 0.5mm the body looks more filled up and less flat if you get my feeling.
Jan,
Horseman is offline Find More Posts by Horseman
Old Sep 10, 2012, 03:38 PM
didier n is offline
Find More Posts by didier n
Leopoldsburg, Belgium
Joined Jul 2006
I think it looks rather nice! :-)
Didier
didier n is offline Find More Posts by didier n
Old Sep 10, 2012, 03:46 PM
CW4 is offline
CW4
Find More Posts by CW4
CW4
Joined Aug 2012
Nice! Are the panel lines pencil as well?
CW4 is offline Find More Posts by CW4
Old Sep 10, 2012, 03:48 PM
Keyrigger is offline
Find More Posts by Keyrigger
Love my scale Whirlybirds
Keyrigger's Avatar
Mississauga, Ont., Can.
Joined Sep 2009
Looks good in my books.
Don
Keyrigger is offline Find More Posts by Keyrigger
Old Sep 10, 2012, 05:22 PM
Horseman is offline
Horseman's Avatar
The Netherlands, FR
Joined Aug 2008
Thanks Guys it was a little gamble, I know it works on a plane but how it looks on a shopper. so I'm pleased that you Guys like it, so now I will go further with it.
The panel lines are done with the same pencil
But after I have put on the dots etc I need to protect the pencil lines/dots with clear coat because now you can wipe it away easily that's not good...
Jan,
Old Sep 11, 2012, 06:10 PM
buddertoast is offline
Find More Posts by buddertoast
United States, FL
Joined Jun 2008
hey Jan,
did you use apoxy to connect the 2 parts front and tail of the fuse together? I see some use a glue, some use screws, and I seen a few that were smooth as if the did bondo work on it?
buddertoast is offline Find More Posts by buddertoast
Old Sep 12, 2012, 07:34 AM
kin is offline
kin
kin
Composite factory
Joined Sep 2007
Don'tttttttttttttttttttttttttttttttttttttttttttttt t make the coating now !!!!!!!!!!!!!!!! still too new look , weatheringgggggggggggggggggg , let it old old old old ! just use a lot thinner add 10 % black paint use a small spary gun ! very carefully to paint the front ,,leading edge in the wing , and all the front area , just very very light .and especial the smoke outside the exhaust to the tail . let the tail boom dirty. ! millitary models is looking old better !
Old Sep 14, 2012, 12:43 AM
JayNZ is offline
Find More Posts by JayNZ
Joined Mar 2012
Hey guys, sorry to jack your thread jan, but if any of you guys are into cockpit detailing, ive got some cool pics up on my build log of the new cockpit panels from robcon-rc.com
heres the link.! http://www.rcgroups.com/forums/showt...1634181&page=7
jan i will pm you for advice on the xtail set up.
JayNZ is offline Find More Posts by JayNZ
Old Sep 14, 2012, 02:02 AM
Horseman is offline
Horseman's Avatar
The Netherlands, FR
Joined Aug 2008
Jay no worry about the jacking my tread as long its on subject I have no problems
I even post a photo of your cockpit, I love it.
Jan,
Old Sep 14, 2012, 06:21 AM
JayNZ is offline
Joined Mar 2012
Thanks Jan!
Here is the full inner cockpit assembly.
Illuminated pilot console
Illuminated gunner console
Old Sep 14, 2012, 07:37 AM
Horseman is offline
Horseman's Avatar
The Netherlands, FR
Joined Aug 2008
Thanks Jan!
Sick
Old Sep 16, 2012, 01:41 AM
Choppercopter is offline
Find More Posts by Choppercopter
Joined Mar 2010
Hi Guys,
I have just received my Smartmodel TT tail system for my RC Aerodyne Jayhawk.
Both short and long torque tubes are come bended so I am unable to use any of them. Wonder if any of you guys have been experience this? I have sent an email to both Bandy and Kin but have not heard any reply.
I reluctantly have to cut my Align 600 torque tube to replace Smartmodel's torque tubes. However I cannot insert the Smartmodel's gear tip into the Align torque tube as the tip is too small in diameter. (Smartmodel's gear tip is 6mm diameter, Align torque tube internal diameter is 7mm, so it is too lose).
Also how can I drill a hole in the tube?
If any of you guys know how to solve this problem. Please help!!!
Thanks very much
Choppercopter is offline Find More Posts by Choppercopter
Old Sep 16, 2012, 08:19 AM
mhills51 is offline
Find More Posts by mhills51
mhills51's Avatar
kansas city
Joined Feb 2007
May try to clean up your other align end. Heat should help un-glue the epoxy.
mhills51 is offline Find More Posts by mhills51
Last edited by mhills51; Sep 17, 2012 at 08:40 AM. Reason: can't believe I wrote head instead of heat lol!
Old Sep 17, 2012, 02:06 AM
Joined Mar 2010
Does any of you guy know how to detach or remove the torque tube end tip from the torque tube? I need to use those tips to make new torque tube.
If there is any of you guys know how, please show me. I need to make the 3 lengths torque tube for this conversion from the Align torque tubes. I don't think Kin will get the bended tubes replaced for me so I guess I have make them myself.
Any guys know please help.
Discussion Smartmodel Apache AH64 + T-Rex 600 ESP Hummerfresse Scale Helicopters 33 Feb 18, 2012 12:47 PM
For Sale SYMA S009G AH-64 Apache 3 Channel Indoor Helicopter with Gyroscope $25.00 Shipped! Hellihawk Aircraft - Electric - Helis (FS/W) 2 Jul 06, 2011 03:13 AM
Discussion 1st Look: HeliArtist 500 Size AH-64 Apache Fuselage BlackTitanium Scale Helicopters 18 Jan 16, 2010 03:14 AM
Rant AirHogs Reflex AH-64 3ch vs. other AH-64 Apache 3ch Sandbox\Hangar Jay-viator Micro Ready-to-Fly 56 Feb 01, 2009 04:21 PM
Video AH-64 Apache 450 size darthdrk Electric Heli Talk 3 Aug 07, 2008 12:37 AM
