Old Sep 05, 2012, 10:54 AM
kin is offline
kin
Find More Posts by kin
kin
Composite factory
Joined Sep 2007
Originally Posted by CW4 View Post
My blades finally arrived today. I ordered a set of 4 matte black 600mm for my Apache. My first thought was, "man, these things are narrow!" I was expecting them to be a bit wider chord-wise. I'm flying at 5,400 ft MSL, so I need all the lift I can get. Not sure how these will perform at altitude.
And then I began to exam them closely, and discovered one of the blades had a bubble on both sides.
Not sure what to do about that, but it's pretty disappointing.
if you want to try my SM 6504 blades i can offer you a compare with that narrow blades . my blades also narrow but hot that exteme! and i am semi=symmetical air foil . if you say yes , i 50% less offer you .pm me
kin is offline Find More Posts by kin
Old Sep 05, 2012, 11:03 AM
kin is offline
kin
kin
Composite factory
Joined Sep 2007
The other SM carbon blades come out next month , they are 550mm and 430mm, Apache/Seahawk swept tip version is 600mm . eurocopter (round tip version) is 430mm . The 780mm are ready out market now !
Old Sep 05, 2012, 01:22 PM
CW4 is offline
CW4
Find More Posts by CW4
CW4
Joined Aug 2012
kin -- I sent you a pm.
patrick
CW4 is offline Find More Posts by CW4
Old Sep 05, 2012, 06:24 PM
JayNZ is offline
Find More Posts by JayNZ
Joined Mar 2012
Hi Jay,
What batteries are you using? I assume you are using 2 x 6S 3000mah? What brand batteries? Thanks.
Patrick
Nah in the black hawk, im kinda overmaxing it, with 2 x 6Cell 6000mah batteries, but have just got a new set of hyperion 6 Cell 4200mah for her. lowers my headspeed a little which is good.
JayNZ is offline Find More Posts by JayNZ
Old Sep 05, 2012, 06:28 PM
JayNZ is offline
Joined Mar 2012
Hey Jan, could you please tell me what you used to make the two long raised panels that are on the top of your rear bulkhead seen in the second picture on here? i like it lot.
Then some photo's at the field,
Here the mechanics and the fuselage,
Yes it fits
And just some nice photo's
Later this day I did the exhaust area,
Panel lines, weathering etc still to come,
Then a photo of my fleet, a Hughes tow defender with a trex 500 inside,
Then a stock Align 600 ESP, and the apache mechanics 600 size and fuselage.
It was finely a nice day to take the toys to the field
Kind regards,
Jan,[/QUOTE]
Old Sep 05, 2012, 11:30 PM
buddertoast is offline
Find More Posts by buddertoast
United States, FL
Joined Jun 2008
Jan, how did you achieve a center gravity with your batteries set up in the front so far when you had your heli out of the fuse. my heli is so nose heavy it's impossible to get a CG
buddertoast is offline Find More Posts by buddertoast
Old Sep 06, 2012, 12:08 PM
United States, FL
Joined Jun 2008
Originally Posted by Horseman View Post
Hello all,
After the photo's and explaining from Partick I build my X tail for the Apache.
I have used the front gear unit
and uses a rubber hammer to dismount the crown gear,
Push out the lock pin,
The result,
I have used a 450 main and just glued the crown gear with thin CA.
Jan, did you reuse the lock pin and drill a hole in the 450 shaft, and if so, what size bit did you use?
thanks
Buddy
Old Sep 06, 2012, 12:29 PM
Horseman is offline
Find More Posts by Horseman
Horseman's Avatar
The Netherlands, FR
Joined Aug 2008
thanks
Buddy
Hi Buddy,
No I was not able to get a 2mm drill in this metal so I glued it with thin CA and that is holding.
At least the front crown gear from Align melted and no problem at all with the new tail assembly and the SM gears.
Of course it has not many hours (25 minutes I guess) but it feels very tight.
Jan,
Horseman is offline Find More Posts by Horseman
Old Sep 07, 2012, 07:09 AM
United States, FL
Joined Jun 2008
IS THERE ANY SECRET TO TRACKING 4 BLADES?? I had to walk away for a bit.
thanks
Buddy
Old Sep 07, 2012, 05:25 PM
didier n is offline
Find More Posts by didier n
Leopoldsburg, Belgium
Joined Jul 2006
thanks
Buddy
i just track them in pairs...remove 2 blades, track...put them back on and remove the other 2, marking where they are suppose to be, track again, now put the first pair on to make it complete, if you still have tracking, change the pitch rods in pairs..worked for me several times
succes!
Didier
didier n is offline Find More Posts by didier n
Old Sep 07, 2012, 08:03 PM
United States, FL
Joined Jun 2008
succes!
Didier
good idea.... thanks a bunch.
Old Sep 08, 2012, 02:04 PM
Horseman is offline
Horseman's Avatar
The Netherlands, FR
Joined Aug 2008
Hello all,
I have flown the Apache today it was a bit dark but I was eager to know if the tail was holding now and what the temp of the gears where.
My buddy lend me his laser temperature gun so that easy to do.
I noticed that the head-speed of 1250 rpm was to low to have real power on the tail with this X rotor head.
So Its now 1350 rpm and the tail is responding crisp and just feeling good.
The temp on the gears is between 30 and 35 degree with 18 degree outside temperature no problem.
The Motor are 45 degree, battery's 43 degree (5% left) forgot the timer.
ESC 42 degree so sound all right for me.
Regards,
Jan,
Old Sep 08, 2012, 03:42 PM
JayNZ is offline
Joined Mar 2012
was it a bubble, or a tiny resin inset that has been put there for blade balancing? mine has them too. still fly fine.
Old Sep 08, 2012, 03:44 PM
JayNZ is offline
Joined Mar 2012
Hello all,
Regards,
Jan,
Im just waiting on my new bladegrips to arrive because the ones i have and the ones that were sent are two different sizes. thanks align! looking forward to making this. my apache is re-assmbled and ready to fly. just working on the new gun system now.
tight lines!
Old Sep 08, 2012, 09:42 PM
CW4 is offline
CW4
CW4
Joined Aug 2012
Definitely a bubble. It's extremely obvious and the other 3 blades are smooth as glass. They are sending me a new pair.
Patrick
Discussion Smartmodel Apache AH64 + T-Rex 600 ESP Hummerfresse Scale Helicopters 33 Feb 18, 2012 12:47 PM
For Sale SYMA S009G AH-64 Apache 3 Channel Indoor Helicopter with Gyroscope $25.00 Shipped! Hellihawk Aircraft - Electric - Helis (FS/W) 2 Jul 06, 2011 03:13 AM
Discussion 1st Look: HeliArtist 500 Size AH-64 Apache Fuselage BlackTitanium Scale Helicopters 18 Jan 16, 2010 03:14 AM
Rant AirHogs Reflex AH-64 3ch vs. other AH-64 Apache 3ch Sandbox\Hangar Jay-viator Micro Ready-to-Fly 56 Feb 01, 2009 04:21 PM
Video AH-64 Apache 450 size darthdrk Electric Heli Talk 3 Aug 07, 2008 12:37 AM
