Old Aug 19, 2012, 04:22 PM
buddertoast is online now
Find More Posts by buddertoast
United States, FL
Joined Jun 2008
I'm in the understanding that the higher the volts the cooler all should run???? If I go to 12 cells a 560kv motor should run cool and smooth with a 120amp esc, no? Im going to use the stock align main gear. I'm looking for 10 min flights so i can hover around the block from the roof of my house. Lol.
Jan, how long did it take to get ur apache fuse from smart models? I'm in the states, so I'm sure it is different then your time, just curious.
Horseman, is your apache from smart models as well?
buddertoast is online now Find More Posts by buddertoast
Old Aug 19, 2012, 04:59 PM
Horseman is offline
Find More Posts by Horseman
Horseman's Avatar
The Netherlands, FR
Joined Aug 2008
Hi Buddy,
How higher the voltage how lower the current so the heat will be cooler, that the long yes.
Shipping the apache it took less then two weeks
And indeed its a Apache from SmartModels.
Regards,
Jan,
Horseman is offline Find More Posts by Horseman
Old Aug 19, 2012, 05:50 PM
josereyes is offline
Find More Posts by josereyes
josereyes's Avatar
United States, WA, Steilacoom
Joined Nov 2011
That would depend on what head speed you are looking for... as you lower the head speed, if the motor is too high of kv, that would mean that you would have to lower your pinion to achieve the head speed desired and esc throttle curve and your motor efficiency, this creates heat... the motor should run at the desired head speed and efficiency of 90 % or better... as it goes below that efficiency it start creating heat on the motor and esc. That's what's causing all these fires on the ESC's, if you don't monitor the heat it will eventually catch on fire. In my case the motor kv was too high (560kv) for the head speed I was looking (1400's), so it was creating excessive heat for the ESC and motor causing it to overheat. Going to the lower kv (500kv) took care of the heat issues on the motor and ESC now it runs at 90% or higher efficiency and a temp of about 25 35 degrees above ambient temp, which is what you want for long term flights... 14-20 minutes easy...
You will need to monitor the ESC heat range as it should not be any higher than about 30 degrees higher than the ambient....
The reason I grought this up is because I had to learn the hard way and the hard way gets very expensive
josereyes is offline Find More Posts by josereyes
Old Aug 19, 2012, 11:10 PM
United States, FL
Joined Jun 2008
Jan,
Do you have a link to purchase the apache fuse. I think I am ready for the body. going on a 8 day vaca to stay home in a few weeks. It would be a great time to start the build.
Has anyone heard of these people and this heli?
http://www.scaleflying.com/AH-64-IAF...ct_p_1112.html
thanks
Buddy
Old Aug 19, 2012, 11:57 PM
United States, FL
Joined Jun 2008
Thank u Jose. It is always nice to learn from other peoples trial and error. I'm sure u saved me some $$$.
Old Aug 20, 2012, 01:23 AM
Horseman is offline
Horseman's Avatar
The Netherlands, FR
Joined Aug 2008
Jan,
thanks
Buddy
Smartmodels don't sell them anymore.
But you can order it by TF models.
The link you mention are RCA and they are good people, my scale blades are coming from them. as well my BlackHawk is from them trough the German dealer here in the EU.
The Apache they offer seems also a Smartmodel/TF kit.
Kind regards,
Jan,
Old Aug 20, 2012, 07:05 AM
United States, FL
Joined Jun 2008
I ordered it and the torque tube raise kit. Let's see what we get!!
Old Aug 20, 2012, 07:17 AM
CW4 is offline
CW4
Find More Posts by CW4
CW4
Joined Aug 2012
I ordered that exact Apache from that link back in June. I received it in less than a week. Good stuff and good people. I also ordered the torque tube tail drive from them as well. Fast shipping if you live in the US.
CW4 is offline Find More Posts by CW4
Old Aug 20, 2012, 07:54 AM
Horseman is offline
Horseman's Avatar
The Netherlands, FR
Joined Aug 2008
You will be fine
Jan,
Old Aug 20, 2012, 09:22 PM
United States, FL
Joined Jun 2008
Also, how do u guys make the rivots. They look great.
Old Aug 21, 2012, 02:29 AM
Horseman is offline
Horseman's Avatar
The Netherlands, FR
Joined Aug 2008
Hi Buddy,
I know that Jay makes them from drips of canopy glue.
I draw them, but the canopy glue option are more real.
You can also order sets of plastic rivets, then you need to drill and glue.
Jan,
Old Aug 21, 2012, 10:58 AM
United States, FL
Joined Jun 2008
http://www.scalehardware.com/
Found these. Maybe cut the top off and glue them on.
Old Aug 21, 2012, 11:27 AM
josereyes's Avatar
Joined Nov 2011
Mobile links not working
Old Aug 21, 2012, 12:56 PM
Horseman is offline
Horseman's Avatar
The Netherlands, FR
Joined Aug 2008
It works for me?
But a stunning website, never know that you can get bolts and nuts that smalllllllllllllll
Old Aug 21, 2012, 09:42 PM
United States, FL
Joined Jun 2008
Jan,
How did you order that left hand pitch arm. I need one....
thanks
Buddy
Discussion Smartmodel Apache AH64 + T-Rex 600 ESP Hummerfresse Scale Helicopters 33 Feb 18, 2012 12:47 PM
For Sale SYMA S009G AH-64 Apache 3 Channel Indoor Helicopter with Gyroscope $25.00 Shipped! Hellihawk Aircraft - Electric - Helis (FS/W) 2 Jul 06, 2011 03:13 AM
Discussion 1st Look: HeliArtist 500 Size AH-64 Apache Fuselage BlackTitanium Scale Helicopters 18 Jan 16, 2010 03:14 AM
Rant AirHogs Reflex AH-64 3ch vs. other AH-64 Apache 3ch Sandbox\Hangar Jay-viator Micro Ready-to-Fly 56 Feb 01, 2009 04:21 PM
Video AH-64 Apache 450 size darthdrk Electric Heli Talk 3 Aug 07, 2008 12:37 AM
