Old Aug 15, 2011, 07:37 PM
jaksno is offline
Find More Posts by jaksno
jaksno's Avatar
Norwood, CO
Joined Jul 2009
Question
High altitude flying/operating experince?
In the Beginner thread I have a post about a Sierra and Evo.40 at 7000 ft - I may just need to better tune the engine, but if anyone could go there and look for:
"Do you have experience with Top Flite Sierra and Evo .40?" over there, I'd sure appreciate it!
jaksno
jaksno is offline Find More Posts by jaksno
Old Aug 15, 2011, 09:00 PM
Elios000 is offline
Find More Posts by Elios000
Elios000's Avatar
United States, MO, Springfield
Joined Jul 2010
hmm may want to look in to e power and higher then listed pitch prop
Elios000 is offline Find More Posts by Elios000
Old Aug 16, 2011, 09:44 AM
jaksno is offline
jaksno's Avatar
Norwood, CO
Joined Jul 2009
Excellent thinking. But I've set this 'task' as I've had the desire for so many years to do R/C with fuel, have the Bud Nosen Champ almost ready to go, and am trying to transition from the foamies and electric, which I like a lot, so I can eventually fly the Champ without too much chance of wrecking, etc.
I've been flying e powered foam for a couple years, and ailerons recently with no problem; finally starting to attempt to fly the tail dragger converted Sierra, the last step in the saga to flying the champ and possibly hanging it up as far as fuel goes.
Then back to all the possibilites of foam, Guillow conversions, etc.
Thanks!
jo
Old Aug 16, 2011, 04:05 PM
Elios000 is offline
Elios000's Avatar
Joined Jul 2010
you may just need a bigger motor at that alt is the issue
Old Aug 17, 2011, 12:44 AM
jaksno is offline
jaksno's Avatar
Norwood, CO
Joined Jul 2009
I agree, Elios. At the moment, I'm considering the idea of using a hi-start/bungee/catapault as well.
thanks,
Jackson
Old Aug 18, 2011, 08:46 AM
Chip01 is offline
Find More Posts by Chip01
United States, TX, Weatherford
Joined Dec 2006
The engine will operate about the same as if it were at sea level. It may tun a bit faster due to the density change. Other factors that effect the engine are humidity and temperature. It is not like a regular gasoline engine or a diesel engine where asperation would be a problem. That's why the trucks all have turbo chargers, takes care of the altitude problems among other things.
I would fuel it up and go fly. Do the same things like backing off a couple of clicks to enjure you do not go lean in the air. I think you will have no problems.
Chip
Chip01 is offline Find More Posts by Chip01
Discussion High altitude flying? AleG Multirotor Talk 35 Aug 19, 2011 03:07 AM
The High Altitude Slug Project - A cheap high altitude UAV! phatmonkey UAV - Unmanned Aerial Vehicles 11 Nov 13, 2005 05:16 AM
TM: High Altitude Flying Hasina75 Parkflyers 3 Aug 10, 2002 10:51 PM
Flying Drenalyn at high altitude DeaninMilwaukee Scratchbuilt Indoor and Micro Models 3 Jul 08, 2002 05:00 PM
high altitude flying Bruce Janssen Electric Sailplanes 6 Apr 14, 2002 01:31 PM
