Old Sep 08, 2003, 05:39 PM
power is offline
Find More Posts by power
Begin with end in mind...
power's Avatar
Eagle Lake, Minnesota
Joined Apr 2003
12volt wallwart power supply reading 14.6 ? (help)
Hi, all I just purchased a 12 volt 1500mah wallwart power supply for my apache, when I checked the no load voltage it reads 14.6.The apache instructions state not to use anything over 13.8 will this be o.k? Is this a normal reading with no load? Thanks a bunch!!!
POWER
power is offline Find More Posts by power
Old Sep 08, 2003, 05:57 PM
RMFISH is offline
Find More Posts by RMFISH
Surrey, BC Canada
Joined Apr 2000
Put a load on that baby and the voltage will drop. How much is debatable but will probably get you to the voltage you need.
Robert.
RMFISH is offline Find More Posts by RMFISH
Old Sep 08, 2003, 09:28 PM
Mike4122KSA is offline
Find More Posts by Mike4122KSA
Arkansas
Joined May 2003
They all do that. Should work just fine....
Mike in Arkansas
Mike4122KSA is offline Find More Posts by Mike4122KSA
Old Sep 09, 2003, 10:53 AM
mkirsch1 is offline
Find More Posts by mkirsch1
United States, NY, Spencerport
Joined Oct 2001
Perfectly normal. The wall wart only produces the rated voltage at the rated current draw. At lower currents, the voltage is higher, and at higher currents, the voltage is lower. It's just like a NiCd.
mkirsch1 is offline Find More Posts by mkirsch1
Old Sep 09, 2003, 04:21 PM
power is offline
power's Avatar
Joined Apr 2003
Thanks!!
Thanks to all!! I can rest my mind a little now.
What Kind Of Power Supply For Isl 6-330d Dog Flyer Batteries and Chargers 9 Aug 19, 2004 12:19 AM
pc power supply only 10.9v Help thesnapper Batteries and Chargers 15 Mar 10, 2004 04:27 PM
Power supply box for charger! help! sykdevil Batteries and Chargers 2 Jan 05, 2004 01:26 AM
12volt, 9amp power supply for sale Paul Susbauer Aircraft - Electric - Airplanes (FS/W) 1 Dec 03, 2003 12:44 PM
Power supply for triton charger help ehooper Batteries and Chargers 4 Apr 14, 2003 07:23 PM
