Old Aug 15, 2011, 10:03 AM
ita47 is offline
Find More Posts by ita47
Southwest Missouri
Joined Aug 2010
Help - How do you mount a Super Tigre 370 on a GWS Slow Stick?
I have a GWS Slow Stick and I just got a Super Tigre 370 brushless motor given to me. Does anyone know of a motor mount for this setup? Has anyone mounted this motor on the slow stick? If so how did you do it? If not what plane has anyone used this motor on?
ita47 is offline Find More Posts by ita47
Old Aug 15, 2011, 12:39 PM
restlessswind is offline
Find More Posts by restlessswind
restlessswind's Avatar
United States, CA, Sacramento
Joined Jan 2010
http://www.headsuprc.com/servlet/the...ck-with/Detail
the disk portion of this stick mount would work well, but something on this site should work
restlessswind is offline Find More Posts by restlessswind
Old Aug 15, 2011, 08:06 PM
wpnguy is offline
Find More Posts by wpnguy
wpnguy's Avatar
lakeridge VA.
Joined Jan 2005
I am not familiar with the super tigre, but, millenniumRC.com makes a nice mount
wpnguy is offline Find More Posts by wpnguy
Old Aug 16, 2011, 06:30 PM
Piece is offline
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
This mount would be the ideal way to do it, but it's out of stock.
The Millennium mount mentioned above is virtually the same thing and will do the job just as well.
Piece is offline Find More Posts by Piece
Old Aug 16, 2011, 07:07 PM
eckace1 is offline
Find More Posts by eckace1
OFF TOPIC POSTER
Des Moines IA
Joined Dec 2005
Radicalrc and hobbyparts have that mount as well.
eckace1 is offline Find More Posts by eckace1
Old Aug 17, 2011, 10:41 PM
ita47 is offline
Southwest Missouri
Joined Aug 2010
Thanks guys but those mounts wont work with the Super Tigre motor. It has a 3 point mount like a triangle on a 34mm diameter. Most motors use the standard 4 point mount like the ones you posted this little guy is different. You can't see all three mounting points in the picture but I think you can get the idea. The disk mount is close but the bolts would be right on the outer edge and I'm not sure it would work, it's just a little bit too small.
Old Aug 17, 2011, 11:00 PM
Piece is offline
Piece's Avatar
Joined Aug 2009
Oooohhh, THAT motor. Yeah, there are some oddballs that use that setup. I think Electrifly's smaller Rimfire motors do, too.
You could just get a small piece of plastic or wood and drill the 120* holes in it for that mount, then bolt/glue it to a normal one. A bit of epoxy would be more than enough to hold it. If you really like to work with wood, you could make your own stick mount that goes straight on the fuselage without needing one of those mounts...
Old Aug 17, 2011, 11:11 PM
bubba153 is offline
Find More Posts by bubba153
Joined Nov 2009
Description:
This would work failing anything else. Just use a small piece of light ply between this mount and the ST mount.
You can find this under the motor mounts at Radical RC
Bob
bubba153 is offline Find More Posts by bubba153
Old Aug 17, 2011, 11:29 PM
Piece is offline
Piece's Avatar
Joined Aug 2009
Wait a minute. Does that funky silver mount come off the motor (screwed to a round post/tube type thing), or is it built in?
If it's a separate piece, would something like this mount work?
Old Aug 18, 2011, 10:29 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
Unfortunately, if it is like the 400, the bearing tube is 9mm... and very short!
From my review of the 400: "The ST 400 is 28mm diameter, 30mm long and has a three armed mount which requires three mount holes on a 34mm circle. This mount is locked to the bearing tube with a single machine screw... the bearing tube is 9mm... a real and annoying oddity, since just about every other motor of this size uses an 8mm or a 10mm bearing tube.... for which there are readily available stick-mounts".
The SuperTigre .10 has a 12mm bearing tube.
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Aug 18, 2011, 10:37 PM
Piece is offline
Piece's Avatar
Joined Aug 2009
Ouch... That's stupid
Old Aug 18, 2011, 11:00 PM
Nathan Schmoekel is offline
Find More Posts by Nathan Schmoekel
ground penetration specialist
Nathan Schmoekel's Avatar
USA, MI, Grand Rapids
Joined Apr 2007
Really guys......
Just get scrap of light ply, some triangle stock, and make a firewall on the front.
Mount pieces of triangle stock to the four sides of the stick "fuselage". the result you want is flat front, cross shaped surface. Then glue/screw the ply to the front as a firewall style motor mount.
Screw the motor to the firewall.....DONE
Adjust the thrust line by stacking washers between the motor and wall if necessary.
Nathan Schmoekel is offline Find More Posts by Nathan Schmoekel
Old Aug 19, 2011, 12:52 AM
1320fastback is offline
Find More Posts by 1320fastback
Detroit 2-stroke junkie
1320fastback's Avatar
USA, CA, Oceanside
Joined Jul 2008
I make my own mounts like the one in the second post.
Two simply round disc of ply laminated together (cross grain of course) and then cut a shaft that fits inside the SS stick. The end of the shaft get a dual angle cut to angle the ply down and to the right 6 degrees and 3 degrees respectively.
4 small triangle gussets and epoxy the whole thing together. It takes about 20 minuets start to finish (not including epoxy curing ).
1320fastback is offline Find More Posts by 1320fastback
Discussion How do you "do" the wooden engine mount? Sky-walker Giant Scale Airplanes 6 Jul 24, 2011 09:21 AM
Discussion Buying my first RC Plane: GWS Slow Stick. What parts do I want/need? RCrox Electric Plane Talk 3 May 27, 2011 01:59 PM
Discussion How do I mount a GWS prop on a Park 370 prop adaptor? feet wet Parkflyers 3 Feb 14, 2006 05:38 PM
How do the servos mount on the slow stick? Lammergier Parkflyers 5 Feb 24, 2003 07:40 PM
HELP! How do you mount the orange 1047 prop on the GWS DX-A? EFoil Parkflyers 6 Sep 08, 2001 11:41 PM
