Old Aug 13, 2011, 11:51 AM
hotshot564 is offline
Find More Posts by hotshot564
USA, OH, Conneaut
Joined Jan 2011
Boat planks
My set up for making planks
hotshot564 is offline Find More Posts by hotshot564
Old Aug 13, 2011, 12:30 PM
Gravman is online now
Find More Posts by Gravman
United States, TX, La Porte
Joined Apr 2007
With your fence set to the left didn't you have to keep changing it after each pass? I may be missing something though. When I cut mine I set the blade about 3/16 from the fence and cut them. Kinda scary either way you do it.
Gravman is online now Find More Posts by Gravman
Old Aug 13, 2011, 01:20 PM
420TEE is offline
Find More Posts by 420TEE
North Central TN USA
Joined May 2006
I've done something similar and had a bunch of shims the right thickness and add one between the fence and plank each pass.
420TEE is offline Find More Posts by 420TEE
Sharky1dk is offline
Find More Posts by Sharky1dk
Woodfumbler......
Sharky1dk's Avatar
Copenhagen. Denmark
Joined Apr 2010
Nice surroundings, for making planks.
And the results is looking good to.
Robert
Sharky1dk is offline Find More Posts by Sharky1dk
Old Aug 13, 2011, 01:30 PM
patmat2350 is offline
Find More Posts by patmat2350
Vita ex Machinis
patmat2350's Avatar
Motor City
Joined Dec 2004
I rip them on a bandsaw, but have to thickness sand to finish...
patmat2350 is offline Find More Posts by patmat2350
Old Aug 13, 2011, 02:58 PM
RGinCanada is offline
Find More Posts by RGinCanada
Tinkerer in Training
RGinCanada's Avatar
Guelph, ON
Joined Sep 2004
Ripping thin strips is a lot easier with a zero-clearance insert and the proper blade. I have ripped down to a little under 1/8" with a Freud Glue-Line Ripping blade on my Ridgid table saw.
RGinCanada is offline Find More Posts by RGinCanada
Old Aug 13, 2011, 03:29 PM
Joined Apr 2007
Yes, I have to run mine through the thickness sander after I cut them. My thickness sander must have had 10,000ft of Mahogany run through it over the years. It is from way back in the 1980's. It just keeps chunging along.
Old Aug 13, 2011, 04:00 PM
USA, OH, Conneaut
Joined Jan 2011
You have to push the board up against the feather board, then move the fence up to it and lock it with each pass. Works real well, because the strip is not being stuck between the fence and blade. The strips are 3/32" x 48" Don
Old Aug 13, 2011, 04:33 PM
420TEE is offline
Joined May 2006
Actually you can cut one that is correct then use it and every succeeding one for spacers.
Old Aug 13, 2011, 04:42 PM
chesguy is online now
Find More Posts by chesguy
chesguy's Avatar
Hamilton,ON Canada
Joined Dec 2009
Don't you still need to allow for kerf of the blade each time?
chesguy is online now Find More Posts by chesguy
Old Aug 13, 2011, 04:47 PM
Stu Kerrn is offline
Find More Posts by Stu Kerrn
SLK
Stu Kerrn's Avatar
USA, IL, Morton
Joined Feb 2007
Sawing Planks
I have a four inch table saw with a micrometer on the rip fence. I saw all my planks a few thousandths wide (band saw or the small table saw carbide blade) and then use a hand micrometer, get the plank size and then use the micrometer on the rip fence to get the exact size I feel I want, every time. My saw has a removable blade cover insert, to have zero blade clearance for various thickness slitting blades (no kerf). With this method I can make 1/32 square stock. Thank you Stu Kerrn
Stu Kerrn is offline Find More Posts by Stu Kerrn
Old Aug 13, 2011, 08:39 PM
norgale is offline
Find More Posts by norgale
Retired for now
Bonita Springs,Fl.
Joined Sep 2007
Nice set up Hotshot. I'll have to try that on my table saw. The only thing missing in your pictures is a nice old time mahogany runabout at the dock. Nice looking site. pete
norgale is offline Find More Posts by norgale
Old Aug 14, 2011, 12:30 PM
boater_dave is offline
Find More Posts by boater_dave
Big Boats Rule!
boater_dave's Avatar
Wisconsin
Joined Jun 2007
I used a disposable piece of thin ply clamped to the table as a zero clearance insert. I would set the fence position by testing on a scrap piece. Then lower the blade and clamp the ply in place. Start the blade and raise it through the ply. And my fence is on the right side of the blade so it doesn't change for each cut. I found that it works best to cut the planks from a bigger board by ripping the plank thickness dimension first, then going for the width. Always start with longer planks than needed so you don't have to worry about the last few inches. And use a push stick and finger boards as needed to keep the stock under control. A helper to pull the pieces out the other end helps, too.
Dave
boater_dave is offline Find More Posts by boater_dave
Why planks for EPP DS? aussie Dynamic Soaring 22 Dec 22, 2004 12:56 PM
Help launching planks jleonard Slope 12 Sep 12, 2004 03:48 PM
Do planks fly funny or is it just me? Cody WIlson Slope 23 Sep 08, 2004 02:22 AM
kyosho series 91 6 ch heli radio heli or planks $30 jschick Aircraft - General - Radio Equipment (FS/W) 0 Jul 26, 2004 02:49 PM
Yippee! How many Planks Planes do I own? Vinnya42 Slope 6 Jul 21, 2003 04:08 PM
