Old Aug 12, 2011, 11:03 PM
GreenAce92 is offline
Find More Posts by GreenAce92
Physics hate's my ideas
GreenAce92's Avatar
USA, NY, Dunkirk
Joined May 2007
Long duration high speed EDF's do they exist?
I'm starting to get into FPV flying and I'm looking for speed and duration!
EDF's seem to be best for high pitch speed...
I've got a design I'm thinking about doing however I should know first if an EDF would be worth looking over for an FPV plane
Say 70mph at least (not full power) and say a flight time of at least 15 minutes
GreenAce92 is offline Find More Posts by GreenAce92
Old Aug 12, 2011, 11:31 PM
racer1 is offline
Find More Posts by racer1
5kW Club
racer1's Avatar
United States, AZ, Tucson
Joined Feb 2007
Stick with props, EDF are not efficient in any way shape or form.
racer1 is offline Find More Posts by racer1
Old Aug 12, 2011, 11:36 PM
GreenAce92's Avatar
USA, NY, Dunkirk
Joined May 2007
Says the guy with an EDF for an avatar...
What if you took that air frame (for example the one you have) and then put a small high pitch prop on there...
Better results?
Old Aug 12, 2011, 11:46 PM
LuvEvolution7 is offline
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
deffinitely better results. but define better. better slower top speed, or better more endurance? you'll get more work done on less amps, but not as high in the speed range. for FPV, I'de stick with prop. unless you've got big glider-like wings and can fly slow, power down, then dly slow, it might be a good way to go. think of the UAV Predator. something like that. if you wanna go fast, your flight times will be a lot less. somewhere around 7 minutes or less, depending on battery size. I'de go with a prop, based on those flight times. EDF is unrealistic at that speed range, unless you are willing to make it into a glider, as suggested above.
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old Aug 12, 2011, 11:51 PM
GreenAce92's Avatar
USA, NY, Dunkirk
Joined May 2007
An EDF glider?
What about a high aspect ratio glider, which can glide because of the high loading on the wings = better L/D ratio
I had this idea for a variable EDF intake which could be closed when you don't want the EDF to be in use, so the EDF is basically sealed off and the glider has clean aerodynamics (as good as it gets)
Old Aug 12, 2011, 11:53 PM
racer1 is offline
5kW Club
racer1's Avatar
Joined Feb 2007
To fly jets using a fan systems, it is usually lots of small props tied together to make a fan, high rpm for thrust, lots of amps to do it with.
Larger prop, lower rpm, lower amps.
If you are posting here you must have some experience with EDF, then you know we have been searching long flight times for awhile. 4 to 6 minutes is all we get with good throttle management.
If you can figure out the setup you want, I am sure you could sell a few.
Good luck
Old Aug 12, 2011, 11:56 PM
GreenAce92's Avatar
USA, NY, Dunkirk
Joined May 2007
Well... my experience is nil almost none...
I had a cheap model of an Albatross once a little 2ch thing
Not really the same as a 70mm fan
What kind of rpms are we talking about here anyways?
Old Aug 13, 2011, 12:03 AM
racer1 is offline
5kW Club
racer1's Avatar
Joined Feb 2007
My 5 inch Dynamax, 12s, 25,000 rpm 110 amps
Vio fan, 12s 27,500 rpm 144 amps
Modified Ramtec 12s 26,000 rpm 128 amps
90 mm Fan 6s 34,000 rpm 65 amps
My friends flying wing FPV- UAV 4s, 14 inch prop, 45 minutes plus flying time.
Just some numbers for you, to think about
Old Aug 13, 2011, 12:08 AM
GreenAce92's Avatar
USA, NY, Dunkirk
Joined May 2007
Hmm... So EDF really doesn't have a chance?
Even if, let's say you take a hot liner body, have an EDF motor with a gate for both the intake and the outtake (exhaust?)
That way you can seal the engine up to be a complete pod which has no holes for drag...
How much does efficiency drop when you change the intake hole/outtake hole from a complete circle to say a flattened ellipse... ?
Old Aug 13, 2011, 12:13 AM
racer1 is offline
5kW Club
racer1's Avatar
Joined Feb 2007
Hotliner is just a special glider.
10 to 15 seconds of full power, climb out of sight then glide around, then power up, and repeat.
Get the right setup, prop for best speed at the lowest current/amp draw.
Use a Castle Creations Ice controller and you can download the data and look at rpm, amp draw, etc.
There is no right answer, you will have to find the setup you want, I am sure you can find better answers in the glider, or prop sections, or the FPV-UAV sections, good luck.
Old Aug 13, 2011, 12:14 AM
Mike Warren is offline
Find More Posts by Mike Warren
BOHICA!
Mike Warren's Avatar
Joined Dec 2010
69mm fan typically 45,000 up to around 60,000RPM
Big fans, like Clay says.....25,000RPM or a bit more
Forget EDF for "speed + long flight times", the system is meant to replicate jet like flight and has to achieve it by pouring (compared to props) gobs if power into a less "efficient" setup.
Mike Warren is offline Find More Posts by Mike Warren
Old Aug 13, 2011, 12:17 AM
GreenAce92's Avatar
USA, NY, Dunkirk
Joined May 2007
That's too bad
I think I may just go with a folding prop type deal, where I can have a good constant "on" time and then turn the motor off and glide.
I appreciate the input guys, I'm glad I didn't waste the effort in materials to find out this answer
Old Aug 13, 2011, 07:52 AM
erh7771 is online now
Find More Posts by erh7771
Joined Nov 2005
The simple answer is low wing load...as low as possible...I can get around 10mins out of the Tieseng 70mm T-45 if I only did a couple of high speed passes but the rest of the time I let it float when using 4000mah battery.
15min is something you'd get out of a glider with a fan on it but as mentioned before you're erasing speed.
HK does sell a 70mm edf global hawk with 80" wing span, don't now if it'll go 70 plus.
erh7771 is online now Find More Posts by erh7771
Old Aug 13, 2011, 07:54 AM
Joined Jan 2009
not even close. 50MPH tops and that's only if you dive down from about 5000 feet to get there. LOL.
Old Aug 13, 2011, 02:34 PM
skyhawk1 is offline
Find More Posts by skyhawk1
United States, OH, Corning
Joined Nov 2004
Take a look at the Great Planes Syncro. It is an EDF and has sailplane wings.
I have one and on a 3 cell 2600 it gets flight times of 20 minutes with the motor running. But the speed is way below 70 mph. At full throttle it will fly pretty fast.
It is heavy so it does not soar all that good. But if you float around awhile with the 2600 battery 30 minutes flights are pretty easy to achieve.
The quality on the Syncro is excellent. And it is a great flier. So if you need an EDF the Syncro might work for you.
There is a thread on it here in this forum as well as the electric sailplane forum.
Todd
skyhawk1 is offline Find More Posts by skyhawk1
Help! Hobbyking!!! Do they really Exist??? jacktrotter HobbyKing 40 Jun 14, 2011 02:09 PM
High quality servos - how long do they live? bdunsire Giant Scale Airplanes 2 Sep 04, 2005 11:12 AM
Slow Stick...do they really exist? daycat Parkflyers 30 Apr 26, 2005 01:21 AM
Help do they still exist? Theo coenen Fuel Plane Talk 2 Aug 19, 2003 01:51 AM
Cybirds - Myth? Or do they exist ? andyUK Ornithopters 0 Dec 08, 2002 10:38 AM
