Old Nov 09, 2011, 08:45 PM
SidewaysLS4 is offline
Find More Posts by SidewaysLS4
Redjestird Youser
SidewaysLS4's Avatar
Joined Jan 2009
Just as an example . I'll probabaly do urethane vs. the neoprene. I have a urethane on my Redbird, and it looks like new even with countless hours flight time on it. Now to get my butt in gear...STILL havent taken the 550 out of the JetRanger...
SidewaysLS4 is offline Find More Posts by SidewaysLS4
Old Oct 16, 2012, 06:39 AM
SteelHeadz is offline
Find More Posts by SteelHeadz
United States, TX, Kerrville
Joined Aug 2011
Cap, what's your final tally on the HK600 stretched to a 700. What parts and part numbers did you get to make this work?. I see this thread is pretty old but im hoping to wake y'all up.
SteelHeadz is offline Find More Posts by SteelHeadz
Old Oct 16, 2012, 08:53 AM
JoseReyes69 is offline
Find More Posts by JoseReyes69
Jose Reyes
JoseReyes69's Avatar
Steilacoom, WA
Joined Feb 2010
RC Aerodyne has these parst for the conversion....
http://www.scaleflying.com/700-Size-...be_p_1737.html
JoseReyes69 is offline Find More Posts by JoseReyes69
Old Oct 16, 2012, 12:26 PM
cap231ex is offline
Find More Posts by cap231ex
Track clear , smoke on !
cap231ex's Avatar
3 miles from AMA HQ Muncie, IN.
Joined Jan 2009
All that is , is a 700 boom and a 700 TT which ends up making it longer then an actual 700 unless you cut both down.
Basically all one really needs is the belt , a 700 boom (which gets roughly 49mm cut off of it to make the correct 700 length) , 680-710mm blades, and I installed the Thunder Tiger 8t pulley on the rear of my tail rotor gearbox to speed up the tail.
Other than that maybe re-gear (lower pinion) or go with a lower Kv motor , I went with a Z-power A-50 780Kv motor and an 11t pinion running on a 6s pack on mine.
Yeah this is an old thread sence this I have stretched a T500 into a T550 , a T500 into a T600 , and a T450 into a T500 all with great success.
cap231ex is offline Find More Posts by cap231ex
Old Oct 18, 2012, 06:29 AM
Joined Aug 2011
Awesome, Thanks for the response and help guys. I have an extra set of 600 frames that i bought from fpainter and quite a few spares from my hk600 that i want to stretch to a 700. I'm converting my current hk600 to a scale airwolf with cnc retracts then i'll start the build on this stretched bird. Thanks again.
Old Oct 18, 2012, 06:30 AM
fpainter3 is offline
Find More Posts by fpainter3
fpainter3's Avatar
USA, KY, Florence
Joined Aug 2007
A proper Helicopter has skids !!! I am looking to build a Bell 206.
fpainter3 is offline Find More Posts by fpainter3
Old Oct 18, 2012, 05:14 PM
Joined Aug 2011
I looked around on Ebay for that Bell 206 and all i've been seeing is for a 700 class. Hey!! whatch'a talking about?, are you saying my 600 will not be proper since it has retractable wheels? , lol. . If all else fails, i can just drive the heli on my front yard , haha..
Old Oct 18, 2012, 05:15 PM
cap231ex is offline
cap231ex's Avatar
Joined Jan 2009
No problem glad to help.
Old Oct 18, 2012, 06:03 PM
fpainter3's Avatar
USA, KY, Florence
Joined Aug 2007
My neighbor has a 90 sized 222 with retracts. It is really cool looking on a high speed low pass. he even bounced it on its belly once on a high speed pass with no damage.
It uses Graupner mechanics and is converted to electric with a big old Scorpion in it.
Old Nov 25, 2012, 11:41 AM
cap231ex is offline
cap231ex's Avatar
Joined Jan 2009
Finally been getting some progress done on the 206L and thought I would share .
The horizontal and vertical fins in the last 3 pics are just dry fitted and not glued or anything , that is way they are sagging downwards.
The upper cable cutter is just setting in place for the pics as well and won't get install permanently until the black , and dacals are applied then the clear will get shot on.
Enjoy the pics.
Old Dec 04, 2012, 07:19 PM
cap231ex is offline
cap231ex's Avatar
Joined Jan 2009
Here is your first look at the paint job
Just finished peeling off all the liquid mask and other masking to reveal one bad a$$ looking heli.
It almost turned out exactly like I envisioned it would , I still have a few small issues to deal with as far as masking lines and such but nothing I can't deal with.
I'm going to give it a couple more days before I start to apply the Callie Graphics and than spray the clear coat.
I think all in all it came out pretty close to the real one as I could get it , although there are a few areas I would like to do a little different if I had the chance.
Old Dec 04, 2012, 08:05 PM
Keyrigger is offline
Find More Posts by Keyrigger
Love my scale Whirlybirds
Keyrigger's Avatar
Mississauga, Ont., Can.
Joined Sep 2009
Looks really good.
Don
Keyrigger is offline Find More Posts by Keyrigger
Old Dec 05, 2012, 06:33 AM
fpainter3's Avatar
USA, KY, Florence
Joined Aug 2007
A proper Helicopter, I don't like the pitot tube(or whatever that is sticking out) holder, though. It ruins the look, even on the full size one.
Old Dec 05, 2012, 06:55 AM
mligosh is offline
Find More Posts by mligosh
mligosh's Avatar
New Smyrna Beach, FL
Joined Jun 2005
Awesome Cap. Looks great. Those colors really pop against the black. Where did the cable cutters come from?
mligosh is offline Find More Posts by mligosh
Old Dec 05, 2012, 09:56 AM
cap231ex is offline
cap231ex's Avatar
Joined Jan 2009
I made them from multple layers of 1/32" and 1/16" Liteply plywood and piano wire.
Discussion Turnigy T600 880kv Delta to Wye help mattyhawk Electric Motor Design and Construction 34 Jul 09, 2011 08:04 AM
For Sale Turnigy T600-880KV motor helifrek Aircraft - Electric - Helis (FS/W) 2 May 20, 2011 09:29 PM
Sold *** Turnigy T600-1100Kv for Trex 600 *** Rudderman98 Aircraft - Electric - Helis (FS/W) 3 May 19, 2011 06:19 PM
Sold *** Turnigy T600-1100Kv for Trex 600 *** Rudderman98 Aircraft - Electric - Power Systems (FS/W) 4 May 19, 2011 06:14 PM
Discussion Quieting down a T600/T550 scaler with a Helical main gear SidewaysLS4 Scale Helicopters 2 May 02, 2011 06:00 AM
