Old Aug 22, 2011, 05:21 PM
cap231ex is offline
Find More Posts by cap231ex
Track clear , smoke on !
cap231ex's Avatar
3 miles from AMA HQ Muncie, IN.
Joined Jan 2009
It a cheapoo Walkera WK-2801 PRO version 2.3 8-CH 2.4 GHz.
cap231ex is offline Find More Posts by cap231ex
Old Aug 22, 2011, 06:39 PM
mrmj2u is offline
Find More Posts by mrmj2u
mrmj2u's Avatar
United States, DC, Washington
Joined Mar 2011
Nice! I fly with a Flysky 6 channel... Works ok, but I hate having to connect it to a computer to program it... Love my DX6i though!
mrmj2u is offline Find More Posts by mrmj2u
Old Aug 22, 2011, 10:22 PM
SidewaysLS4 is offline
Find More Posts by SidewaysLS4
Redjestird Youser
SidewaysLS4's Avatar
Joined Jan 2009
Yeah, the sticks are bb and adjustable. Feels real nice too, this DX6i I'm sorta using feels...well, I want my DX8 back, lol. That DX6i also has a lurchy up elevator making things weird...uneven pot that shows up in travel vs. commanded % looking at FBL software monitoring. I think that was like that since new. One of the reasons I upgraded to the 8
The DX8 warranty for this problem is pretty much moot, it also falls under a recall program for aileron issues, which it fails the 'official' test also, so it should be taken care of. They even sent a shipping label to send it in.
While I'm bashing the DX6...man I hate how you have to turn off throttle hold to turn the radio on...and I'm so spoiled with the 8's auto-start timer also. Dont think I'll convert any more birds to it in the meantime.
SidewaysLS4 is offline Find More Posts by SidewaysLS4
Old Aug 31, 2011, 11:53 AM
cap231ex is offline
cap231ex's Avatar
Joined Jan 2009
Finally received my 700mm blades , I got the FG to test the concept . In the middle of balancing them and then will move on to the flight testing to see how well everything turned out.
On an off topic note a couple of days back I was at the field flying the 500E an might a fellow flier with a Logo 600 , long story short I got to fly it and was very impressed. It was running on 12s and was FBL with a V-bar and had a Scorpion motor, it was set up to fly 3D but was very manageable with no bad habits.
Old Aug 31, 2011, 07:34 PM
cap231ex is offline
cap231ex's Avatar
Joined Jan 2009
Got a short test flight in and to my surprise everything works great , I was worried about my motor and ESC not being up to snuff to swing the larger 700mm blades. I measuredthe temps on the batteries , ESC, and motor after a 7 minute flight of FF and hovering mostly hovering testing the tail workability but everything was cool . Temps were as follows ESC=112.8` F , motor=102.4` F , batteries= 114.0` F and the batteries were at almost the same voltage as with the 600mm blades for the same amount of time, hhmmmm.
The one thing I have noticed is that I will probably need to install larger dia. linkage rods and balllinks as I noticed the tracking seemed to change about 1/4" at the blade tips from flight to flight. I don't think that is to big of a deal though and I think I will change the tailrotor gearbox to an Align all plastic to help with the CG as well. All in all if one is looking to make their 600 into a 700 this mod is well worth a look as it is now a proven mod not just an ideal any more.
Old Sep 14, 2011, 02:38 PM
cap231ex is offline
cap231ex's Avatar
Joined Jan 2009
Got some new parts in after checking around at fuselages I found that my distance from the mainshaft to tailshaft was way to long (980mm). All the 700 fuselages I found would accept a distance of 910-940mm from main to tail shaft , so I needed to lose 40-70mm in tailboom length. After looking high and low for a belt that would get me in that range I came across Polybelts.com http://shop.polybelt.com/main.sc they have a large inventory and great prices.
I also besides changing the boom length plan on a few upgrades , to help on the CG I plan on installing a plastic tail drive gearbox and blade grip . On the top side I plan on installing Align 600 linkage rods (1.95mm vs HK's 1.75mm)and ball links and their 70* rubber dampeners to fix the tracking issue. I also got a couple pair of Fusuno 95mm tail blade to try although the 85mm Swift tail blades held it very good before, here is some pics to check-out.
Old Sep 14, 2011, 07:48 PM
cap231ex is offline
cap231ex's Avatar
Joined Jan 2009
After going some measuring it looks like the 700XL belt is the winner , it will put my main to tail shaft distance at 925mm.
Anyone with a stock Align 700 that could give me a good measurement along the tailboom from mainshaft to tailshaft to confirm this number that would be great.
Old Sep 15, 2011, 08:31 AM
mrmj2u is offline
mrmj2u's Avatar
Joined Mar 2011
Does this belt require that the tail drive gear be shaved?
Old Sep 15, 2011, 11:13 AM
cap231ex is offline
cap231ex's Avatar
Joined Jan 2009
Yes , the one I used is 1.5mm wider then a stock T-600 belt .
This is done very easily with a cordless drill clamped to your bench and a dremel tool with a cut-off wheel, oh and a steady hand.
Old Sep 15, 2011, 08:12 PM
cap231ex is offline
cap231ex's Avatar
Joined Jan 2009
Tail length fixed
I ended up cutting 50mm off the tailboom and going with the 700XL belt for a mainshaft to tailshaft distance of 930mm . I also saved 60grs in weight by changing the metaltail gearbox and tail blade grips to plastic that should really help on the CG.
Old Sep 16, 2011, 06:11 AM
mrmj2u is offline
mrmj2u's Avatar
Joined Mar 2011
How are you running 8S on a Turnigy plush?
Old Sep 16, 2011, 07:11 AM
cap231ex is offline
cap231ex's Avatar
Joined Jan 2009
I'm not , it's two 6s 3000mah packs in parallel to give me a total of 6s (22.2v) 6000mah .
Old Sep 16, 2011, 07:16 AM
mrmj2u is offline
mrmj2u's Avatar
Joined Mar 2011
AAHHH Thanks for that clarification.
Old Sep 16, 2011, 09:47 PM
cap231ex is offline
cap231ex's Avatar
Joined Jan 2009
Canopy
Wanted a new look to the big old girl so I thought I would give her old blah canopy a makeover, I know it's not scale now but it's all leading up to that in time.
I started by wipeing it all down with rubbing alcohol , then brushing on some Dively's Liquid Masking Film over the windscreen area. Next sprayed it with Testers enamel yellow from a rattle can , after it cured out I than sprayed the cobalt blue from my airbrush. After a day I removed the masking film under warm water and dryed , installed RedBull decals and called it done.
Old Sep 19, 2011, 03:31 PM
cap231ex is offline
cap231ex's Avatar
Joined Jan 2009
Painted head
Finally got my head painted up , I think it looks a lot better in black. I went all though the head piece by piece and only found 1 bad bearing in one of the washout arms , replaced it and got things put back to gether . Now just waiting for the weather to clear up to give it a test flight and see how the new boom length and parts all work. I am interested to see if the Align gray rubber dampeners fixed the tracking problem too , as before the tracking would not stay fixed with the soft HK stock dampeners in the head. Untill the weather clears up and more testing can be done , here is some pics to tide you over.
Discussion Turnigy T600 880kv Delta to Wye help mattyhawk Electric Motor Design and Construction 34 Jul 09, 2011 08:04 AM
For Sale Turnigy T600-880KV motor helifrek Aircraft - Electric - Helis (FS/W) 2 May 20, 2011 09:29 PM
Sold *** Turnigy T600-1100Kv for Trex 600 *** Rudderman98 Aircraft - Electric - Helis (FS/W) 3 May 19, 2011 06:19 PM
Sold *** Turnigy T600-1100Kv for Trex 600 *** Rudderman98 Aircraft - Electric - Power Systems (FS/W) 4 May 19, 2011 06:14 PM
Discussion Quieting down a T600/T550 scaler with a Helical main gear SidewaysLS4 Scale Helicopters 2 May 02, 2011 06:00 AM
