Old Aug 12, 2011, 05:03 AM
Oblivion is offline
Find More Posts by Oblivion
Air, Land & Sea RC's.
Oblivion's Avatar
Australia, SA, Adelaide
Joined Nov 2008
need new motors for apparition twin drive
does anyone know where a guy can get replacement motors for the app twin drive?
theyre apparently 2881kv 380's.
prefer stock motors, or something with at least the same power on 3s thats a drop in
Oblivion is offline Find More Posts by Oblivion
Old Aug 12, 2011, 05:55 AM
F1 madness is offline
Find More Posts by F1 madness
F1 madness's Avatar
Staffs UK
Joined Feb 2010
What about a pr of leopard 2860
These will drop straight in and last alot longer than the originals,plenty of power & perfect for 3s
http://www.ebay.co.uk/itm/LEOPARD-Bo...item45fa98e968
These are cheaper here in the uk than the original motors and well worth the 's/$'s
F1 madness is offline Find More Posts by F1 madness
Old Aug 12, 2011, 06:43 AM
Oblivion is offline
Oblivion's Avatar
Joined Nov 2008
ah great, thanks for the link.
i found the same ones for sale on ebay aus.
ill give em a go, i dont know why the originals smoked though.
one lost power and the other cut out, both had a light wiff of smoke from them when i opened the canopy.
is the pin hole water pickup in the rudder an ok setup for water intake? (is it sufficient for the upgrade)
Old Aug 12, 2011, 06:47 AM
Oblivion is offline
Oblivion's Avatar
Joined Nov 2008
do you have any links or tips on how to swap my water cooling jacket onto the new motors? (or how to add water cooling)
Old Aug 12, 2011, 06:51 AM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
The cooling jackets are just a metal sleeve with an o-ring at each end, just pull them off carefully with a bit of wiggling. When you go to put them on the new motors grease the o-rings and watch the edges of the motor can so you don't tear the rings.
wparsons is offline Find More Posts by wparsons
Old Aug 12, 2011, 06:59 AM
Oblivion is offline
Oblivion's Avatar
Joined Nov 2008
awesome, thanks very much.
Old Aug 13, 2011, 05:18 PM
zanek is offline
Find More Posts by zanek
Agressive driver
United States, CA, Santa Barbara
Joined Jun 2011
Not sure what other motor you could use, maybe someone knows? But I WOULD NOT recommend Leopard http://radiocontrolinfo.com/forum/vi...c.php?f=6&t=18
zanek is offline Find More Posts by zanek
Old Aug 13, 2011, 05:32 PM
F1 madness's Avatar
Staffs UK
Joined Feb 2010
Zanek
Iv been running the leopard motors now for awhile and can say they are great motors
Old Aug 13, 2011, 06:13 PM
zanek is offline
Agressive driver
Joined Jun 2011
Originally Posted by F1 madness View Post
Zanek
okay. Maybe that one was just defective
Old Aug 13, 2011, 07:37 PM
Oblivion is offline
Oblivion's Avatar
Joined Nov 2008
i done some crude approximate figures on the specs, seems like it'll perform better than the stock ones did on 3s.
original motors
2881kv X 11.1v = 31979 rpm
and i got a watts up reading of i think 601w @ 62a peak. (in a run)
leopard 2730kv @ 11.1v = 30303 rpm
if theyre 1300w on 5s (-approx 260w per cell) i should get approx 780w on 3s
(ballpark figures, of course)
= 1676rpm loss with the leopards (@ no load), but a ~180w gain in power
and since ill be running 3s on a motor thats capable of 5s, it shouldnt get even slightly hot since its nowhere near peak loads/output
Old Aug 14, 2011, 03:57 AM
F1 madness's Avatar
Staffs UK
Joined Feb 2010
1 or 2 bad motors in the 100's they produce theres always gonna be a defective 1 somewhere.
But did you search feigao's,iv read lots of storys of them throwing magnets & bearings but you still brought 1.
end of the day anything you buy could be defective thats what happens in mass production,but it doesnt mean there all bad.
Old Aug 14, 2011, 03:59 AM
F1 madness's Avatar
Staffs UK
Joined Feb 2010
original motors
Also youll find these have alot more torque so youll be able to spin larger props than what you spinning so youll gain speed.
Old Aug 14, 2011, 05:07 AM
Oblivion is offline
Oblivion's Avatar
Joined Nov 2008
what about the 2860 2910kv.
it seems virtually identical in specs except the 2910kv is a measly 30kv higher than the stock 2881kv.
i can get the 2910' locally, the 2730kv i'd have to order off ebay.
(4th down) http://www.leopardhobby.com/product/...ionID=01020204
Old Aug 14, 2011, 05:29 AM
F1 madness's Avatar
Staffs UK
Joined Feb 2010
Yep they do aswell just keep prop size down to start with.
What props were you running or have got???????
Old Aug 14, 2011, 05:31 AM
Oblivion is offline
Oblivion's Avatar
Joined Nov 2008
stock copper props, tfl 435's i think
Discussion Apparition Twin Hull, Twin motor offshore boat Oblivion Racing Boats - Electric 107 Dec 30, 2014 09:53 AM
Question Apparition flex drive HELP PLEASE quadman77 Racing Boats - Electric 2 Jul 20, 2011 06:10 AM
Sold Anthem Metal Products Twin Motor Gear Drive .40 Equivalent w/twin Green ROAR motors ALL American Aircraft - Electric - Power Systems (FS/W) 2 Dec 09, 2010 05:18 PM
Discussion Apparition Twin motor ramtornado Racing Boats - Electric 0 Jul 17, 2010 09:12 AM
For Sale Lot of 10 new EDP 300H direct drive brushed motors. 10 motors for $15 shipped. DrDHalko Aircraft - Electric - Power Systems (FS/W) 1 Jan 26, 2007 11:58 AM
