Old Sep 07, 2003, 11:57 PM
King Kong is offline
Find More Posts by King Kong
King Kong's Avatar
los alamitos ca
Joined Jun 2001
What are the best servos?
I'm building a rudder elivator dlg, and I'm curious what are the best servos to use. I plan to use a pull pull system if it matters.
King Kong is offline Find More Posts by King Kong
Old Sep 08, 2003, 05:05 PM
John Gallagher is offline
Find More Posts by John Gallagher
John Gallagher's Avatar
Lindenwold, NJ, USA
Joined Dec 2000
A lot of people consider the JR241 servo to be very good if not the best. A while back someone did a test on sub-miniture servos and the 241 had supperior centering - something very important for a DLG. Things change quickly in this hobby, so there might be a better one now, but both Polecat aero (XP-3) and the Taboo manufacturer recommends jr241's.
I use hs55's in my Avenger and like the servo although it doesn't center well.
John
John Gallagher is offline Find More Posts by John Gallagher
Old Sep 13, 2003, 07:49 PM
LWThompson is offline
Find More Posts by LWThompson
Senior Member
LWThompson's Avatar
Nashville, TN USA
Joined Jun 2002
What John Said
I agree with John. I use a variety of servos. Some are HiTec, some Cirrus, some GWS, some Dymond and some JR.
You will want to match servo specifications to your criteria. A few questions to ask would be...
How important is servo centering?
How important is having ball bearings?
How much current does it draw idle; while moving?
How much torque do I need for each surface?
Do I want to standardize on one servo?
How big is my battery?
How much will the RX draw?
Is there a gyro involved?
Also check out the micro servo thread in this section.
LWThompson is offline Find More Posts by LWThompson
Old Nov 13, 2003, 09:47 PM
AustinTatious is offline
Find More Posts by AustinTatious
AustinTatious
AustinTatious's Avatar
Hurst, Texas, United States
Joined Jul 2003
I woudl suggest the CS 4.9 gram servos... They have a lot of torque for their size. I use them on my rudder and elevator on an ENIGMA DLG. I use 6.4's in the wings. Great little servos AND LIGHT!! pretty cheap too. 18 bucks for 6.2's and 24 for 4.9's If you want save the 12 dollars and weight a whole gram more.. hehe
AustinTatious is offline Find More Posts by AustinTatious
What are linear servos? JStory Electric Plane Talk 28 Oct 10, 2010 12:10 PM
Question What are the best planes for beginners? rick2048 Beginner Training Area (Aircraft-Electric) 23 Jul 21, 2009 07:05 PM
What are the best micro servos? Pork Tornado Parkflyers 35 Nov 04, 2008 04:17 PM
Discussion What are the best servos to replace the stock ones (HB CP2), I mean plug and play sebasneumann Micro Helis 2 Jul 09, 2006 12:51 PM
What are the best micro servos for this plane bmaaa Electric Ducted Fan Jet Talk 1 Aug 22, 2005 05:21 PM
