Old Aug 11, 2011, 06:25 PM
leaky bill is offline
Find More Posts by leaky bill
leaky bill
Parksville BC
Joined Jul 2007
Help!
Johnson 550 motors ?
I would appreciate hearing from someone with experience running
John son 550 motors.
I am building a 37 inch fast patrol boat and plan on installing two Johnson 550 motors, I believe the motors are designed for a 6 volt system
Questions
1. Will I burn out the motors running on 12 volts ?
2. Which ESC should I use, I am planning on a proboat 40 amp ESC but
do not know if that ESC is compatible for a 6 volt system...will it support the load from these motors ?
My boat will be a very light GRP hull with a 5ah SLA battery for power and ballast.
TIA
Leaky Bill(ge)
leaky bill is offline Find More Posts by leaky bill
Old Aug 11, 2011, 06:50 PM
coriolan is offline
Find More Posts by coriolan
"Unnecessary Necessity"
coriolan's Avatar
Canada
Joined Sep 2006
Johnson 550 don't draw very much and two should be Ok on a 40 Amps ProBoat esc and 12V as long as not overproped or use a geardrive reduction(best). If they really have a winding for 6V only you can alway feed them in serie from the esc, each will see only 6V and the Amp draw will remain the same. Most of these Johnson/Mabuchi motors don't have a fixed voltage rating, the only limit is the total Watts through the armature which depend on the load.
coriolan is offline Find More Posts by coriolan
Old Aug 11, 2011, 06:52 PM
Tachikaze is offline
Find More Posts by Tachikaze
太刀風
Tachikaze's Avatar
United States, OR, Eugene
Joined Jan 2003
Johnson makes several motors. My Springer runs on a Johnson 550 that is 6v. My Japanese DD runs on 12v with a completely different Johnson 550. The 550 refers to the cannister size of the motor.
If when you turn the shaft of the motor, and you feel it pull firmly through the magnets or if you can barely turn it with your fingers, I would recommend not running it on 12v.
Without playing with the motor, and if there are not markings on it, one can only really tell by hooking it up to power. Hook it up to 6v, it run like crazy? If so, then do not be using 12v.
Tachikaze is offline Find More Posts by Tachikaze
Old Aug 11, 2011, 08:11 PM
420TEE is offline
Find More Posts by 420TEE
North Central TN USA
Joined May 2006
A problem with series connections is if one motor gets bound up by say, seaweed, the second motor grabs all the power and smoke usually results.
420TEE is offline Find More Posts by 420TEE
Old Aug 12, 2011, 12:34 PM
leaky bill
Parksville BC
Joined Jul 2007
Thanks for your replies
I will install the 550 motors using a 6 volt 5ah SLA battery...I am confident
that the model will perform well on a pond with 6 volts...however the only info I can find on the Proboat 40 amp ESC is reference to brushless motors...
Can a ESC designed for brushless motors be used for brushed motors with no
risk ?
TIA
Leaky Bill(ge )
Old Aug 12, 2011, 01:32 PM
RGinCanada is offline
Find More Posts by RGinCanada
Tinkerer in Training
RGinCanada's Avatar
Guelph, ON
Joined Sep 2004
No, you will need a brushed motor ESC.
I am pretty sure that this Proboat 40A ESC is for brushed motors.
RGinCanada is offline Find More Posts by RGinCanada
Old Aug 12, 2011, 06:12 PM
nick_75au is online now
Find More Posts by nick_75au
NeverAgainVolunteerYourse lf
nick_75au's Avatar
Australia, QLD, Regents Park
Joined Mar 2007
Not quite true, It depends on the ESC, some of the brand name ESC's like Tekin and Novak have brushed and brush-less modes, 99% of brushless ESC's are brushless only.
They seem like a waste of money to me though
The Pro-boat linked is definitely brushed motor only
Nick
Etc
http://www.teamnovak.com/products/esc/gtb/index.html
http://www.amainhobbies.com/product_...-Brushless-ESC
nick_75au is online now Find More Posts by nick_75au
Old Aug 12, 2011, 10:20 PM
boaterguy is offline
Find More Posts by boaterguy
Thermite + ice = Big boom.
boaterguy's Avatar
Canada, ON, Ottawa
Joined Apr 2009
unless specified, A brushless ESC is for brushless only.
boaterguy is offline Find More Posts by boaterguy
Old Aug 13, 2011, 02:03 PM
mfr02 is online now
Find More Posts by mfr02
Blackpool, Lancs
Joined Feb 2006
If a boat is wanted to be fast, a lightweight hull is great. Ballast isn't. Add more lightness.
Lead acid is not the best for performance, despite there having been reasonable examples. Think NiMH or Lithium batteries for performance and good run times for a given weight.
mfr02 is online now Find More Posts by mfr02
Old Aug 13, 2011, 09:09 PM
coriolan is offline
coriolan's Avatar
Canada
Joined Sep 2006
A "fast scale boat" isn't a fast electric racing boat, patrol boat are not planning hull but displacement hull and would look ridiculous zooming around (which a 37" scale hull powered with 550 size motors cannot do anyway). I have seen relatively fast scale boats around that size powered with brushed Astroflight-40 and 12V/7amp gel cell.
Old Aug 14, 2011, 09:38 AM
boater_dave is offline
Find More Posts by boater_dave
Big Boats Rule!
boater_dave's Avatar
Wisconsin
Joined Jun 2007
The same question comes up often. A gel cell is not the best choice when the load is going to be more than an amp or two. The problem is that of heat dissipation. The life span of the battery will be cut short as the internal plates will be damaged. Only AGM (absorbed glass mat) or wet flooded lead batteries are capable of dischagrging at useful levels.
If you are going to draw more than an amp or two, NiCad/NiNmh or Lipo are much better suited. And they can be charged pond side for even longer runs. If your motors were made for 6 volt there should be no problem running them on 7.2 volts (6 cell NiXXX).
Do you know what the total amp draw is for your motor/prop combination?
Dave
boater_dave is offline Find More Posts by boater_dave
Old Aug 14, 2011, 12:57 PM
ZZ56 is offline
Find More Posts by ZZ56
Nickel Belter
ZZ56's Avatar
Canada, MB, Winnipeg
Joined Jun 2009
Dave
idonwanna start a fight, but a co-worker says gel-cells are fine up to their amp-hour rating but not beyond, and he's an electrician with 30 years experience.
Me, I've seen so many fine scale boats using your standard Yesa and Yuasa and Panasonic gel cells and not one owner reported killing their batteries after a hard run. What kind of damage are we talking about, a total loss of charge or a gradual decline in performance?
ZZ56 is offline Find More Posts by ZZ56
Old Aug 14, 2011, 03:43 PM
leaky bill
Parksville BC
Joined Jul 2007
i have been sailing my 72 inch destroyer for the past 5 years, no problems running 2 x 12 volt 755 from a single 7ah SLA, normally my sailing sessions are over an hour...so will go with a 5ah SLA for my 37 inch patrol boat with displacement hull. The SLA battery should provide all the ballast I will need...
I will use 6 volt SLA battery...if that does not provide the speed I am
looking for, may try 12 volt, at some risk of course.
Thanks for the interest in this project
see my models on
www.freelanceboats.blogspot.com
Leaky Bill
Old Aug 14, 2011, 11:58 PM
coriolan is offline
coriolan's Avatar
Canada
Joined Sep 2006
Nice build Bill!
Old Aug 15, 2011, 10:28 AM
Big Boats Rule!
Wisconsin
Joined Jun 2007
My comment on gel cells is about amp load. The damage comes from overheating the internal structure if too many amps are drawn from the battery. Overcharging causes the same issues. The typical damage is the battery will no longer hold a charge, so I guess you could say poor performance is the result. All of the examples everyone posted in with are just what I said in my post. If the load is only a few amps you should be fine. And the bigger the battery, the better it can handle the heat. Also the running style. Do you run at high speeds for a long time, or only short bursts. The original post said fast-ish boat on a pair of 550 can motors.
Go to any battery store, or website, and read the FAQ section on SLA/gel type batteries for this info. These batteries are best suited for smaller discharge rates and long term storage of power. NiCad and Nimh are good for dischage amps, but will self discharge at about 5-10 percent per day so they make lousy storage batteries. Lipo are great at both discharge and storage.
My 5 minute Google search found this site which has a nice combination of info and tech specs.
http://homepages.which.net/~paul.hil...eriesBody.html
It looks like the C rating is always fractional, even as low as 1/5 capacity of the battery itself. My question would be at what rate do you charge your battery? That should be close to the optimum discharge rate as well.
Dave
Wanted Storm Launcher replacement motors DCM-189 (Johnson J 250) mastaswitch Aircraft - Electric - Batteries & Chargers (FS/W) 1 Dec 23, 2011 11:12 AM
Discussion What ESC to use with two 550 motors proteque Scale Boats 14 Jun 15, 2011 07:13 AM
Help! Flying Field Johnson City TX Ken Smith USA - District VIII 0 Apr 17, 2011 06:49 PM
Sold 13 New Brushed Johnson 550 motors************ Lammergier Aircraft - Electric - Power Systems (FS/W) 0 Aug 04, 2008 01:17 PM
FS: Johnson motors w/ props (2), Speed 300 motors (2), Electrifly C-10 ESC kyril Aircraft - Electric - Airplanes (FS/W) 1 Apr 26, 2004 09:10 PM
