Old Sep 09, 2011, 07:08 PM
swimmer is offline
Find More Posts by swimmer
AMA 1042906
swimmer's Avatar
United States, KS, Derby
Joined Mar 2008
Originally Posted by mitsudriver274 View Post
That is interesting, I used the orange wire haha if you look in my pictures you can see the colors are different.
I believe if you look at the back of the board it will be labeled -+& signal
Is there any programming to the AR6400 to get all to operate correctly or once all wires connected correctly and powered on it all works?
Allan
swimmer is offline Find More Posts by swimmer
Old Sep 09, 2011, 07:33 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Allan
You need to use stick logic to change the brick to external ESC mode.
Bind rx to tx
unplug rx battery
hold thottle stick northwest
plug battery into rx
rx flashes 3 times
brushed motor will run constant if plugged into brick.
See AR6400 manual for details.
UNGN is offline Find More Posts by UNGN
Old Sep 09, 2011, 07:54 PM
swimmer is offline
AMA 1042906
swimmer's Avatar
Joined Mar 2008
Bind rx to tx
unplug rx battery
rx flashes 3 times
Do these instructions apply to my DX6i?
This appears to be much easier than a lot of other things I have read. I'll be ready to complete my upgrade tomorrow and your instructions is what I needed. Also found it in the manual.
Allan
Old Sep 09, 2011, 09:14 PM
micro_builder is offline
Find More Posts by micro_builder
micro_builder's Avatar
United States, MN, Corcoran
Joined Jan 2005
The emax 7amp will not work with 3s voltage, the 10 will work but very heavy at 8.5 grams.
The turnigy plush 6amp will work but is not warrantied under 3s operation.
I have had faulty fiego units sent to me for other builds.
Honestly from experience spend the extra coin on the castle creation esc, they claim it weighs 3.96g mine came in a little over 5 with wiring connectors. I have also dealt with castle creations customer support and I can say they rock.
True, no warranty coverage, but for the price of one Thunderbird 6A, I can get three Plush 6As! CC does put out a good product though.
Nick
micro_builder is offline Find More Posts by micro_builder
Old Sep 09, 2011, 09:21 PM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Allan
The only hard part is plugging the the RX battery while holding the throtttle stick "just right". Its good to rig a rubber band to hold the Throttle stick for you and use 2 hands to plug in the battery.
Old Sep 10, 2011, 11:48 AM
mitsudriver274 is offline
Find More Posts by mitsudriver274
Joined Jul 2009
Holding the sticks is the hardest part, I just have someone else hold the sticks. If you have problems getting the board to switch to brushless mode, reset the model in your tx and rebind.
mitsudriver274 is offline Find More Posts by mitsudriver274
Old Sep 10, 2011, 06:54 PM
swimmer is offline
AMA 1042906
swimmer's Avatar
Joined Mar 2008
Got all the wiring complete. Tried a number of times but cannot get the board to switch to brushless. AR6400 does not flash but stays steady. Used UNGN's instructions but no joy. Rebinded the DX6I to the AR6400 and still won't switch.
Do I have to use a stock TX to make the brushed to brushless mode? Been trying to make change with my DX6i.
Allan
Old Sep 10, 2011, 09:04 PM
rx7weee is offline
Find More Posts by rx7weee
Full size pilot
USA, WA, Bellingham
Joined Dec 2009
Try moving the throttle/rudder trims one way or another to get it to bind.
rx7weee is offline Find More Posts by rx7weee
Old Sep 10, 2011, 09:45 PM
swimmer is offline
AMA 1042906
swimmer's Avatar
Joined Mar 2008
It Works!!!!
Went to a clean model memory on my DX6i. Switched to brushless the first time. Of course, motor was running backward but a little soldering took care of that and everything works perfect.
Thanks you all for your suggestions.
Allan
Old Sep 10, 2011, 10:22 PM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Yes a clean model memory is important. I use a RTF TX to switch any of my bricks. (that's about the only thing I use it for)
Old Feb 06, 2012, 04:56 AM
stalyoni is offline
Find More Posts by stalyoni
high flyer
stalyoni's Avatar
Australia, WA, Geraldton
Joined May 2008
Im also planning my own 3s micro project. The guys over on the umx sbach thread where starting to use a 3s on there umx sbach so I decided to give it a try. Well long story short it stuffed the brick by plugging it in. Theres only 2 people who have run a 3s in the umx sbach sucessfully (still no proof really).
So anyways ive decided to run seperates. As the sbach uses a rx/esc brick with no servos so it makes it easy to replace.
This will be my umx sbach 3s setup:
I have ordered a turnigy plush 10a esc @ 9 grams
hobbyking 6ch (orange rx) @ 4 grams (without the shell)
Hyperion 240mah 3s @ 26g
UM stryker 180 3000kv motor or UM sbach 180 2500kv @ 7grams
stock brick 7g + stock lipo 12g = 19g
VS
hobbyking 6ch rx 4g + 10a esc 9g + cables 1g + 3s hyp 26g = 40g for 3s
VS
hobbyking 6ch rx 4g + 10a esc 9g + cables 1g + 2s zippy 180 15g = 29g for 2s
So for the 3s setup it will be carrying an extra 21g
and for the 2s setup it will be carrying an extra 10g
I have ordered these cables to hook up all the stock servos:
http://micronradiocontrol.co.uk/conn_jstsh.html
JST-SH Extension Leads
I will use the female part of the lead and then probably use a JR connector the other end or just hard wire it to the HK 6ch RX. I will probably end up with a 1gram or two grams in weight with the cables.
Not sure what motor I will use yet. The 2500kv or 3000kv. I will have a 4540, 5275, 5030 and 5043 props to choose from. I will have to run some tests when I get it all setup.
Im hoping I can make my cable adaptors long enough and put the esc up in the tail of the plane. Hopefully the added weight will balance out.
Anwyays im still waiting on parts (2 weeks) but heres a picture with my hyperion 240mah 3s and HK 6ch RX in the middle (think ill put the esc there)
Do you think the UM stryker 180 3000kv motor will be ok on a 3s?
What would be a better motor then this rather then the AEO C10 2100kv?
stalyoni is offline Find More Posts by stalyoni
Old Feb 06, 2012, 02:36 PM
brushless55 is offline
Find More Posts by brushless55
big ignore list
brushless55's Avatar
United States, CO, Longmont
Joined Nov 2011
Proof?
what proof do you want??
brushless55 is offline Find More Posts by brushless55
Old Feb 08, 2012, 06:14 AM
stalyoni is offline
high flyer
stalyoni's Avatar
Joined May 2008
Originally Posted by brushless55 View Post
Proof?
heres all the proof you need buddy
I finally did the 3s mod today. I decided to just cut off the micro jst connectors and solder up the JR connectors to the servos rather than use the micron adapters that I ordered. I figured this would save some weight. It took allot of work, time and frustration but I got it done.
I decided to cut into the top section of the cockpit and mount the RX up in there. I was really running out of room for everything. I mounted the turnigy 10a esc where the stock brick was. I used some cable ties to tidy up the wiring.
As you can see from the picture I cut allot of foam out from behind the battery bay. This will allow me to move the lipo futher back to gain CG. I added some velcro into the battery bay to secure the lipos.
I am using the stock 2500kv motor and stock sbach prop for now.
I took it to the park and I first ran it on a 2s zippy 180 lipo to see if it would fly ok. I then had a second flight and moved the lipo all the way to the front and the CG was much better. It was very windy but I wanted to test it on a 3s.
So I mounted the 3s lipo. Had it a little back from the front. Launched the plane and it has amazing power now. At just about a 1/4 throttle it was almost as fast as it was on a 2s. It takes a while to wind up to top speed but once it gets there its super fast. I only had about a minute and a half run with it before I decided to land it due to the wind. I took the hatch off and the motor wasnt that hot at all.
umx sbach on a 3s 11.1v lipo 2500kv stock prop (2 min 20 sec)
Sorry about the poor quality video but it was windy and overcast and I had it on the wrong setting. Watch it in 720p full screen.
The plane now weighs 65 grams without a lipo
The total flying weight with a 3s (hyp 240) is about 91grams
The total flying weight with a 2s (zip 180) is about 79grams
I might have to try the 3000kv motor on the 3s next time or maybe a 5030 on the 2500kv.
Anyways ive got it up and flying again and it didnt cost me $70 for a new brick. The plane will be much quicker and reliable now.
Im just having problems with my throttle response with the turnigy plush 10a esc. Its very slow to react. Any ideas what this could be please guys?
Old Feb 08, 2012, 11:31 AM
big ignore list
Joined Nov 2011
[QUOTE=stalyoni;20656820] (still no proof really).
[QUOTE]
Proof?
Uh hello??
I was not looking for proof..
I have a sweet Sbach on 3s and it rips!
Old Feb 08, 2012, 03:52 PM
johnkielsen is online now
Find More Posts by johnkielsen
COPENHAGEN DENMARK
Joined Aug 2007
I want to see some pictures or a video.
John
johnkielsen is online now Find More Posts by johnkielsen
Wanted CF UM Project: Sell me your UM Sukhoi and P-51 airframes, wings, etc! S.R.G. Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Mar 06, 2011 09:33 AM
Discussion lead glider - original lead sled? Phil.Taylor Slope 2 Nov 27, 2007 06:06 PM
Lead Sled Alley - December 2002 dave_lilley Slope 9 Jan 07, 2003 10:38 AM
Lead Sled Alley - December 2002 dave_lilley Sailplane Talk 0 Dec 31, 2002 01:13 PM
