Old Aug 27, 2011, 12:01 PM
Ron van Sommeren is offline
Find More Posts by Ron van Sommeren
homo ludens modellisticus
Ron van Sommeren's Avatar
Netherlands, GE, Nijmegen
Joined Feb 2001
Originally Posted by BoomStriker View Post
Thanks. I must be getting old, Louis and Christo too, but mostly me
http://groups.yahoo.com/group/lrk-to.../message/12138
http://www.rcgroups.com/forums/showthread.php?t=1011712
Originally Posted by Skylar View Post
I think that it's very fitting to mention here where the SPS (LRK) winding scheme comes from. ...
See also
http://www.aerodesign.de/peter/2001/...0_Wroclaw.html
Vriendelijke groeten Ron
diy motor tipsDrive Calculator
diy motor groupCumulus MFC
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old Aug 27, 2011, 02:07 PM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
Jack
I've added the meaning of SPS to the first post - for the benefit of new readers of this thread. Thanks for pointing this out.
Christo
I've been lurking on the thread because it is interesting, I didn't mean criticize you for not have explained a term that everyone else seemed to understand.
But I'm sure other lurkers and future readers will be smarter for you having added it. Thanks for doing it.
Jack
jackerbes is offline Find More Posts by jackerbes
Old Aug 28, 2011, 08:13 AM
Skylar is offline
Find More Posts by Skylar
我爱飞行 . . . I love flying
Skylar's Avatar
South Africa, GP, Pretoria
Joined Jul 2003
Emetor Kv
Hi Louis
I assume you managed to sort out the input errors in Emetor.
Do perhaps know how one can calculate or otherwise determine the Kv of a design in Emetor. I don't think they give Kv in the results.
Christo
Skylar is offline Find More Posts by Skylar
Old Aug 28, 2011, 12:53 PM
Fourdan is offline
Find More Posts by Fourdan
Fourdan's Avatar
Antony (France)
Joined Sep 2003
Hi Louis
Christo
Hi Christo
Presently I am busy in testing a lot of motors (Dualsky EA series)
Could be 2 weeks to recover some time to learn Emetor
Louis
Fourdan is offline Find More Posts by Fourdan
Old Aug 29, 2011, 04:34 AM
Skylar is offline
Skylar's Avatar
Joined Jul 2003
No problem Louis
It should be possible to calculate Kv using the torque constant, Kt (Nm/A) which is equal to Ke (generator constant) V/(rad/sec).
Good luck with your motor testing.
Christo
Old Aug 31, 2011, 04:07 PM
Christian Lucas is offline
Find More Posts by Christian Lucas
Germany, BY, Gräfelfing
Joined Jan 2003
Hi,
Intresting discusion.
Powerst kV with SPS Windung As all Wind of a Phase will See magnetic flux at the Same Time .dLRK has the Windung of a Phase on naberhod teeth where the magnetic flux has a Time Delay wirft result in a lower Induction but wirft a more rectangular Design .The Design of SPS has longer endturns by Windung the Same Count of turn As with dLRK witch result in litle higher coil résistance belobt to the lenght of the stator.
Christo:if you would like the Best you have to Wind two separate LRK or SPS motors on One Stator .First from tooth 1,3,5,7,9,11 the Second start from teeth 2,4,6,8,10,12 for a 12N stator.
The Windung Factor says how good ist the Windung used to produce magnetic Force As higher the Number As better .
some wordes spell silly but i wrote this with a ipad witch correct me with german dictionary,crasy thing.
happy amps Christian
Christian Lucas is offline Find More Posts by Christian Lucas
Old Aug 31, 2011, 04:40 PM
Skylar is offline
Skylar's Avatar
Joined Jul 2003
Hi Christian
OK, this concept is new to me. How should the 2 windings be terminated? Joined as for one motor or separately as for 2 motors and connected to 2 speed controllers?
Don't worry, I understand you perfectly. Thanks for the advice.
Gruss
Christo
Old Aug 31, 2011, 05:43 PM
Joined Jan 2003
Yes,correct ,two controler.It is than a real 6 phase motor.The SPS is like a semi 6 phase with the 3 phase using the 6 phase magnetsystem.
Best over all is to use a 2 phase controler for each coil. example 11 slot 12 Pole using 11 2 phase controler. Siemens does it in the German Fuelcell powered Submarine.
Old Dec 09, 2012, 04:49 AM
WimH is offline
Find More Posts by WimH
WimH's Avatar
Belgium, Flemish Region, Oosterzele
Joined Dec 2001
Hi All,
I intend to try the " 2 LRK motors on one stator with 2 controllers" approach. I'm not sure how to get a similar motor to my DD LRK though. Both motors are Scorpion S4020 12N 14P kits, the "original" LRK has 14 turns/Tooth, but coils are in parallel, not in series, about 1000RPM/V. Not sure how to achieve the same easily with 2 LRK motors...I want to see if there's a noticeable difference...
Wanted to do this a long time, I now have 2 identical YGE 100A controllers that should be ok with this config.
WimH is offline Find More Posts by WimH
Old Dec 09, 2012, 06:01 AM
Skylar is offline
Skylar's Avatar
Joined Jul 2003
Originally Posted by WimH View Post
Hi All,
Hi Wim
I'd be interested in the results. Please post it here when you've succeeded.
Groetjes
Christo
Old Dec 23, 2012, 05:00 AM
Joined Feb 2001
Hi Wim, I'd be interested in the results. ...
Keep an eye on this thread Christo
www.modelbouwforum.nl/.....scorpion-hk3026-hk4225-hk4020-hk4025-hk4035-buitenloper-wikkelen-42.html#post2804304
And Ralph is up to it again, iron-cobalt core
http://www.helifreak.com/showthread.php?t=481901
Met vriendelike groete Ron
Old Dec 23, 2012, 07:14 AM
WimH is offline
WimH's Avatar
Joined Dec 2001
ah , yes, forgot Skylar is from South Africa and might understand Dutch
hmm, cobalt lams were given to me by Christian Lucas once, Ralph got them in the end after Torcman butchered them up a bit, I wonder if they are the same...
Old Dec 23, 2012, 04:57 PM
Joined Jan 2003
Hello Wim,
my Holländisch is not that good ,i understand nothing .But nice to read from you.
Sorry Wim , plates are from unknowen distributor
Ron, Wim and all motorwire enthusiast worldwide.
I wish you a merry xmas .let wish come true build your owen engine.
Old Dec 25, 2012, 11:46 AM
WimH is offline
WimH's Avatar
Joined Dec 2001
Hi Christian, Merry Christmas to you and your family as wel. Basically I'm trying to (have somebody) build 2 nearly identical 1000KV Scorpion 4020 14p LRK motors, one 'true' LRK with 14 turns per tooth, DD connection (to replace my damaged selfwound 13 turns LRK) and the same motor , but 7 turns/tooth LRK*2 on 2 separate YGE100 controllers, to see if the difference is noticeable.
Wim
Old Dec 29, 2012, 05:01 AM
WimH is offline
WimH's Avatar
Joined Dec 2001
This is the last "news" I got from the "rewinder" :
about 21.5mm2 copper fill, not bad at all...
Discussion Valid LRK wind? fly_boy99 Electric Motor Design and Construction 72 Jul 02, 2009 11:11 PM
Discussion Wind on LRK Geoff Woodward Electric Motor Design and Construction 41 Apr 27, 2007 09:27 AM
Discussion 6 stator tooth LRK wind? rcnutt Electric Motor Design and Construction 4 Apr 03, 2006 08:48 AM
LRK wind help requested please Rocketman209 Power Systems 6 Dec 06, 2005 11:40 AM
