Old Aug 26, 2011, 04:53 PM
Skylar is offline
Find More Posts by Skylar
我爱飞行 . . . I love flying
Skylar's Avatar
South Africa, GP, Pretoria
Joined Jul 2003
Originally Posted by Ron van Sommeren View Post
I have not played that much with it. The tool (advanced) gives some numbers, I don't understand all of them though. Maybe you can figure out their meaning?
Hi Ron
I'm glad you mentioned the improved winding diagram 'calculator' again. That prompted me to have another look at it.
It gives a number that's called "winding factor". I'm not sure what this means, but by clicking on "advanced", one can input values like "stator diameter", "slot opening" and interestingly, the amount of "skewing". By ticking the "into the table" tickbox, it recalculates the mysterious "winding factor" value.
From what I've seen, the advanced function could be very handy for verifying LRK design layout, because the "winding factor" bars in the graph are high only for the "legal" magnet pole numbers if number of slots and poles comply with the LRK rules. I like this new tool !!
Also, the higher the skewing number, the lower the "winding factor" number. I wish someone would explain what it means.
Christo
Skylar is offline Find More Posts by Skylar
Old Aug 26, 2011, 05:03 PM
Fourdan is offline
Find More Posts by Fourdan
Fourdan's Avatar
Antony (France)
Joined Sep 2003
Originally Posted by Skylar View Post
Hi Louis
You mentioned some valid points.
a) Phase relationship. So a poorly constructed/designed motor with varying stator teeth width or irregular magnet spacing could still work well as a generator. Very interesting.
Christo
Hi Christo
If you rectify for DC use (to load a battery) ..
phase relation-ship is not important
(for example if you have 0, 60 deg, 120 deg instead of 0, -120 deg, 120 deg
it is not important for a generator)
BUT amplitude of BEMF (V/rpm) is important
So a bad design or an error on the phases windings in serial is not a good thing. And there is a "merit factor" for every configuration.
I have the simulation software (my secret !!) to analyze that (copper distribution and magnets distribution)
dLRK or LRK are very close together (as for merit factor)
Louis
Fourdan is offline Find More Posts by Fourdan
Old Aug 26, 2011, 07:50 PM
Ron van Sommeren is offline
Find More Posts by Ron van Sommeren
homo ludens modellisticus
Ron van Sommeren's Avatar
Netherlands, GE, Nijmegen
Joined Feb 2001
... I wish someone would explain what it means.
On that page you'll find that Felix Niessen is the author. The link points to his company website.
Prettig weekend Ron
diy motor tipsDrive Calculator
diy motor groupCumulus MFC
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old Aug 26, 2011, 11:36 PM
BoomStriker is offline
Find More Posts by BoomStriker
Joined Sep 2010
I found this: http://www.emetor.com/manual/glossary/winding-factor/
Don't make sense to me. But I bet it does for you guys.
BoomStriker is offline Find More Posts by BoomStriker
Old Aug 27, 2011, 03:39 AM
Fourdan is offline
Fourdan's Avatar
Antony (France)
Joined Sep 2003
Originally Posted by modisc View Post
Designing a motor is a very sophisticated work. Simply try wiring on commercially purchased, or "hardware" fixed models, is a good start anyway. Im not specialized in this area, actually, my profession is not even close to RC. But to me, motors are just like human body, a lot to explore and a lot to think, yet a lot to fix.
Hi Modisc
I agree with your posts #24 and #25
12N8P is also a very good config, however there are some "distorsions" BEMF waveform (some speaks about harmonics).
I am a fan of Fourier analysis but in this case I prefer to think in the time domain and the Lorentz forces when rotor is rotating in regard of current conductors distribution.
I have to add that there is a lot to do in ESC algorithms to get the best time instants to commute phase sub cycles. Also a sophisticated task.
Louis
Old Aug 27, 2011, 04:10 AM
Skylar is offline
Skylar's Avatar
Joined Jul 2003
Originally Posted by BoomStriker View Post
Hi BoomStriker
Thanks for the link. That website is very informative and useful, especially the online motor design program Emetor.
Christo
Old Aug 27, 2011, 05:03 AM
Fourdan is offline
Fourdan's Avatar
Antony (France)
Joined Sep 2003
Hi BoomStriker
Christo
Hi Christo
Did you succeed to input all parameters without one "error"
If yes what are all your data ? (file ?)
Louis
Old Aug 27, 2011, 05:18 AM
Skylar is offline
Skylar's Avatar
Joined Jul 2003
Hi Louis
At first I kept on getting a "Tooth width is too large - error", then I changed to "Concentrated winding" and it worked without any errors. Apparently, "Distributed winding" means something different to them.
If you still don't succeed, let me know and I'll e-mail you my file.
Christo
Old Aug 27, 2011, 05:29 AM
Skylar is offline
Skylar's Avatar
Joined Jul 2003
Emetor
Louis
Once you've selected "Concentrated winding", "2 layers" means dLRK and "1 layer" is LRK.
Christo
Old Aug 27, 2011, 06:01 AM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
This is a step backwards from the level of the conversation here but I finally figured out what "SPS" stands for,
"..Lucas, Retzbach and Kühfuss (LRK) motors, also known as Split Phase Sector (SPS) motors..."
http://www.femm.info/wiki/LRKAnalysis
That is a pretty attractive set of pages there.
Jack
jackerbes is offline Find More Posts by jackerbes
Old Aug 27, 2011, 06:44 AM
Skylar is offline
Skylar's Avatar
Joined Jul 2003
Originally Posted by jackerbes View Post
... I finally figured out what "SPS" stands for.
Jack
I've added the meaning of SPS to the first post - for the benefit of new readers of this thread. Thanks for pointing this out.
Christo
Old Aug 27, 2011, 06:56 AM
Skylar is offline
Skylar's Avatar
Joined Jul 2003
The origin of SPS (LRK)
I think that it's very fitting to mention here where the SPS (LRK) winding scheme comes from. We know LRK stands for Lucas, Retzbach and Kühfuss, the 3 guys who popularized the outrunner motor as we know it.
In this post Christian Lucas gives credit to Zelinski and Schoep from Poland who used it in big, slow-running alternators powered by water or windmills.
Christo
Old Aug 27, 2011, 08:00 AM
modisc is offline
Find More Posts by modisc
Inspiration
modisc's Avatar
United States, MI, Ann Arbor
Joined Aug 2011
Originally Posted by Fourdan View Post
Hi Modisc
Louis
I assume there will be more distortions in 12N4P and 12N2P? How about 12N16P?
modisc is offline Find More Posts by modisc
Old Aug 27, 2011, 09:21 AM
Fourdan is offline
Fourdan's Avatar
Antony (France)
Joined Sep 2003
Hi
Yes more distorsions in 12N2P and 12N4P
12N16P is OK (low distorsion) but the "merit factor" is less
My favourite is 12N10P (for the same magnet coverage %; could be 80-90%)
Louis
Old Aug 27, 2011, 09:52 AM
modisc is offline
Inspiration
modisc's Avatar
Joined Aug 2011
Hi
Louis
I just posted a thread about winding factors. Please see whether that term can actually solve some problems
Discussion Valid LRK wind? fly_boy99 Electric Motor Design and Construction 72 Jul 02, 2009 11:11 PM
Discussion Wind on LRK Geoff Woodward Electric Motor Design and Construction 41 Apr 27, 2007 09:27 AM
Discussion 6 stator tooth LRK wind? rcnutt Electric Motor Design and Construction 4 Apr 03, 2006 08:48 AM
LRK wind help requested please Rocketman209 Power Systems 6 Dec 06, 2005 11:40 AM
