Old Aug 17, 2011, 05:55 PM
Dialfonzo is online now
Find More Posts by Dialfonzo
DiaLFonZo - UAV/Drone
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Good...
@Cyberdog:
Can you weight a motor and esc for us?
Dialfonzo is online now Find More Posts by Dialfonzo
Old Aug 18, 2011, 02:46 PM
cyberdog is offline
Find More Posts by cyberdog
Sweden, Norrbotten County
Joined Jun 2007
Esc is 5 grams
Motor with propsaver, o-ring and 5x3 prop is 13 grams
cyberdog is offline Find More Posts by cyberdog
Old Aug 18, 2011, 02:53 PM
cyberdog is offline
Joined Jun 2007
Started building a small 18cm MtM frame to play with until i get a real frame Making it out of 10x18mm alu and ply. Little heavy but it will be ok to play with
Guessing the frame weight will be around 60-70 grams.
Old Aug 18, 2011, 02:54 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Originally Posted by cyberdog View Post
Esc is 5 grams
Tanks a lot...!
Old Aug 18, 2011, 06:43 PM
flyhigh300 is offline
Find More Posts by flyhigh300
United States, TX, El Paso
Joined Nov 2010
They are ready to mail tomorrow..
Here are some pictures..
1. Pic One - show's two center plates ( you only get one )
Top Plate will be your FB
2. Pic Two - show's Top view
after some debate here is how I did the bolts
a. Center Bolt come from the bottom - up
b. On the outside Bolt come from the top - down
3. I cut the slops under size ( final fit is sanded) so no glue
you get a very tight fit..
4. I'm using 2mm bolt then 4 - 2mmx20mm with plastic standoffs to hold the flight board.
Note: most flight boards use 3mm bolt holes but.. this should work fine..
flyhigh300 is offline Find More Posts by flyhigh300
Old Aug 18, 2011, 08:55 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Updated the first post ...
(Will do better, i am on my cellphone 1500km away from home. LOL)
Old Aug 18, 2011, 09:31 PM
G-unit is offline
Find More Posts by G-unit
WHEN IN DOUBT FLOOR IT!!!
G-unit's Avatar
AZ
Joined May 2006
Looks good, cant wait to get it.. I like the extra top plate, is there any way we can buy the extra center, so then we can have a roll cage to protect the FC..
Thanks G
G-unit is offline Find More Posts by G-unit
Old Aug 18, 2011, 10:25 PM
Joined Nov 2010
hmm yeah I was thinking about that.. when I put it together..
on hand I have some .. 25mm long 3mm bolts.. and 1/4 stand offs..
see pics..
:-) .. you guys are making me work..
will have to cut more part's if you guy's want this option..
weight with out this .. is 51grams .. with it 66grams
in your hands you can feel the difference..
Thanks G
Old Aug 18, 2011, 11:03 PM
daign is offline
Find More Posts by daign
My RC builds in my profile.
daign's Avatar
Joined Feb 2011
Liking this a lot.
daign is offline Find More Posts by daign
Old Aug 19, 2011, 09:02 AM
NaterPin is offline
Find More Posts by NaterPin
Joined Dec 2009
see pics..
I like the Idea of a top plate too. Luis my order is in.
NaterPin is offline Find More Posts by NaterPin
Old Aug 19, 2011, 07:05 PM
milliotseb is offline
Find More Posts by milliotseb
Munich (Germany)
Joined Oct 2010
Look nice
I will start with a 48cm motor to motor and maybe later this one
milliotseb is offline Find More Posts by milliotseb
Old Aug 20, 2011, 12:58 PM
cyberdog is offline
Joined Jun 2007
Heres a small pic of a mini frame i just put together. Will only use it as a testbed for the electronics
So faar the weight is 100 grams.
Old Aug 20, 2011, 01:26 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Real nice...!
What's the dimensions?
Comparable to our frame?
Witch controller you will use?
Old Aug 20, 2011, 01:59 PM
cyberdog is offline
Joined Jun 2007
This is 18cm mtm if i remember right. Wanted to use 5" props but the frame was too small so went with 4" propps instead Might try and fly it tomorrow if i can fit fc and rx on it Hopefully i get enough lift with the 4" props so it can take off . If not i make a new one that fits 5" props. Will be using 500-1000 mah 3s lipo.
If i cant find room for everything i will just wait till i get the real frame and try it out then
Old Aug 20, 2011, 02:05 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Witch frame will you use?
I am on my way home. Vacation are done... lol
Discussion DiaLFonZo-Copter TrinitY Quad V2.0 Dialfonzo Multirotor Talk 316 Mar 12, 2012 04:46 AM
Build Log KX-2 V1.0 Dragon kristjane Multirotor Talk 4 Oct 06, 2011 01:16 PM
Sold TacCon FS One Hangar 9 v1.0 Controller smallmax Aircraft - General - Miscellaneous (FS/W) 4 Apr 09, 2011 09:31 PM
Discussion Easy osd v1.0 or v1.2 borsel FPV Talk 2 Jul 10, 2010 04:35 AM
Idea A nifty tool for you guys/girls that program pics etc it is ASCII V1.0.0 flyman668 DIY Electronics 5 Dec 15, 2004 12:47 AM
