Old Aug 10, 2011, 10:54 AM
Dialfonzo is offline
Find More Posts by Dialfonzo
DiaLFonZo - UAV/Drone
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
DiaLFonZo - QuadMini & TriMini
--- Upgrade ---
Here is the new version
DiaLFonZo-Copter TrinitY QuadMini
Hi everyone,
The "DiaLFonZo - QuadMini" frame is freshly cut and ready to be shipped.
Now online at:
http://www.myrcbuild.com/DiaLFonZo--QuadMini_p_61.html
Hi All...
I am making a little quad and just want to share the design.
Center "Transparent" plate is to be the controller board. Standard 45mm hole.
G10 Rendering...
Dialfonzo is offline Find More Posts by Dialfonzo
Old Aug 10, 2011, 11:01 AM
Connexxion is offline
Find More Posts by Connexxion
Nemo in a blender
Connexxion's Avatar
The Netherlands-Amsterdam
Joined Mar 2007
Looks flimsy to me but lets see it's first flight first.
Connexxion is offline Find More Posts by Connexxion
Old Aug 10, 2011, 11:04 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Plan is to cut it from 1.5mm carbonfiber sheet.
I don't think it will have any flex.
It's small... arms are +-110mm overall.
+- 220mm center to center motors
Tanks for posting comments..
Old Aug 10, 2011, 11:09 AM
chris24g is offline
Find More Posts by chris24g
United States, CA, Hayward
Joined Apr 2006
interesting design. good work. for a small quad (sub 330mm), i think it be more than rigid enough. definitely rigid enough if you use 3mm CF.
chris24g is offline Find More Posts by chris24g
Old Aug 10, 2011, 09:11 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Tanks a lot...
I can't wait to have it in real material.. lol
Old Aug 10, 2011, 09:44 PM
SeismicCWave is offline
Find More Posts by SeismicCWave
AMA 46133
Hawaii
Joined Feb 2003
How are you going to have red and yellow when you make it in black carbon sheet?
Nice and clean looking design. I am concern about the flex of the motor mounts.
SeismicCWave is offline Find More Posts by SeismicCWave
Old Aug 10, 2011, 11:25 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Tanks,
It won't be Red and Yellow. I have done that render to show the parts. Since it's not easy to see on the CarbonFiber render.
I will have a "Beta" set to be cut on Friday. Will be cut out of 0.094" black G10 material. Just to see how it is looking.
Will keep people informed..!
Old Aug 11, 2011, 02:37 AM
cyberdog is offline
Find More Posts by cyberdog
Sweden, Norrbotten County
Joined Jun 2007
Looks nice. How are the legs attached to the arms? Glue or it just super tight fit.
cyberdog is offline Find More Posts by cyberdog
Old Aug 11, 2011, 02:58 AM
ChrisVogelzang is offline
Find More Posts by ChrisVogelzang
Joined Aug 2011
Unibody?
Why do you call it a unibody frame?
From what I can see it is made up of several parts
ChrisVogelzang is offline Find More Posts by ChrisVogelzang
Old Aug 11, 2011, 02:59 AM
timecop is offline
Find More Posts by timecop
Joined Dec 2010
Maybe the part about center + arms being unibody, usually this kind of frame have a center plate + 4 arms connected to it.
timecop is offline Find More Posts by timecop
Reply With Quote  (Disabled)
Old Aug 11, 2011, 07:39 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Ok, so first of all English is not my language. So sorry in advance if some word are not use as they should..
I have started the project using only a Controller as the center of the body. Only screwing the arm direcly to that board.
Then, i didn't think it was a good idea and maybe make the board break quickly on a crash. So i added a bottom plate.
So again sorry if the confusion.
This is a multi parts frame, with only one layer of arm (Not to are one on top of the other that are use in many bigger frame)
So have a name in mind ?
Eric
Old Aug 11, 2011, 09:21 AM
flyhigh300 is offline
Find More Posts by flyhigh300
United States, TX, El Paso
Joined Nov 2010
Hey Dialfozo,
I to forget that English was not my first language ...but for me it was so many years back ..
hmm for a name..
How about the Dilafozo-Mini :-) it will for sure be a small frame.. the motor to motor distance is.. 8.6"
Eric
flyhigh300 is offline Find More Posts by flyhigh300
Old Aug 11, 2011, 09:23 AM
kinderkram is offline
Find More Posts by kinderkram
OS Sponsor
kinderkram's Avatar
Germany, NRW, Dusseldorf
Joined Jun 2010
Nice frame!
The landing gears: do they just snap in or will you have to glue them?
kinderkram is offline Find More Posts by kinderkram
Old Aug 11, 2011, 09:38 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Originally Posted by kinderkram View Post
Nice frame!
Tanks..
I will take that descision when having them in my hand.
But i do think a couple drop of CA will lock them in place nicely.
Old Aug 11, 2011, 11:22 AM
Joined Nov 2010
Hey guys..
I think a little of both. :-)
Keeping a high tolerance .. where you can just have a friction fit ..
will be hard..
Option are to cut them a bit under size.. then sand to perfect fit..
the first test will be with .094-.1 in ( G10 material) .. and even CF..will burn up a lot of tools when cutting these material..
Tanks..
Discussion DiaLFonZo-Copter TrinitY Quad V2.0 Dialfonzo Multirotor Talk 316 Mar 12, 2012 04:46 AM
Build Log KX-2 V1.0 Dragon kristjane Multirotor Talk 4 Oct 06, 2011 01:16 PM
Sold TacCon FS One Hangar 9 v1.0 Controller smallmax Aircraft - General - Miscellaneous (FS/W) 4 Apr 09, 2011 09:31 PM
Discussion Easy osd v1.0 or v1.2 borsel FPV Talk 2 Jul 10, 2010 04:35 AM
Idea A nifty tool for you guys/girls that program pics etc it is ASCII V1.0.0 flyman668 DIY Electronics 5 Dec 15, 2004 12:47 AM
