Old Aug 10, 2011, 09:49 AM
lwalton is offline
Find More Posts by lwalton
Lance
lwalton's Avatar
United States, GA, Alpharetta
Joined Mar 2008
My H9 P-47 retracts are making some sounds
I've got this H9 P-47 with the OEM mechanical retracts. I had to put a new 791 servo in, the Futaba didn't have enough torque. When they go up, there's a 'creaking' noise. It sounds like something in the wood of the plane (a bulkhead, etc). I don't think it's affecting anything but I can't look inside the wing during the up retract operation to visually be able to diagnose the stress.
Anyone else ever see this?
Retracts on a Hangar 9 P-47 60 (0 min 29 sec)
lwalton is offline Find More Posts by lwalton
Old Aug 10, 2011, 11:51 AM
twmonroe is offline
Find More Posts by twmonroe
Joined Mar 2011
It could be a bulk head..could also be vibration in the push rods..it also doesn't look like your retracts are going all the way up?
I'd also pull the retracts out of the wing and check to see if possibly moving parts are rubbing against wood..it sounds like somethimes rubbing across a bulkhead or former when the retract is under load...if thats the case you should be able to see gouges in the wood where its hitting and a little dremel action with a drum sander will clearance it just fine..rubbing and gouging the wood can lead to binding and eventual breakage..better to be safe than sorry
Troy
twmonroe is offline Find More Posts by twmonroe
Old Aug 10, 2011, 03:34 PM
lwalton is offline
Lance
lwalton's Avatar
Joined Mar 2008
Thanks for the info. I forgot to mention it doesn't make that sound when the wing is inverted. So it must be gravity-related and you can't hear it in the video but it sounds like it's straining when it makes that noise. I'll pull the gear out tonight and look for scuffs.
Old Aug 10, 2011, 03:57 PM
DreamArcher is offline
Find More Posts by DreamArcher
DreamArcher's Avatar
Joined Apr 2008
I hope not but it sounds like stripping servo gears to me.
DreamArcher is offline Find More Posts by DreamArcher
Old Aug 10, 2011, 04:23 PM
twmonroe is offline
Joined Mar 2011
Could be that too
Troy
Old Aug 11, 2011, 05:19 AM
Lifer is offline
Find More Posts by Lifer
Kansas City
Joined Apr 2010
Gears. Replace them. It's the first gear off the output arm gear. A gear set is about $3.
Lifer is offline Find More Posts by Lifer
Old Aug 11, 2011, 11:18 AM
Joined Apr 2008
If it is stripped gears you need to also discover why they stripped and fix it.
Old Aug 13, 2011, 10:24 AM
twmonroe is offline
Joined Mar 2011
Things to look for on ruor retracts if it is the gear. Make sure your servo travel is only enough for the gear to lock in both positions. Mechanicals are a pain to get right. If you are are stripping gears on a metal geared servo then something is definately out of sorts.
Troy
Old Aug 18, 2011, 08:09 AM
lwalton is offline
Lance
lwalton's Avatar
Joined Mar 2008
Thanks again for everyone's input. So I took the servo out and when manually putting the gears up by pushing the push rod with my hand, I was able to recreate the noise - so it's def. something inside the wing. Problem is I don't see any rubbing or wear/tear on the gear or the wing. I need fiber optics to see what's happening when the sound occurs
Old Aug 20, 2011, 03:15 AM
twmonroe is offline
Joined Mar 2011
So you pulled the actuators and there was no sign of anything?
Pull em again and lay some epoxy at all the joints..just keep it off of the flats where the actuators rest on..also check for binding in each individual actuator..figure out which side its coming from..then make sure that the actuator frames aren't twisting when screwed down..
Something is out of true or it may be normal..I avoid mechanicals..
Best advice..ditch the mechanicals and throw a set of robart pneumatics into it and call it done..LOL
Troy
Old Aug 20, 2011, 09:42 AM
dweeb7944 is offline
Find More Posts by dweeb7944
Dweebster
dweeb7944's Avatar
United States, MA, Charlton
Joined Sep 2008
Troy
Troy has a very good point. Problems usually work themselves out the more money you throw at them. lol
dweeb7944 is offline Find More Posts by dweeb7944
Old Aug 20, 2011, 10:22 AM
1320fastback is offline
Find More Posts by 1320fastback
Detroit 2-stroke junkie
1320fastback's Avatar
USA, CA, Oceanside
Joined Jul 2008
Next step is to take out the retracts to see if it's them making the noise.
1320fastback is offline Find More Posts by 1320fastback
Old Sep 16, 2011, 10:32 PM
the beave is offline
Find More Posts by the beave
ward cleaver's boy...
the beave's Avatar
waco,texas
Joined May 2008
You can take the plastic wheel wells out but you have to do it very gently or they could be damaged. I've done it and it allows you to really get a good look into the wing. When you're done just glue them back in.
the beave is offline Find More Posts by the beave
Discussion Replacing fuel tank in H9 P-47 .60 lwalton Fuel Plane Talk 4 Jun 24, 2011 03:30 PM
Discussion setscrew for a H9 p-47 retracts. Thrawn150 Electric Warbirds 0 Jul 02, 2010 12:37 PM
Wanted H9 P-47 Retracts - 150 size 70 Inch Bird 3DTRYER Aircraft - General - Miscellaneous (FS/W) 0 Feb 25, 2010 05:40 PM
For Sale Century Jet Retracts for H9 P-47 60 Size rdrude Aircraft - Fuel - Airplanes (FS/W) 2 May 02, 2009 08:13 PM
For Sale WTS:Lower Price NEW H9 P-47 Retracts - 150 size 80 Inch Bird $65 LBJ Aircraft - General - Miscellaneous (FS/W) 2 Mar 21, 2009 09:11 PM
