Old Aug 10, 2011, 09:22 AM
John Kim is offline
Find More Posts by John Kim
Panorama City, CA
Joined Sep 2004
Alert
Turnigy/FlySky battery reverse polarity
Turnigy/FlySky transmitter is equipped with 3 pin battery socket.
Be careful. Center pin is positive while both ends are grounded ( - + - )which is very stupid idea. Unused end pin should not be grounded but open.
If you use two pin plug ( - + ) and plug it into wrong side, it will short. That is how I ruined my TX. Use the orignial 3 pin plug which came with battery box.
John Kim is offline Find More Posts by John Kim
Reply With Quote  (Disabled)
Old Nov 25, 2011, 06:19 AM
B12 is offline
B12
Find More Posts by B12
B12
Finland
Joined Sep 2010
So if I am using the servo type connector (=futaba type?) of the Hobbyking transmitter life-battery, it is one and the same which way I connect it?
It has positive in the center pin like servos, negative in one side and the other empty.
It is not the same type as the original but it fits just fine because the pin spacing and size is correct.
B12 is offline Find More Posts by B12
Old Nov 25, 2011, 08:00 AM
Daedalus66 is offline
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
I would not assume that at all. Are you SURE the third pin on the circuit board is not connected? If it's connected to positive you'll cook the battery. The only safe way is to plug it in the right way round.
Daedalus66 is offline Find More Posts by Daedalus66
Old Nov 25, 2011, 12:52 PM
B12 is offline
B12
B12
Finland
Joined Sep 2010
Assuming John Kim is right with the -+- pin order of the radio connector, it would be 100% safe to connect the battery servo connector (-+0) any way you like without issues.
Not verified though. I have only connected it the same as stock ie black to left.
Old Nov 26, 2011, 02:36 PM
John Kim is offline
Panorama City, CA
Joined Sep 2004
Servo plug (3 pins) should be OK as long as the center pin is positive and size fits.
Question Turnigy 9X reversed battery polarity - smoke John Kim Radios 52 Dec 09, 2013 04:24 AM
Discussion FlySky/iMax/Turnigy 9X Battery Solutions c4v3man Radios 22 Aug 20, 2013 07:55 PM
Discussion Lipo polarity reverse contact slowstick4ap Batteries and Chargers 4 Jul 23, 2011 04:43 AM
Help! GPS and Reverse Polarity? iacei FPV Talk 2 Jul 11, 2011 01:24 PM
