Old Jul 25, 2012, 06:06 PM
Adidas4275 is offline
Find More Posts by Adidas4275
manual flying apologist
Adidas4275's Avatar
United States, CA, Fresno
Joined Mar 2011
Originally Posted by MaNDoWn View Post
I use waypoints so I have only used Ace One and WKM so I can't comment on the Naza.
what is funny is that the Naza GPS gets a lock 2-3 times faster than my WKM and flies the same in ATTI and manual mode.
at this point waypoint is the only reason to get the WKM
i am impressed that you fly AP/AV with waypoints.
you ARE "the most interesting (AP) man in the world"
Adidas4275 is offline Find More Posts by Adidas4275
Old Jul 25, 2012, 06:24 PM
boranup is offline
Find More Posts by boranup
Australia, WA
Joined Jun 2012
Hi Dave - thanks for the quick reply, yes for signal and TX loss, not sure what other instances fail safe would be needed for? Maybe if you lost sight or orientation?
I will try to set that up shortly, excuse my noobness here - enhanced failsafe is only for GPS mode? Not 100% sure why I need to manually setup failsafe if there is this option in the software?
Cheers
boranup is offline Find More Posts by boranup
Old Jul 25, 2012, 06:25 PM
MaNDoWn is offline
Find More Posts by MaNDoWn
Registered Aircraft Crasher
United States, CO, Calhan
Not EVERY thing I fly is just for AP/AV. Waypoints are also good for survey and site mapping.
MaNDoWn is offline Find More Posts by MaNDoWn
Old Jul 25, 2012, 06:40 PM
Davebbb is offline
Find More Posts by Davebbb
Joined Aug 2011
Cheers
The enhanced, is basically giving you a choice to offer an option of what you want it to do in the event of Signal loss or TX malfunction, but you need set the failsafe up so it knows what to do if that situation happened, that would then trigger whichever option you chose in the Enhanced failsafe section.
Davebbb is offline Find More Posts by Davebbb
Old Jul 25, 2012, 06:50 PM
boranup is offline
Australia, WA
Joined Jun 2012
Thanks Dave, next question as I try to do this - anyone know how this is done on a Hitec Aurora 9? If I read the manual correctly it says I don't need to use a bind plug? I watched the pitchbitch vid on Vimeo for this and understand the process - now its the execution on my equipment that I need assistance with.
Old Jul 25, 2012, 07:11 PM
Davebbb is offline
Joined Aug 2011
no, i have an Aurora 9.
you simply do as the manual states, eg, press and hold the RX button until it flashes blue, move the switch and throttle to desired position think it was within 5 seconds, then thats done.
now when you go back to the assistant, and turn off the TX the throttle should move up and the Failsafe should highlight blue, if that works ok, all you do is go back to the switch settings and re-do it for the mode switch .
Old Jul 25, 2012, 07:14 PM
Sid3ways is offline
Find More Posts by Sid3ways
DJI Supporter
Sid3ways's Avatar
Swanton, OH
Joined Jul 2007
I could send you a pre-setup file from my A9 for all the functions I use if you have the HP-22
Sid3ways is offline Find More Posts by Sid3ways
Old Jul 25, 2012, 07:24 PM
boranup is offline
Australia, WA
Joined Jun 2012
God - how to bring out all my noobness in one go What is a HP-22 - ok its the PC interface setup - no I don't have it Thanks for the offer though Sid!!
OK found this video -
How to setup your Hitec Aurora 9 with your NAZA-M GPS fail safe RTH mode (19 min 43 sec)
Followed his steps and have it all setup and working - have setup a switch for failsafe as in his video - time to go and test at the local park.
Amazing learning curve - how frustrating and daunting things seem and then bang - all is clear - well murky but clear enough to make it through
Works a treat both using the switch for fail safe and turning off the receiver - very happy, just need my gimbal to turn up then it's a video fest
Old Jul 25, 2012, 08:39 PM
Buffythesaint is online now
Find More Posts by Buffythesaint
Joined Feb 2005
Originally Posted by Infante View Post
I Just got my S800 With the Wookong -M all assembled and i am ready for a test flight.
The Problem is that i Only managed to setup everything with the the assistant software with the Receiver type set to TRADITION.
I never get any signal on the sticks calibration when i choose PPM.
The Graupner MX-20 is on (DSC output PPM24). Watts the difference from PPM10/16/24...
Is it secure to fly this way.
Can any one help please.
Additional info:
Radio Set to Mode 2 stick.
receiver connections:
Throttle- Chanel 1
Aierons-Chanel 2
Elevator-Chanel 3
Rudder-Chanel 4
U-Chanel 7
X3-Chanel 6
All channels mapping and Fail safe working fine, at least on the menus of the assistant software.
I think you are going about it wrong. The HOTT rx's will put out PPM on one of the channels. You need to select SUMO in the tx. Here is a link on the MX-20 and an MK setup. Skip the MK stuff but it will tell you how to set your rx to SUMO. The # of rx channels will determine the # after SUMO. Check which rx you have and the corresponding ppm(SUMO) channel #. The rx must be bound and on so the tx can tell the rx to go into sumo mode. If you get an air module for the MX-20, you will get more telemetry feedback and with voice output if you want.
http://www.mkmanual.com/graupner-mx-20#TOC-Voice-output
Buffythesaint is online now Find More Posts by Buffythesaint
Old Jul 25, 2012, 10:35 PM
Daloaf is offline
Find More Posts by Daloaf
SkyHi Aerial
Daloaf's Avatar
San Francisco, CA
Joined Nov 2005
Originally Posted by Psionic001 View Post
Tanks BB
They may be pulling 130A, but Deans are rated at 50A and one day this will lead to a failure.
I'm finding that with a lot of use, they get very loose and sometimes I have to add a backup piece of tape to prevent slippage.
Also, I would not be covered with my Public Indemnity insurance if it was found I had a failure due to poor choice of plug.
Any more views on plus for multis? particularly Heavies.
I have deans running a 100CC sized electric 3D plane on 12S 10,000, 120A without issue for a year now (and a 12S, 110A 50cc sized for 3 years). That being said, I've replaced the plugs once from carbon build up in the last year.Deans are WAY under rated. Most of the 3D HobbyShop and Extreme Flight Giant Scale guys use deans as well. Oh and I only use the Hobbyking version btw and I have not had a single failure due to plugs in well over 8-9000 flights using HK deans in the last 5 years.
All that being said, buy whatever you feel comfortable flying. There is nothing wrong with those bullet connectors or Anderson PP's.
Daloaf is offline Find More Posts by Daloaf
Old Jul 25, 2012, 10:37 PM
Daloaf is offline
SkyHi Aerial
Daloaf's Avatar
San Francisco, CA
Joined Nov 2005
Originally Posted by digitalCAM View Post
Panza, I have a F550 Hex. I have an AG550 gimbal from "Askman". and I have been using 5.12a and my gimbal gain set to 400hz. It is working fine for me. Here is some video that I shot today. It is straight out of the camera, without any sort of post stabilization. -- JOHN https://vimeo.com/46338303
Awesome video. That's one of the smoothest, non-stabilized videos I have seen. What camera were you using?
Old Jul 25, 2012, 11:44 PM
Adidas4275's Avatar
Joined Mar 2011
he is using the Sony RX100
Old Jul 26, 2012, 12:42 AM
digitalCAM is offline
Find More Posts by digitalCAM
John
United States, WA, Mason
Joined Apr 2011
Adidas is correct. I AM using the RX100. It seems to have quite good stabilization built into it. -- JOHN
digitalCAM is offline Find More Posts by digitalCAM
Old Jul 26, 2012, 01:15 AM
FlyingMcCoy is offline
Find More Posts by FlyingMcCoy
Joined Mar 2010
Can the stabilization be turned off? I'm surprised it doesn't cause any adverse effect.
FlyingMcCoy is offline Find More Posts by FlyingMcCoy
Old Jul 26, 2012, 01:52 AM
Adidas4275's Avatar
Joined Mar 2011
Yes it can be turned off.
Mechanical isolation is good on many cameras even on a multirotor.
The best example is the Sony BOSS on the CX710 and PJ760 lines of camcorders.
The RX100 looks to be very good
optical image stabilization not software based.
Discussion Ballistic Recovery System for Multirotors Duck! Aerial Photography 66 Nov 13, 2015 04:37 PM
Discussion DJI - WooKong eStab for Scale sidneyw Scale Helicopters 97 Dec 30, 2012 10:48 AM
Discussion FY3ZT Autopilot for Aerial Photography feiyudz Aerial Photography 116 May 07, 2012 04:58 PM
Discussion DJI AceOne autopilot for sale... hazchem88 Aerial Photography 4 Mar 31, 2011 03:54 AM
Discussion DJI Innovation helicopter autopilot XP.3.1 for European customers JoelT Aerial Photography 2 Sep 24, 2009 11:43 AM
