Old Jul 15, 2012, 06:06 PM
janoots2 is online now
Find More Posts by janoots2
janoots2's Avatar
Joined Jan 2012
Just got back from the field testing 5.12 and was pretty happy and successful on my hex. Didn't have any issues and it flies very smooth. I especially noticed a difference coming down in altitude. You can actually descend and keep it pretty smooth. I just set my attitude gains to remote so I could dial them when the the wind blew. Gains were at 150 across the board and held well around 100 for attitude when I was done. Haven't tried POI yet. Hex, sbus, Avroto, Maytech, Graups, UAP-1. Running Savox's on a direct drive gimbal and upped them to 400, not sure if I really noticed a difference...I might need to put different gains in now or something.
janoots2 is online now Find More Posts by janoots2
Old Jul 15, 2012, 06:24 PM
Adidas4275 is offline
Find More Posts by Adidas4275
manual flying apologist
Adidas4275's Avatar
United States, CA, Fresno
Joined Mar 2011
the Hz on the servo will make it look smoother so you dont see any stepping from the servo
Adidas4275 is offline Find More Posts by Adidas4275
Old Jul 15, 2012, 06:26 PM
Davebbb is offline
Find More Posts by Davebbb
Joined Aug 2011
tried to mail Xaircraft to ask what Hz the Gimble servos will be ok with, hmmm considering the mail i got back, i dont think they actually know
Davebbb is offline Find More Posts by Davebbb
Old Jul 15, 2012, 06:38 PM
Adidas4275's Avatar
Joined Mar 2011
digital servo are fine at 400hz analog servos need 50hz and some high end analog servos can do 100hz without issue.
I have run my MKS servos up to 600hz on the HoverFly Gimbal Controller without issue
Old Jul 15, 2012, 06:40 PM
Davebbb is offline
Joined Aug 2011
Well they are Digital servos, so ill up it and see if that calms them down ill step up though fromm 100 and take it from there
Old Jul 15, 2012, 06:53 PM
matthewlavin is offline
Find More Posts by matthewlavin
United States, CA, Santa Cruz
Joined Dec 2011
Servo Hz
I updated and I am having much better flight stability. All my settings stayed the same for a heavy lift quad 7.7lbs. I was having a very high frequency vibration when I yawed aggressively. The new firmware made that go away. Better performance in gusty wind too.
Servo Hz
I found this website that has a lot of servos and the Hz they run at. It doesn't have them all but it had my Hitec.
http://www.ronlund.com/rcheli/HELP_SERVO_PULSE.html
matthewlavin is offline Find More Posts by matthewlavin
Old Jul 15, 2012, 07:28 PM
Tahoe Ed is online now
Find More Posts by Tahoe Ed
DJI Support
Tahoe Ed's Avatar
Las Vegas/Lake Tahoe
Joined Feb 2010
I just upgraded to v5.12 and wanted to check my Ground Station. I started v4.05 and was told the Google Earth Plug-in was either corrupt or not the correct version. I uninstalled and reinstalled. It was working when an update notification came up for v4.06. Since that version has loaded I have not been able to get the program to load. It fails on the Google Earth load. I have uninstalled v4.06 and Google Earth several times. Nada. Anybody else have this problem? Anybody have a solution to my problem?
Tahoe Ed is online now Find More Posts by Tahoe Ed
Site Sponsor
Old Jul 15, 2012, 07:37 PM
MaNDoWn is offline
Find More Posts by MaNDoWn
Registered Aircraft Crasher
United States, CO, Calhan
Power issue with octocopter
I would tell anyone who is flying an Octocopter to be VERY CAREFUL!
MaNDoWn is offline Find More Posts by MaNDoWn
Old Jul 15, 2012, 08:33 PM
Davebbb is offline
Joined Aug 2011
Hi
I looked around some more, and someone else is running the Xaircraft Servos at 500Hz, he says without issue, so, will just stick them up to 400Hz.
Old Jul 15, 2012, 08:49 PM
Adidas4275's Avatar
Joined Mar 2011
flown with the WKM (not controlling the gimbal)
Aerial Highlight Reel Wyoming 2012 (ATV, Horseback, Fly Fishing, Real Estate, Salt & Snake Rivers) (4 min 36 sec)
Old Jul 15, 2012, 08:54 PM
nicnaimless is offline
Find More Posts by nicnaimless
nicnaimless's Avatar
United States, MI, Jenison
Joined Jun 2008
http://www.youtube.com/watch?v=cT2PPKQDr0E
Nice work! That askman gimbal is looking more and more enticing.
nicnaimless is offline Find More Posts by nicnaimless
Old Jul 15, 2012, 09:04 PM
Adidas4275's Avatar
Joined Mar 2011
it is getting better.... and what i love is that when he improves his design he will sell you the upgrades for cheap
other places will just release a new Rev 2 gimbal and then charge $200 for a upgrade kit.
Old Jul 15, 2012, 09:09 PM
sidneyw is offline
Find More Posts by sidneyw
United States, NC, Huntersville
I had the same issue as "snurre" but I wasn't so lucky to be on the bench without batteries connected.
Here's what happened to me.
My Octo was working GREAT! I updated to FW 5.10 and had an issue where my Tx radio (JR9303) wouldn't recognize the throttle or rudder inputs.
I removed 5.10 from my computer, trash can, and rebooted my computer. When I logged back on to DJI to download 5.10 again I found the NEW 5.12 update.
I then updated 5.12 FW and checked over ALL my settings. Everything was fine and I rewrote everything just to be sure.
I took my Octocopter outside for a low level test flight and it flew great but didn't seem to hold as well in GPS mode. I thought no big deal and decided to try the POI.
The POI worked and I thought that was COOL! I landed after what was a 4 to 5 minute flight. It was getting late so I didn't get another flight in.
The next day I was ready to go! I got my Octocopter set-up outside and powered everything up. Waited to get a solid GPS lock and started my flight.
About 60 to 90 seconds into my flight I put my Octo into a hover at about 75' altitude. It then took a hard left pitch. I responded by giving it right aileron.
It pitched back right and into a hover for a second. Then ALL MOTORS STOPPED and it fell from the sky like a rock.
I applied throttle on the way down but it didn't help to slow it down one bit. It hit the ground like a rock!
My octo itself wasn't damaged too bad (bent arms) but it just destroyed my camera mount, camera, 2 of 4 batteries, and my air retract arms.
I took the octo inside and put it on my bench. I tested all the wires and push/pulled to look for any bad connections or a short.
Everything was all as it should be. The 2 batteries that didn't get destroyed tested fine (15.9 and 16.0) on voltage.
I removed all my props and fired it up again with batteries that wasn't involved in the crash.
On the bench I brought it up to 1/2 throttle and wiggled my aileron and elevator. The damn thing shut down my motors again!
I THINK THE 5.12 HAS SOME POWER ISSUES, BUGS, OR WHATEVER YOU WANT TO CALL THEM!
FLY AT YOUR OWN RISK AND YOU'VE BEEN WARNED!
I know my bird is GROUNDED until I hear back from DJI! If anyone else is having or had a power issue I would love to hear from you!
Take a look at the videos "snurre" posted of his octo getting power spikes.
Wkm fw 5.12 for octa safety alert
http://www.youtube.com/watch?v=HTMss5jJd18
WKM - Assistant MC output off- motor 7&8 alive fw5.12
http://www.youtube.com/watch?v=CxPSz...=youtu.be&hd=1
We are looking into your report ....
sidneyw is offline Find More Posts by sidneyw
Site Sponsor
Old Jul 15, 2012, 09:20 PM
DJI Support
Tahoe Ed's Avatar
Joined Feb 2010
Mystery solved on my Ground Station. It took 4 times to get everything uninstalled and reinstalled. I still could not connect to the WKM. Looked at Assistant and I need a new S/N for my new MU to replace the early model. Oh well, at least I don't have to keep banging my head against the wall.
Site Sponsor
Old Jul 15, 2012, 09:48 PM
bcollydas is offline
Find More Posts by bcollydas
bcollydas's Avatar
Canada, QC, Laval
Joined Apr 2008
Does this mean that the 5.12 FW for octocopters is grounded?
bcollydas is offline Find More Posts by bcollydas
Discussion Ballistic Recovery System for Multirotors Duck! Aerial Photography 66 Nov 13, 2015 04:37 PM
Discussion DJI - WooKong eStab for Scale sidneyw Scale Helicopters 97 Dec 30, 2012 10:48 AM
Discussion FY3ZT Autopilot for Aerial Photography feiyudz Aerial Photography 116 May 07, 2012 04:58 PM
Discussion DJI AceOne autopilot for sale... hazchem88 Aerial Photography 4 Mar 31, 2011 03:54 AM
Discussion DJI Innovation helicopter autopilot XP.3.1 for European customers JoelT Aerial Photography 2 Sep 24, 2009 11:43 AM
