I'm not the one having flight performance issues. My rig has flown excellent from day one. I have added FPV gear, changed props, changed cameras, and numerous other devices added. I have never readjusted the the XYZ and only gain adjustments. So as you've said.... "I've gotten lucky" many times. |
Joined Aug 2011
when i first got it, i just hung everything on, until i got a central CoG, as far as i can tell, are you not just measuring the GPS distance from the Centre? after all, the GPS only needs to know where it is in relation to the centre of the craft?
the GPS does not need to know anything in relation to CoG ? eg if the GPS is 5cm back and you have 0 as a value, then you calibrate it, the GPS will think that where it is is the Centre of the craft? but in reality the craft is 5cm farther forward? or am i being dumb? lol |
Proof that X Y Z do not need to be changed based on distribution of weight ( CoG )
@3:30 we see the multi take a heavy load on one arm and no adjustments made. Gyros and Acc don't measure weight, only changes in space postition. CoG is often center of craft but not always.
Joined Apr 2007
The best place, to have as little force as possible to change a multi in the air, is to have the CoG in the same plane/height as the propellers. For a quad that is a little bit higher than the frames and on a Y6 the same height as the center of the arms.
EDIT: And I am talking about the z- value here This guy has grasped this and know what I am talking about - look at his multi: http://www.rcgroups.com/forums/showthread.php?t=1599250 |
Joined Aug 2011
with CoG, you add your placement of stuff to gain a central CoG, eg, the craft sits level, so if your IMU is in a central postion, the only value would need altering would be possibly Z.
But surely if your placement grants you a level sitting craft, from varying positions, then the CoG is still central? therefore it is still heading back to Centre of craft? Also, what do people think? would you advise to have the GPS as central to the craft as possible? |
I really think DJI made a big mistake when they wrote CoG in the manual in an attempt to keep thing simple and understandable. Lots have been led astray. |
Canada, ON, Toronto
Joined Jul 2011
Hi Bill since you pointing out the Diagram your C.O.G is between battery or ( middle of the battery ) then IMU starts from there and the GPS value would go higher( negative) and IMU value go lower( positive) in Dji assistant screen - this is the way i understood Values are inputed incorrectly, it's still fly no problem IMU will work twice harder to balance the C.O.G also you will noticed during a take off and landing it may not straight up or straight down ( chicken dance) Shiu |
Joined Aug 2011
| Thread Tools | |
| Discussion Ballistic Recovery System for Multirotors | Duck! | Aerial Photography | 64 | Mar 22, 2013 11:13 AM |
| Discussion DJI - WooKong eStab for Scale | sidneyw | Scale Helicopters | 97 | Dec 30, 2012 10:48 AM |
| Discussion FY3ZT Autopilot for Aerial Photography | feiyudz | Aerial Photography | 116 | May 07, 2012 04:58 PM |
| Discussion DJI AceOne autopilot for sale... | hazchem88 | Aerial Photography | 4 | Mar 31, 2011 03:54 AM |
| Discussion DJI Innovation helicopter autopilot XP.3.1 for European customers | JoelT | Aerial Photography | 2 | Sep 24, 2009 11:43 AM |
