Old Jul 15, 2012, 08:43 AM
nicnaimless is offline
Find More Posts by nicnaimless
nicnaimless's Avatar
United States, MI, Jenison
Joined Jun 2008
Originally Posted by blade strike View Post
Are you sure your Z value is correct? It seems with batteries that low it would atleast be around -3 -4?
Something you might want to look at
I've always understood the values to represent the distance to the center of the craft. Not actual weight distribution. I don't think the value should change if the battery was mounted 12 inches below the frame or 3 inches to the right of center. The value needs to be changes in relation to the distance the IMU is from center of the aircraft. I don't believe we are concerned with weight distribution here.... Please correct me if I'm wrong.
nicnaimless is offline Find More Posts by nicnaimless
Old Jul 15, 2012, 08:46 AM
blade strike is offline
Find More Posts by blade strike
DJI Testing / US Support
blade strike's Avatar
United States, CA, Big Bear
Joined Jan 2006
Sorry to say yoou are wrong They want distance to the CoG
blade strike is offline Find More Posts by blade strike
Site Sponsor
Old Jul 15, 2012, 08:49 AM
Joined Jun 2008
So if you added a big camera mount to the bottom of your craft you would change your Z value? Is this what you are doing?
Old Jul 15, 2012, 09:01 AM
VerticalVue is offline
Find More Posts by VerticalVue
VerticalVue's Avatar
United Kingdom, England, Blackpool
Joined Aug 2011
That is correct. I fly with camera ballast so that i dont have to keep changing settings. Its all in the manual....
VerticalVue is offline Find More Posts by VerticalVue
Old Jul 15, 2012, 09:10 AM
Joined Jan 2006
What he said ^^^^^
Site Sponsor
Old Jul 15, 2012, 09:17 AM
Joined Jun 2008
This is very interesting. I think we have a language issue in the manual. You can hang a lipo off one arm of a tuned WKM craft and it will hold position the same as if the craft was balanced perfectly. All this without changing the X Y or Z values. The GPS and Compass are not concern about the center of gravity but concernd with the center of the craft. GPS and compass are measured the same as IMU. I think this language problem in the WKM manual has caused A LOT of headaches. Once WKM knows the center of the craft it's good to go. I've never adjusted these from initial setup and I swap out little point and shoot cameras all the way up to Pro cameras over 4 lbs. It flies the same. Of course I adjust gains but IMU just wants to know where the center is not where the weight is.
Hmmmm.... I think DJI wrote CoG when the IMU is mostly concerned with CoC.
Old Jul 15, 2012, 09:28 AM
Davebbb is offline
Find More Posts by Davebbb
Joined Aug 2011
When i first got it, i just placed my IMU dead centre, never added values, as i saw it, there were no values to add as the centre point is the CoG point, as for GPS, what are we saying exactly?
If the GPS is set to the rear and up, do i measure its distance from the CoG and enter a minus value? and measure distance up, then enter a Minus figure?
never did this earlier, but all used to be fine.
Davebbb is offline Find More Posts by Davebbb
bcollydas is offline
Find More Posts by bcollydas
bcollydas's Avatar
Canada, QC, Laval
Joined Apr 2008
OK Blade then help me out here.
This is a quick diagram of my setup.
The bird is at work and I don't have it in front of me.
According to the diagram, what are the position numbers from the IMu and the GPS?
Right now I have my GPS set at -3cm for the Z axis.
Cheers
Bill
bcollydas is offline Find More Posts by bcollydas
Old Jul 15, 2012, 09:35 AM
Davebbb is offline
Joined Aug 2011
so this pic, what would my values be for the GPS negative?
Centre is also CoG
Old Jul 15, 2012, 09:36 AM
Joined Aug 2011
Refer to pages 11,12 and 13 of the Manual 2.9. Everything refers to the C of G, its makes sense....If you have never compensated for Cg (large) changes I would suggest that you have been very lucky. The M will compensate for small changes.
I always try to get my Cg at aircraft centre (X and Y), this makes life easy when taking measurements, the only problem comes with estimating the Z value...this is the one that in most affected by increasing battery weight/adding gimbals and cameras.
The IMU and GPS want/need to know where the copter Cg is, NOT the CoC. Cheers
Old Jul 15, 2012, 09:37 AM
epedemi is offline
Find More Posts by epedemi
Im the eye In the sky
epedemi's Avatar
Denmark, Region Zealand, Jyderup
Joined Mar 2012
Perfect flyer
Ok guys...
I dont think perfect is a term in this business... But I think I have achieved something very close to it.
Firmware 5,12
This is in windy conditions.
Gps-atti mode.
Frame = Dji F550
AUW = 2,5 kilos.
Graupner 10x5
Maytech esc = 30amp.
Zippy flightmax 5800
Torxpower ( tigermotor ) 2216 ( 900kv )
Gymbal enabled.
epedemi is offline Find More Posts by epedemi
Old Jul 15, 2012, 09:42 AM
bcollydas's Avatar
Canada, QC, Laval
Joined Apr 2008
do you have a picture of the craft?
Old Jul 15, 2012, 09:43 AM
Joined Aug 2011
Centre is also CoG
Assuming Cg is at centre then the GPS would have negative X and Z.
Old Jul 15, 2012, 09:45 AM
Davebbb is offline
Joined Aug 2011
okay, thanks Bengit
Old Jul 15, 2012, 09:47 AM
tritan is offline
Find More Posts by tritan
Joined Apr 2007
Originally Posted by epedemi View Post
Ok guys...
Firmware 5,12
Gps-atti mode.
Frame = Dji F550
AUW = 2,5 kilos.
Graupner 10x5
Gymbal enabled.
Correct me if I am wrong but do you have the IMU 4cm below your CG?
tritan is offline Find More Posts by tritan
Discussion Ballistic Recovery System for Multirotors Duck! Aerial Photography 66 Nov 13, 2015 04:37 PM
Discussion DJI - WooKong eStab for Scale sidneyw Scale Helicopters 97 Dec 30, 2012 10:48 AM
Discussion FY3ZT Autopilot for Aerial Photography feiyudz Aerial Photography 116 May 07, 2012 04:58 PM
Discussion DJI AceOne autopilot for sale... hazchem88 Aerial Photography 4 Mar 31, 2011 03:54 AM
Discussion DJI Innovation helicopter autopilot XP.3.1 for European customers JoelT Aerial Photography 2 Sep 24, 2009 11:43 AM
