Old Jul 15, 2012, 03:32 AM
VerticalVue is offline
Find More Posts by VerticalVue
VerticalVue's Avatar
United Kingdom, England, Blackpool
Joined Aug 2011
VerticalVue is offline Find More Posts by VerticalVue
Old Jul 15, 2012, 04:47 AM
epedemi is offline
Find More Posts by epedemi
Im the eye In the sky
epedemi's Avatar
Denmark, Region Zealand, Jyderup
Joined Mar 2012
Testing
Ok I get decent flight with theese settings.. FIRMWARE 5,12
But not perfect, its still alittle NOT Staying put, alittle all over the place in Atti-gps.
Drifting up and down, and in vertical lines from side to side ( alittle)
Any suggestions are welcome,
I have a Hexa F550, T.motor 2216 ( 900kv )
Graupner 10x5 E-props.
maytech esc 30amps.
2,5 kilo lift-off weight.
EDIT : Everything are centered, does not look like it, but it is perfect in balance
EDIT : I have slight wind, and small gust ( normal weather I would say )
( Mounting is ) = Z on the Imu is 1 cm // Z on the gps is -15
epedemi is offline Find More Posts by epedemi
Old Jul 15, 2012, 05:12 AM
Ab74 is offline
Find More Posts by Ab74
Philippines
Joined Dec 2010
My test initial test with my octo,
DJI WK-M Octocopter XL Flight Test rcphilippines (2 min 28 sec)
Ab74 is offline Find More Posts by Ab74
Old Jul 15, 2012, 05:25 AM
IconFlyer is offline
Find More Posts by IconFlyer
Joined May 2011
maytech esc 30amps.
out of interest, did you try with lower gain values? the reason I ask is that your setup is very similar to mine interms of dimensions and AUW and the gains seem to be very high yet your getting drifts(which could be vibration related or simply the craft not being able to compensate fast enough)...I have a feeling that most people are facing issues because DJI changed the gain range.
IconFlyer is offline Find More Posts by IconFlyer
Old Jul 15, 2012, 05:29 AM
epedemi is offline
epedemi's Avatar
Joined Mar 2012
What are your gains plz?!!
Old Jul 15, 2012, 05:35 AM
Joined May 2011
I just started testing with 5.12 yesterday...100% was un-fliable(swinging and not enough compensation)...next I tried 150%...still swinging but better(at least I could fly it)...I guess 250% would be rock solid for my setup, will test some more today.
Old Jul 15, 2012, 05:49 AM
epedemi is offline
epedemi's Avatar
Joined Mar 2012
Im using remote gain tuning on pitch roll, and on atti.
Old Jul 15, 2012, 07:31 AM
epedemi is offline
epedemi's Avatar
Joined Mar 2012
Im getting very good results right now, with medium vind in Gps-atti.
Will post my gains sortly, doing the last settings on my attitude on remote, just ran out of batteries ;-) now I have used up 7 battery-packs on testing.. :-) One thing I have noticed is that YAW is now up to 300 after seeing Ab74 doing his testing with his octo.
Old Jul 15, 2012, 07:43 AM
Joined May 2011
stupid question but just for sanity
I know this was probably asked before but I couldn't find the answer easily:
When the IMU is mounted to left of the CoG, should the number in the assistant be positive or negative? The manual says distance from the center of the IMU to the CoG, which according to the diagram means that if the IMU is on the left, the number should be positive. However going by the description of the diagram it's the opposite.
Old Jul 15, 2012, 07:49 AM
epedemi is offline
epedemi's Avatar
Joined Mar 2012
Negative
Old Jul 15, 2012, 07:50 AM
Joined May 2011
its a negative
That's what I have and what i understood always, but since I installed 5.12 I've been doubting everything i learned in the past year
Old Jul 15, 2012, 08:33 AM
blade strike is offline
Find More Posts by blade strike
DJI Testing / US Support
blade strike's Avatar
United States, CA, Big Bear
Joined Jan 2006
Are you sure your Z value is correct? It seems with batteries that low it would atleast be around -3 -4?
Something you might want to look at
I will need to try some higher gains and push mine, maybe that will help with wind..They had to play around with the gain matrix, relearing everything right now!
blade strike is offline Find More Posts by blade strike
Site Sponsor
Old Jul 15, 2012, 08:38 AM
Joined May 2011
With the battery only I never had to set the Z value before although my Z cog is about 2.5cm below the bottom plate...I only set the Z value when i have the camera + mount underneath. I didn't change anything since FW 5.08 hence my surprise that it would behave like that since the upgrade
Old Jul 15, 2012, 08:40 AM
Joined Jan 2006
Oh ok.. I was just going by the pic you posted
Site Sponsor
Latest blog entry: Dji m600
Old Jul 15, 2012, 08:42 AM
Joined May 2011
no problems, thanks for your input! didn't post any pictures...that was someone else's hexa, I just said it was similar to mine
Discussion Ballistic Recovery System for Multirotors Duck! Aerial Photography 66 Nov 13, 2015 04:37 PM
Discussion DJI - WooKong eStab for Scale sidneyw Scale Helicopters 97 Dec 30, 2012 10:48 AM
Discussion FY3ZT Autopilot for Aerial Photography feiyudz Aerial Photography 116 May 07, 2012 04:58 PM
Discussion DJI AceOne autopilot for sale... hazchem88 Aerial Photography 4 Mar 31, 2011 03:54 AM
Discussion DJI Innovation helicopter autopilot XP.3.1 for European customers JoelT Aerial Photography 2 Sep 24, 2009 11:43 AM
