Old Jul 14, 2012, 03:04 PM
Davebbb is offline
Find More Posts by Davebbb
Joined Aug 2011
if 1.30 is ready, where is it? all i can see, is still 1.28?
Davebbb is offline Find More Posts by Davebbb
Old Jul 14, 2012, 03:05 PM
IconFlyer is offline
Find More Posts by IconFlyer
Joined May 2011
So the trick is for the assistant software to see the changes, the unit must be power cycled everytime you do a write...don't really know if that's an assistant or a FW issue.
Also noticed now that my set failsafe values are all at max although my Rx is setup to keep everything centered except for throttle :S
IconFlyer is offline Find More Posts by IconFlyer
Old Jul 14, 2012, 03:09 PM
Davebbb is offline
Joined Aug 2011
must be recent, as i have never had to do that to see any changes before.
Plus im still trying to find out where is the option for increasing servo travel limit ? because it wont let me alter past a 1000
so no way i can do 90 ?
Old Jul 14, 2012, 03:14 PM
blade strike is offline
Find More Posts by blade strike
DJI Testing / US Support
blade strike's Avatar
United States, CA, Big Bear
Joined Jan 2006
http://www.rcgroups.com/forums/showthread.php?t=1691421
blade strike is offline Find More Posts by blade strike
Site Sponsor
Latest blog entry: Dji m600
Old Jul 14, 2012, 03:16 PM
Davebbb is offline
Joined Aug 2011
cheers
Old Jul 14, 2012, 03:34 PM
Joined May 2011
From my initial ground tests on 5.10, the +/- 1000 now provide you with an increased range of travel, no need to enable or adjust anything
Old Jul 14, 2012, 03:54 PM
Davebbb is offline
Joined Aug 2011
Hmm, my travel has not changed in the slightest, still exactly the same movement as i have had all the time.
Old Jul 14, 2012, 04:06 PM
Joined Jan 2006
OK...
First two flights seem ok.. Not able to try RTH or the new POI, since we have thunderstorms right now and not going to bother going to the field or lake.
Dont think your gains are even going to be close to your old ones! I have her holding ALMOST as good as the NAZA now, still need some more time to fine tune. I would also like to see how she does in higher wind.
This is on a f550 with aeroxcraft LG..F/W 5.12
Basic
170/170/155/155
Altitude
120/120
Havent touched the Advanced settings as of yet!
Site Sponsor
Old Jul 14, 2012, 04:14 PM
Joined Jan 2006
1 more thing guys, please make sure you reset to default on each and every page. Also remember to recalibrate gps/compass
Site Sponsor
Old Jul 14, 2012, 04:24 PM
Joined May 2011
Originally Posted by blade strike View Post
OK...
Basic
170/170/155/155
Altitude
120/120
So what were your original gains on the previous firmware? I'm just trying to determine why mine was swinging back and forth on 5.12 alhtough on all of the previous FW version, 100% was ok, I only changed the gain values before to make things perfect as opposed to avoid a total disaster.
Old Jul 14, 2012, 04:25 PM
Adidas4275 is offline
Find More Posts by Adidas4275
manual flying apologist
Adidas4275's Avatar
United States, CA, Fresno
Joined Mar 2011
are you using servos that are 90 degree or 180 degree servos.
if they are 90 degree servos then the old firmware already was allowing max travel for you (45 in each direction) and thus the new firmware will change nothing (it is a physical limitation with your gimbal and not a software issue)
if you are using 180 degree servos the there should be a different.
comprende?
Adidas4275 is offline Find More Posts by Adidas4275
Old Jul 14, 2012, 04:35 PM
Davebbb is offline
Joined Aug 2011
comprende?
yes the Gimble will allow the extra movement, but then as you point out, i must have 90 servos on it, the Servos came with the mount, and can find little to no specs for the servos, but obviously now, they are 90 then, will look around for some 180
cheers
Old Jul 14, 2012, 04:38 PM
Joined May 2011
cheers
If you have a servo tester, try pluing in your servos there so you're sure it's a servo issue and not something else.
On a separate note and again sorry to repeat...can any one advise on gain differences between previous version and 5.12? the swining behavior is really unusual and I don't want to ruin my copter by trial and error
Old Jul 14, 2012, 04:43 PM
Davebbb is offline
Joined Aug 2011
thanks will try,
on the note of gains pitch and roll seemd ok at the value they previously was, but the same value on yaw, was very soft, it was not locking as solid after centre stick.
started raining, so have not tested much other than that so far, but it didnt seem that bad really.
Old Jul 14, 2012, 04:44 PM
Joined Jan 2006
Originally Posted by iconflyer View Post
so what were your original gains on the previous firmware? I'm just trying to determine why mine was swinging back and forth on 5.12 alhtough on all of the previous fw version, 100% was ok, i only changed the gain values before to make things perfect as opposed to avoid a total disaster.
210/210/165/150
75/75
Site Sponsor
Discussion Ballistic Recovery System for Multirotors Duck! Aerial Photography 66 Nov 13, 2015 04:37 PM
Discussion DJI - WooKong eStab for Scale sidneyw Scale Helicopters 97 Dec 30, 2012 10:48 AM
Discussion FY3ZT Autopilot for Aerial Photography feiyudz Aerial Photography 116 May 07, 2012 04:58 PM
Discussion DJI AceOne autopilot for sale... hazchem88 Aerial Photography 4 Mar 31, 2011 03:54 AM
Discussion DJI Innovation helicopter autopilot XP.3.1 for European customers JoelT Aerial Photography 2 Sep 24, 2009 11:43 AM
