Old Feb 10, 2012, 08:29 AM
UAVProducts is offline
Find More Posts by UAVProducts
United States, MI, Goodrich
Joined Mar 2004
Small update:
The "top brass" have received the request and suggestion email I personally sent and they will take it into consideration. Lets not expect changes over night. However, DJI has always taken ideas into consideration and implemented them. From the XP 3.1 autopilots to the Ace One to present controllers etc.
This is a good thing lets be patient. I will post any updates I personally receive to the consumers as always.
Jumping off my soap box to get orders out and UAV's built. Actually, I really need to finish my coffee first.
UAVProducts is offline Find More Posts by UAVProducts
Old Feb 10, 2012, 09:21 AM
Rkopf is offline
Find More Posts by Rkopf
United States, CT, Oxford
Joined Jun 2011
Major confusion........
Can anyone give me detailed intructions on how to set up a switch on a Futaba 14MZ for RTH?
HELP!!!!!!
Rkopf is offline Find More Posts by Rkopf
Old Feb 10, 2012, 09:28 AM
robvree is offline
Find More Posts by robvree
Joined Nov 2011
Originally Posted by BorisSA View Post
How do you guys deal with no GPS lock down constant 3 red blinks ? I have a new GPS module hooked it up to a frame that already airborne and the GPS module before got GPS lock down in secs. Probably flew is now 30 mins in the garden taking up high so no further disturbance around, still no lock down. Never had this experience with the modules before !
Boris
Make sure the IMU is at least 3 inches away from the GPS.
robvree is offline Find More Posts by robvree
Old Feb 10, 2012, 09:52 AM
jovito is offline
Find More Posts by jovito
Trying to understand something
Argentina, CB, Córdoba
Joined Nov 2011
Here is my first video upload. Not good quality video and several nervous movements from a newbee pilot (me) but pretty smooth for this 1,3 kg bird.
Untitled (2 min 0 sec)
I was happy because finally could rid the jello effect.
Shooted with gopro on Gaui 500x + WKM.
Jo
jovito is offline Find More Posts by jovito
Old Feb 10, 2012, 10:08 AM
Frank.T is offline
Find More Posts by Frank.T
Frank.T's Avatar
Netherlands, ZH, Rotterdam
Joined Jul 2010
HELP!!!!!!
Go to functions, and select a switch on the output of your choice.
There will be something like Gear, Flap, AUX right now, touch that and you can select a switch or dial.
Frank.T is offline Find More Posts by Frank.T
Old Feb 10, 2012, 10:16 AM
jesolins is offline
Find More Posts by jesolins
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
Gents,
Just a thought: If the DJI flight controller module is causing enough EMF to knock out the GPS, then they really should shield both the flight controller module and the bottom of the GPS module with MuMetal or similar EMF shielding to prevent this. You might want to add that to the list...
For those with Android phones there are several similar free EMF detection and measuring applications that you can install from the Market to visually see the amount of EMF produced and to test the results of shielding or placement and braiding of the wires in order to optimize your GPS signal and compass accuracy. I use the Magnet-O-Meter. The EMF Hazards Detector and Max Magnetic Field Detector are good for this testing on multicopters too.
Cheers,
Jim
Quadrocopter and Tricopter Info Mega Link Index
jesolins is offline Find More Posts by jesolins
Old Feb 10, 2012, 10:24 AM
BorisSA is offline
Find More Posts by BorisSA
Austria, Wien, Vienna
Joined May 2011
Originally Posted by jesolins View Post
Gents,
Just a thought: If the DJI flight controller module is causing enough EMF to knock out the GPS, then they really should shield the module with MuMetal or similar EMF shielding to prevent this. You might want to add that to the list...
Cheers,
Jim
For me the issue is solved needed another hour on the balcony and got full lock down. Anthor start up it was picking up after a couple mins. Funny though since i never had these issue with my other two GPS module and this module was mounted on a frame that already had a full setup on it and back than not showing the same behavior.
Boris
BorisSA is offline Find More Posts by BorisSA
Old Feb 10, 2012, 10:28 AM
Rkopf is offline
Joined Jun 2011
Is there some sort of mix or something to program to make it work?
Old Feb 10, 2012, 10:43 AM
lrrps is offline
Find More Posts by lrrps
lrrps's Avatar
Le Havre, FRANCE
Joined Feb 2007
http://vimeo.com/36523539
Jo
Very nice, did you fly FPV?
lrrps is offline Find More Posts by lrrps
Old Feb 10, 2012, 11:22 AM
jovito is offline
Joined Nov 2011
Thanks Not still, do you?
I am interested in learn about and have some advices to do it.
Old Feb 10, 2012, 11:29 AM
Gredeby is offline
Find More Posts by Gredeby
Gredeby's Avatar
Kingdom of Sweden, Blekinge County
Joined Aug 2010
Hi, I just uploaded my first video, I certainly need some advice to improve
video and flight quality. It's a hexa, motors DT700 ,APC 11x4,7.
GOPR0119 (7 min 17 sec)
Gredeby is offline Find More Posts by Gredeby
Old Feb 10, 2012, 11:45 AM
lrrps is offline
lrrps's Avatar
Le Havre, FRANCE
Joined Feb 2007
I've flown FPV with planes but never tried with multirotors, I'm waiting for a VTX to arrive, I already have the FPV cam. and the ground station.
Old Feb 10, 2012, 12:58 PM
lrrps is offline
lrrps's Avatar
Le Havre, FRANCE
Joined Feb 2007
Maiden flight of my X-650M4 WookongM inside.
I tested the RTH function too.
Untitled (3 min 1 sec)
Old Feb 10, 2012, 02:54 PM
georgebinns is offline
Find More Posts by georgebinns
Multirotors blow
georgebinns's Avatar
Peterborough, England
Joined Dec 2006
http://vimeo.com/36558219
Well done for persevering Irrps - I never thought you were going to get there!!
George.
georgebinns is offline Find More Posts by georgebinns
Old Feb 10, 2012, 02:56 PM
Multirotors blow
Joined Dec 2006
Jo
Nice video Jovito - well done! How did you get rid of the Jello in the end?
George.
Discussion Ballistic Recovery System for Multirotors Duck! Aerial Photography 66 Nov 13, 2015 04:37 PM
Discussion DJI - WooKong eStab for Scale sidneyw Scale Helicopters 97 Dec 30, 2012 10:48 AM
Discussion FY3ZT Autopilot for Aerial Photography feiyudz Aerial Photography 116 May 07, 2012 04:58 PM
Discussion DJI AceOne autopilot for sale... hazchem88 Aerial Photography 4 Mar 31, 2011 03:54 AM
Discussion DJI Innovation helicopter autopilot XP.3.1 for European customers JoelT Aerial Photography 2 Sep 24, 2009 11:43 AM
