Old Feb 07, 2012, 12:33 PM
Gredeby is offline
Find More Posts by Gredeby
Gredeby's Avatar
Kingdom of Sweden, Blekinge County
Joined Aug 2010
You need only one BEC.
The size of the BEC is depending of amperage draw from servos.
5 or 7 amp are common size.
Gredeby is offline Find More Posts by Gredeby
Old Feb 07, 2012, 12:38 PM
quadman is offline
Find More Posts by quadman
California
Joined Nov 2009
14x4.7 APC props
4--normal rotation
4--CC rotation
$45 Shipped.
quadman is offline Find More Posts by quadman
lrrps is offline
Find More Posts by lrrps
lrrps's Avatar
Le Havre, FRANCE
Joined Feb 2007
I just feed my gimbal servos with an external 5A BEC, I only connect the signal wire of the synchros to F1 and F2, works fine.
lrrps is offline Find More Posts by lrrps
Old Feb 07, 2012, 12:42 PM
lrrps is offline
lrrps's Avatar
Le Havre, FRANCE
Joined Feb 2007
Does anyone use the WKM on an X650 quad?
The stock motors (Xairplane motors) have a square shape at the base of their axis, Xaircraft props fit but not other brands or do I miss something?
Old Feb 07, 2012, 12:48 PM
Paul@SCC is offline
Find More Posts by Paul@SCC
Chalfont St Giles, Bucks, UK
Joined Jan 2007
Nope, you have missed nothing. It is a ridiculous design.
Paul@SCC is offline Find More Posts by Paul@SCC
Old Feb 07, 2012, 02:02 PM
bitrush is offline
Find More Posts by bitrush
Joined Apr 2011
pick up your specialized props at cncheli.
bitrush is offline Find More Posts by bitrush
Old Feb 07, 2012, 02:53 PM
cougar2465 is offline
Find More Posts by cougar2465
cougar2465's Avatar
Joined Dec 2007
Originally Posted by Gredeby View Post
"BEC" means battery eliminating circuit.
Bigger servos for the camera rig can fry the PMU so you
better use a BEC to power the servos and only connect the signal conductor
from the servo to Wookong main contoller .
I am using maytech esc with power lead unpluged in my craft. Instead of using another bec for the two gimbal servos using Y harness, can I use two of the maytech becs to power the two servos using esc extension cable? I was thinking of removing the power lead of the extension cable on the servo side and plug in the power lead/pin from the Maytec esc.
cougar2465 is offline Find More Posts by cougar2465
Old Feb 07, 2012, 03:59 PM
jetbootz is offline
Find More Posts by jetbootz
jetbootz's Avatar
Australia, Lord Howe Island
Joined Jan 2010
just a quick one for the experts :
If I wanted to shield the GPS a little better using a copper plate under the antenna, am I supposed to solder a single wire from the copper plate to the negative of my battery harness? thanks
jetbootz is offline Find More Posts by jetbootz
Old Feb 07, 2012, 05:04 PM
helicoblast is offline
Find More Posts by helicoblast
Geneva, Switzerland
Joined Jan 2009
I love your video, very smooth flying.
Do you use the stock props, I found it impossible to use other brands of props because of the square shape below the motor axis threads.
Thanks, yes I'm using stock props for the same reason you're speaking about... I still have a bit of jello effect even with balanced props and motors, but I will change the gimbal soon, maybe that will solve my problem!
helicoblast is offline Find More Posts by helicoblast
Old Feb 07, 2012, 05:13 PM
Geneva, Switzerland
Joined Jan 2009
Originally Posted by Brombo View Post
Hey Helico, nice smooth flight!!
How can you take so nice calm video with the F450?
I have a setup like yours, can you please post a photo of your settings and share the parameters in the WooKong software to try if i have other kind of problems that lead me away from results like these...??
Anyway.. great result
My Multirotors
Hi Brombo, thanks for your comments!
You'll find here some pics of my setup:
http://www.rcgroups.com/forums/showp...postcount=8431
I'll post the parameters as soon as I've my laptop with me, hopefully tomorrow...
Old Feb 07, 2012, 07:00 PM
WaveV is offline
Find More Posts by WaveV
Joined Aug 2009
What is the newer GPS module? And are powering the gimbal from the FC?
WaveV is offline Find More Posts by WaveV
Old Feb 08, 2012, 12:34 AM
lrrps is offline
lrrps's Avatar
Le Havre, FRANCE
Joined Feb 2007
Thanks for your reply, stupid indeed but I think they did that on purpose.
Did you replace the motors, which one you recommend me to run on 4S.
Sorry for all these questions, I'm a newbie regarding multicopters.
Old Feb 08, 2012, 01:34 AM
Huddo is offline
Find More Posts by Huddo
Australia, SA, Adelaide
Joined Aug 2011
For anyone who is interested, I've got a droidworx frame with axi motors, plush esc and wookong-m controller on the classified page. http://www.rcgroups.com/forums/showthread.php?t=1588364
Huddo is offline Find More Posts by Huddo
Old Feb 08, 2012, 04:28 AM
jetbootz is offline
jetbootz's Avatar
Joined Jan 2010
pm'd you huddo
Old Feb 08, 2012, 07:13 AM
lrrps is offline
lrrps's Avatar
Le Havre, FRANCE
Joined Feb 2007
Guys,
I wanted to test my new quad in the living room, wait 'till light turns yellow (ATTI mode) then started the motors, found #3 not running until I applied more throttle then all motors turned.
Kept on applying throttle gradually then lamp turns red, even with throttle at max, the quad satyed on the ground, did I do something wrong?
M1 and M3 motors turn CCW view from the top, is that correct?
I asked because when M1 & M3 motors turned CW viewed from above, the quad violently yawed CW.
Discussion Ballistic Recovery System for Multirotors Duck! Aerial Photography 66 Nov 13, 2015 04:37 PM
Discussion DJI - WooKong eStab for Scale sidneyw Scale Helicopters 97 Dec 30, 2012 10:48 AM
Discussion FY3ZT Autopilot for Aerial Photography feiyudz Aerial Photography 116 May 07, 2012 04:58 PM
Discussion DJI AceOne autopilot for sale... hazchem88 Aerial Photography 4 Mar 31, 2011 03:54 AM
Discussion DJI Innovation helicopter autopilot XP.3.1 for European customers JoelT Aerial Photography 2 Sep 24, 2009 11:43 AM
