Old Jan 08, 2012, 09:40 PM
ScottPhoto is offline
Find More Posts by ScottPhoto
ScottPhoto's Avatar
United States, CT, Broad Brook
Joined Jul 2011
Originally Posted by WaveV View Post
Question? Is anyone using the primary battery to power there fpv setup?
Yes, I use it to power the immersion 600mv tx and the analog to DV converter.
ScottPhoto is offline Find More Posts by ScottPhoto
Old Jan 08, 2012, 10:47 PM
saabguyspg is offline
Find More Posts by saabguyspg
saabguyspg's Avatar
Calgary Canada
Joined Jun 2006
cabalerro did you remove the red wire from all your esc's?
Steve
saabguyspg is offline Find More Posts by saabguyspg
Old Jan 08, 2012, 11:22 PM
Rkopf is offline
Find More Posts by Rkopf
United States, CT, Oxford
Joined Jun 2011
Originally Posted by Rkopf View Post
I finally got the chance to go out and fly my hex for the first time, and I have to say that after trying to get an XA flying well, this was a dream. I powered it up and waited about 12 minutes for the 3 red blinks to go away, but they never did. I then flew around for a while in ATT mode, but I could never get any satellites, and just gave up after I went through 2 packs. It was a clear day in a big open field w/o obstructions or any nearby metal.
How about some help for a newbie guys?
I thought that was what this forum was for.
Rkopf is offline Find More Posts by Rkopf
Old Jan 08, 2012, 11:25 PM
BorisSA is offline
Find More Posts by BorisSA
Austria, Wien, Vienna
Joined May 2011
Rkopf can you post some pics of your setup. Might be that your gps modul is to close to some components that are disturbing it !
Boris
BorisSA is offline Find More Posts by BorisSA
Old Jan 08, 2012, 11:27 PM
BorisSA is offline
Joined May 2011
And did your digital compass kalibration work without any problems ? Just checkign with that if your connection to the GPS module is given and there is no connection problem. WKM also flies without the GPS module and would have the same effect red blinks etc.
Old Jan 08, 2012, 11:40 PM
Rkopf is offline
Joined Jun 2011
Calibration was no problem, LEDs on all components are correct, flies OK in ATT mode, just can't get any satellites!
Old Jan 08, 2012, 11:41 PM
Rkopf is offline
Joined Jun 2011
Sorry, picture didn't attach to last reply.
Old Jan 08, 2012, 11:48 PM
BorisSA is offline
Joined May 2011
hmmm very strange, you have it on the pole certainly far away from any components that could mess with it, connection it given otherwise the calibration wouldn't have worked.
Any window or balcony, garden you have your bird with props off standing for a while to check if you catch one less blink than 3 ?
Since the blinks only indicate a certain amount of sat locked and not that you havent locked any. Did you try switching it to GPS and if so what happened ?
sorry about the formulations and spelling very tired
Old Jan 08, 2012, 11:51 PM
BorisSA is offline
Joined May 2011
by the way maybe i am tired and blind but were is your IMU ?
Old Jan 08, 2012, 11:55 PM
BorisSA is offline
Joined May 2011
I would also place your RX somewhere else or at least not have your atennas attached to the carbon booms.
Check out the picture of the rx mounted on that AD
http://www.kopterworx.com/Jeti/Graup...T-mounting-set
You should do something similar and attache it to your landinggear having the antennas hanging down ! Best hot clue the antennas to have a somewhat 90 degree angle between them.
Old Jan 08, 2012, 11:58 PM
cabalerro is offline
Find More Posts by cabalerro
cabalerro's Avatar
Malaysia, Selangor, Seri Kembangan
Joined Jun 2011
Steve
yup...did removed the red wire from all esc's...but the setup did not using the distribution boards for all esc's..using dean connectors for all esc's, and 3.5mm bullet connector to motors...is this type of wiring ok?
cabalerro is offline Find More Posts by cabalerro
Old Jan 09, 2012, 12:01 AM
BorisSA is offline
Joined May 2011
best would be if you show your distribution setup !
i am confused what you mean with this ?
Old Jan 09, 2012, 12:08 AM
saabguyspg's Avatar
Calgary Canada
Joined Jun 2006
mmmm.... strange yes please send pictures.
deans for power to the esc and bullets to the motors is fine...
however as a personal opinion I don't like deans however this has likely nothing to do with your problem
Steve
Old Jan 09, 2012, 12:10 AM
saabguyspg's Avatar
Calgary Canada
Joined Jun 2006
try moving the gsp out onto a boom as far away as possible,
as you may or may not know your first lock will take the longest as it is getting a lock in a new location possibly for the first time in it's life... so expect a long wait for the first lock
Steve
Old Jan 09, 2012, 12:15 AM
BorisSA is offline
Joined May 2011
Steve
yeah but two lipo pack flight and no lock or certain amounts of sats is too long. But you might be right moving out to the booms is good.
Rkopf take the GPG modul off and place it somewhere on the frame temp and just test if you catch some sats.
Boris
Discussion Ballistic Recovery System for Multirotors Duck! Aerial Photography 66 Nov 13, 2015 05:37 PM
Discussion DJI - WooKong eStab for Scale sidneyw Scale Helicopters 97 Dec 30, 2012 11:48 AM
Discussion FY3ZT Autopilot for Aerial Photography feiyudz Aerial Photography 116 May 07, 2012 05:58 PM
Discussion DJI AceOne autopilot for sale... hazchem88 Aerial Photography 4 Mar 31, 2011 04:54 AM
Discussion DJI Innovation helicopter autopilot XP.3.1 for European customers JoelT Aerial Photography 2 Sep 24, 2009 12:43 PM
