Old Jan 08, 2012, 01:17 PM
badbill is offline
Find More Posts by badbill
Habitual Freeloader
badbill's Avatar
USA, GA, Centerville
Joined Dec 2002
[QUOTE=cafecubain;20359268]
Originally Posted by badbill View Post
Here are screenshots of my setup, and a video of the same Quad in position hold and return home. I have had no problems at all with gimble jitters.
Bill Davenport
AMA 28141
hi badbill
what esc's and motors that you use? I curious because I have a same frame XAircraft.
thanks!
I'm using the stock XA motors with Maytech 30 amp esc's. Graupner 11-5 props.
Bill Davenport
AMA 28141
badbill is offline Find More Posts by badbill
Old Jan 08, 2012, 02:15 PM
GGoodrum is offline
Find More Posts by GGoodrum
GGoodrum's Avatar
South Orange County, CA
Joined Mar 2003
One of the reasons you aren't noticing the "jitters" is because this mount has rotary dampeners, in each axis. I've noticed the same sort of jitter reduction with the MC6500PRO mount, which has similar dampeners. What also helps is the roughly 2:1 reduction in each axis. Still, if you look for it, you can still see the drifting, once the GPS is locked on.
I hear that DJI has identified the problem. It is because once the GPS data is factored in, it is causing a .1-.2 degree change in the IMU attitude data. they can fix this with a mod to the IMU firmware, but for obvious reasons, it would be much better to do something on the MC end to take care of this. A small, or maybe even settable, artificial dead-band adjustment for the gimbal outputs would certainly be one way. In any case, they are looking at this, so hopefully there will be a software update coming that will address this issue, sooner than later.
-- Gary
GGoodrum is offline Find More Posts by GGoodrum
Old Jan 08, 2012, 02:20 PM
Rkopf is offline
Find More Posts by Rkopf
United States, CT, Oxford
Joined Jun 2011
I finally got the chance to go out and fly my hex for the first time, and I have to say that after trying to get an XA flying well, this was a dream. I powered it up and waited about 12 minutes for the 3 red blinks to go away, but they never did. I then flew around for a while in ATT mode, but I could never get any satellites, and just gave up after I went through 2 packs. It was a clear day in a big open field w/o obstructions or any nearby metal.
Rkopf is offline Find More Posts by Rkopf
Old Jan 08, 2012, 02:29 PM
matthewlavin is offline
Find More Posts by matthewlavin
United States, CA, Santa Cruz
Joined Dec 2011
Originally Posted by Dronenor View Post
I am using Flight Mode and gear switch, this occupate only one channel, with this a have all tree nav modes on flight mode switch, and fail safe activating in each nav mode from gear switch
I have made 2 mixer setup for this, If someone intrested I can post pic taken of the diffrent mixing from my Spektrum Dx8
Please post a pic.
matthewlavin is offline Find More Posts by matthewlavin
Old Jan 08, 2012, 02:30 PM
milo12 is offline
Find More Posts by milo12
Joined Feb 2011
Nice job Gary, looks like your persistence paid off. Now that they have an idea what is causing the problem they should be able to fix it. I wonder how they didn't notice it while testing the new magic gimbal.
milo12 is offline Find More Posts by milo12
Old Jan 08, 2012, 02:46 PM
WaveV is offline
Find More Posts by WaveV
Joined Aug 2009
Question? Is anyone using the primary battery to power there fpv setup?
WaveV is offline Find More Posts by WaveV
Old Jan 08, 2012, 03:42 PM
Dronenor is offline
Find More Posts by Dronenor
Joined Jan 2012
Bill Davenport
AMA 28141
http://www.youtube.com/watch?v=3Aodv96McpE
Nice video!! I tried failsafe today with my Hexa, it flies like on rails, I can not say other than that I love this machine
But it seems that Dij have problems with the webpage server today, i like to try IOC?
My gimble works perfect too.
Dronenor is offline Find More Posts by Dronenor
Old Jan 08, 2012, 03:55 PM
liteglow is offline
Find More Posts by liteglow
Joined May 2005
I uploaded the new software 1.20 since the site is down.
http://www.sendspace.com/file/03wheh
try that :-)
cheers
liteglow is offline Find More Posts by liteglow
Old Jan 08, 2012, 04:16 PM
Dronenor is offline
Joined Jan 2012
Originally Posted by matthewlavin View Post
Please post a pic.
First you have to set travel adjust and then make 2 diffrent mixes, look at the picture att.
I hope DJI will come with pwm adjusted mode for all modes include IOC, then we need only use one singel channel for all modes. I have made 6 diffrent modes with this two switches earlier.
look in dji assistent for high lighted blue for every mode, if not trim a littel bit
I hope you enjoy it
Old Jan 08, 2012, 04:40 PM
liteglow is offline
Joined May 2005
is IOC mode worth to use flying FPV ?
sorry to ask but I did not quite understand the meaning with IOC...
Old Jan 08, 2012, 04:57 PM
Paul@SCC is offline
Find More Posts by Paul@SCC
Chalfont St Giles, Bucks, UK
Joined Jan 2007
I don't think you would FPV with it enabled.
This guy has produced a nice vid with it in action.
http://m.youtube.com/index?desktop_u...?v=QXmCirSGBC8
Paul@SCC is offline Find More Posts by Paul@SCC
Old Jan 08, 2012, 05:04 PM
cafecubain is offline
Find More Posts by cafecubain
cafecubain's Avatar
Spain (MÓlaga)
Joined Aug 2010
[QUOTE=badbill;20359474]
Bill Davenport
AMA 28141
thanks!
cafecubain is offline Find More Posts by cafecubain
Old Jan 08, 2012, 05:09 PM
Dronenor is offline
Joined Jan 2012
Intelligent Orientation Control (IOC), or carefree (MK) is good if you fly outside the visible range
Old Jan 08, 2012, 06:54 PM
Tahoe Ed is offline
Find More Posts by Tahoe Ed
DJI Support
Tahoe Ed's Avatar
Las Vegas/Lake Tahoe
Joined Feb 2010
It also works well for A/P as long as you remember to keep it in front of you.
Tahoe Ed is offline Find More Posts by Tahoe Ed
Site Sponsor
Latest blog entry: How to reload P3 firmware
Old Jan 08, 2012, 08:16 PM
cabalerro is offline
Find More Posts by cabalerro
cabalerro's Avatar
Malaysia, Selangor, Seri Kembangan
Joined Jun 2011
i don't know if anyone facing this situations...our quad flies well and smooth for few sessions...3-4 packs of 4S...when comes to the 4th battery, the quad flies wobbly and not stable to hover...expect that esc/motors overheat...tries to let it rest few hours and fly it again still the same behaviour...ended up reset everything, reflashed new firmware and start all over again..now hovering smooth again...face this same situation 2 times...without making any changes it suddenly wobble...
cabalerro is offline Find More Posts by cabalerro
Discussion Ballistic Recovery System for Multirotors Duck! Aerial Photography 66 Nov 13, 2015 04:37 PM
Discussion DJI - WooKong eStab for Scale sidneyw Scale Helicopters 97 Dec 30, 2012 10:48 AM
Discussion FY3ZT Autopilot for Aerial Photography feiyudz Aerial Photography 116 May 07, 2012 04:58 PM
Discussion DJI AceOne autopilot for sale... hazchem88 Aerial Photography 4 Mar 31, 2011 03:54 AM
Discussion DJI Innovation helicopter autopilot XP.3.1 for European customers JoelT Aerial Photography 2 Sep 24, 2009 11:43 AM
