Old Jan 07, 2012, 03:36 AM
topgearuk is offline
Find More Posts by topgearuk
topgearuk's Avatar
United Kingdom, London
Joined Dec 2003
Originally Posted by hexa View Post
Nice lil shed you you got there. Too bad mine lost its roof last week in the 100mph wind.
Yes think I've been lucky as there has been a lot of carnage, around but got away with-it, just a wobbly fence panel...
Originally Posted by nisouck View Post
Could you explain ......
It's a Rud - Rud mix I did take a photo of this setting and posted a few pages back, if you need help just ask.
Originally Posted by Paul@SCC View Post
topgear and Harrismagnum. Nice videos.
Cheers Paul
topgearuk is offline Find More Posts by topgearuk
Old Jan 07, 2012, 03:38 AM
topgearuk's Avatar
Joined Dec 2003
Originally Posted by Harrismagnum04 View Post
I have had some great tests of redundancy in the last few days, lost a prop completely and didnt even notice until i landed. A lady walking her dog came over with it. I then had a prop snap in flight, the octo started vibrating obviously so I landed with not problem, I also had a motor wire come off due to my bad soldering. Every time I had no problems landing and in fact in the case of the prop coming off I still caried on filming, the first part of this film with the Kayaks in was filmed with a Dex quad and Gaui FC the second part 1.56 on is with octo and DJI both on pretty windy days no camera stabilisation http://vimeo.com/34442210
Great video there!
Old Jan 07, 2012, 04:10 AM
Tokaz is offline
Find More Posts by Tokaz
Sverige, Stockholms Län, Värmdö
Joined Mar 2011
Hello
Flew my wookong hexa for a few days ago and it flew really nice. Yesterday in first lift off it wants to drift a lot to the right roll. I do a lot of sub trims to the left roll and then it flew good again. But does anyone know that went wrong?
The ground I started on was not completely straight, it leaned a little to the right when I hooked up the batteries. Fredde
Tokaz is offline Find More Posts by Tokaz
Old Jan 07, 2012, 05:49 AM
liteglow is offline
Find More Posts by liteglow
Joined May 2005
http://www.youtube.com/watch?v=X_luS...ature=youtu.be
liteglow is offline Find More Posts by liteglow
Old Jan 07, 2012, 05:58 AM
timecop is offline
Find More Posts by timecop
Joined Dec 2010
Originally Posted by liteglow View Post
ESC throttle calibrated wrong.
Fast beep means its receiving signal way out of bounds to what it was calibrated to. Wookong sends ~960?us as 'stop' pulse, you might want to trim throttle down a bit or use a servo tester to calibrate outputs exactly 1000..2000us
timecop is offline Find More Posts by timecop
Reply With Quote  (Disabled)
Old Jan 07, 2012, 06:13 AM
liteglow is offline
Joined May 2005
the trim is all the way down when I calibrate servo.
I dont have any servo tester!
Old Jan 07, 2012, 06:38 AM
liteglow is offline
Joined May 2005
Some one should have mention that all TRIM was supposed to be in center !
problem solved.... as I said before, it must have been some small text in the manual that I had missed.
thanx timecop for solving the problem :-)
Flying was OK..
-25 Degree Celsius outside, so I`m only flying inside for testing.
Anyway, it felt like I could add some more gain on the roll\pitch ?
It was very sensitive on the sticks, and when I hold it in my hand hovering, I could easy turn it.
This is usual ?
sorry to ask , but I have only used GU controller before, and that one was rock stable hovering in air!
Old Jan 07, 2012, 09:11 AM
farooq_niaZ is offline
Find More Posts by farooq_niaZ
Joined Aug 2010
Hi
When I start the motors the motors spin at different rate in attitude or manual mode in the beginning. Is it ok. I upgraded the firmware to 2.0 and 5.0. The quad flipped two times.
farooq_niaZ is offline Find More Posts by farooq_niaZ
Old Jan 07, 2012, 09:43 AM
llbr22 is online now
Find More Posts by llbr22
llbr22's Avatar
USA, CA, Oakland
Joined Nov 2009
Originally Posted by Rkopf View Post
Hi,
Quick question...
I had someone help me build this and does this picture look OK to people? Those are the receiver antenna wires tucked in a zip tie on top of one of the ESCs
I've had no problems with my antenna cable similar to this. But it wouldn't hurt to put space between the cable and the carbon like tony said.
But don't get too crazy about it. Unless your in a full carbon sailplane shell, futaba is pretty solid.
llbr22 is online now Find More Posts by llbr22
Old Jan 07, 2012, 09:48 AM
llbr22's Avatar
USA, CA, Oakland
Joined Nov 2009
Some one should have mention that all TRIM was supposed to be center!
Basic RC dude, center everything, clear mixes, curves, etc. when starting any new model.
Do you have any expo setup that might be causing the fast rates and twitchy feeling?
Old Jan 07, 2012, 09:51 AM
Dronenor is offline
Find More Posts by Dronenor
Joined Jan 2012
Ground Station Virus detected
Hi, first I have a hexa with dji wk, it flyes perfect with dslr and gopro mounted together. I have also byed a Ground Station. When I try to install it on a computer with Window7 and AVG virus controll, it detects virus in groundstation.exe. I have tryed o instal on several computers. Is there someone else have got the same issue?
Dronenor is offline Find More Posts by Dronenor
Old Jan 07, 2012, 10:06 AM
sidneyw is offline
Find More Posts by sidneyw
United States, NC, Huntersville
I use Norton and Avira, don't have the issue. AVG definitions might treat a non-threat file as virus. Disable AVG to install.
sidneyw is offline Find More Posts by sidneyw
Site Sponsor
Old Jan 07, 2012, 10:11 AM
freebyte is offline
Find More Posts by freebyte
Who dares wins
Deutschland, HE, Nidderau
Joined Oct 2011
Originally Posted by ~>Miha<~ View Post
Please discover the next functions by reading the manual like us idiots do as it would be a pity to see you nominated for the next Darwin Awards.
Guide me to the place in the manual where it read "arming motors will start motors." - I didn't found anything about it.
Oh, and gute Besserung... immer wieder schön wenn der Schmerz nachlässt, isn't it?
Danke :-) Laughing still causes some pain *fg*.
Bernd
freebyte is offline Find More Posts by freebyte
Old Jan 07, 2012, 10:18 AM
topgearuk's Avatar
Joined Dec 2003
Hi Sidney, Just sent you an email, if you could let us know if you got it.. Cheers
Old Jan 07, 2012, 10:34 AM
Dronenor is offline
Joined Jan 2012
If this is a real virus, it may be dangerous, but I will try to take a chance
Discussion Ballistic Recovery System for Multirotors Duck! Aerial Photography 66 Nov 13, 2015 04:37 PM
Discussion DJI - WooKong eStab for Scale sidneyw Scale Helicopters 97 Dec 30, 2012 10:48 AM
Discussion FY3ZT Autopilot for Aerial Photography feiyudz Aerial Photography 116 May 07, 2012 04:58 PM
Discussion DJI AceOne autopilot for sale... hazchem88 Aerial Photography 4 Mar 31, 2011 03:54 AM
Discussion DJI Innovation helicopter autopilot XP.3.1 for European customers JoelT Aerial Photography 2 Sep 24, 2009 11:43 AM
