Old Jan 04, 2012, 12:46 AM
Florentf31 is offline
Find More Posts by Florentf31
France, Midi-Pyrénées, Toulouse
Joined Nov 2011
Originally Posted by TimIndy View Post
Hi, Nice. What motors are you using?
I Use Dualsky 2834-CA10 (870kv) motors
Florentf31 is offline Find More Posts by Florentf31
Old Jan 04, 2012, 01:21 AM
Velociraptor73 is offline
Find More Posts by Velociraptor73
SMILE you're being recorded :)
Velociraptor73's Avatar
Joined Apr 2010
Any idea what cable colors must be swapped to invert motor direction?
Tried to invert the escs connectors that goes in the DJI controller for the motors that were spinning the wrong direction but that made that motors unresponsive and their escs didn't stop beeping!
Velociraptor73 is offline Find More Posts by Velociraptor73
Old Jan 04, 2012, 01:26 AM
cdi3d is offline
Find More Posts by cdi3d
Brushless
cdi3d's Avatar
Joined Mar 2009
you need to swap 2 of the 3 motor wires - not the esc connector
cdi3d is offline Find More Posts by cdi3d
Old Jan 04, 2012, 05:22 AM
Joined Apr 2010
It worked!
Old Jan 04, 2012, 07:30 AM
Tarro is offline
Find More Posts by Tarro
Long Island, New York
Joined Jun 2008
Do you have any RC experience?
Tarro is offline Find More Posts by Tarro
Reply With Quote  (Disabled)
Old Jan 04, 2012, 08:09 AM
cabalerro is offline
Find More Posts by cabalerro
cabalerro's Avatar
Malaysia, Selangor, Seri Kembangan
Joined Jun 2011
Just a short clip me and my partner of our quad with test flight session today with some raw clip from the camera. Apologize for my handheld camera works as i'm using my mobile phone.
Visualplex Aerial - Quadrocopter Test Flight 01 (1 min 33 sec)
You can always assign Elevator>Elevator to a switch of the radio channel mixing to get smooth forward move. And also Rudder>Rudder for panoramic capture.
cabalerro is offline Find More Posts by cabalerro
Old Jan 04, 2012, 08:48 AM
amalka is offline
Find More Posts by amalka
Česká republika, Hlavní město Praha, Praha
Joined Nov 2011
Can you explain this a bit? How do you mean it?
amalka is offline Find More Posts by amalka
Old Jan 04, 2012, 08:59 AM
topgearuk is offline
Find More Posts by topgearuk
topgearuk's Avatar
United Kingdom, London
Joined Dec 2003
http://youtu.be/pG-937KtTDY
Excellent idea, and have just done the rudder mix. Flick a switch and I now get a slow pan 360° in about 45seconds! Thanks for the idea! Now I won't keep hitting the throttle when doing a pan!
topgearuk is offline Find More Posts by topgearuk
Old Jan 04, 2012, 09:04 AM
cabalerro's Avatar
Joined Jun 2011
Thats GREATT !!! Easy and smooth rite! That is what I meant @amalka
Old Jan 04, 2012, 09:14 AM
topgearuk's Avatar
Joined Dec 2003
Go in to a free mix and do a mix with it's self! I'll take a picture, easier then trying to explain.
It's pretty cold out and therefore my fingers are shaking a bit sometimes when I fly, with this mix, just flick a switch and turn the gain up or down depending on speed!
Old Jan 04, 2012, 09:17 AM
cbergen is offline
Find More Posts by cbergen
Joined Jun 2004
Now THAT'S why these forums are such great places for info..Terrific!!
cbergen is offline Find More Posts by cbergen
cabalerro's Avatar
Joined Jun 2011
Spot On! Thanks for help out to explain...as it's almost midnight here and i'm off to bed..
Old Jan 04, 2012, 09:19 AM
topgearuk's Avatar
Joined Dec 2003
Thanks for the heads up!
Old Jan 04, 2012, 09:36 AM
nisouck is online now
Find More Posts by nisouck
Belgique, Région Wallonne, Braine-l'Alleud
Joined Dec 2008
Originally Posted by freebyte View Post
After using WKM since the beginning I never thought that anything from DJI could surprise me.
So I put the newest firmeware on the controller and the latest setup software on my laptop.
I reset and set carefully every parameter the upgrade instructions demands.
After this, I set the "start/stop motor" behavior to "immediately". According the manual, this is the procedure I like to see: pull throttle below 10% and everything is silent in every mode (which is fine because I have an emergency switch moving "gas" to minus 150 just to be sure - had already a serious accident with WKM where this didn't work in ATT/GPS mode).
After everything was set up, I moved all switches into "manual mode, no fail safe" and verified this via USB software control.
I gently moved the throttle stick, but nothing happened.
So I picked up my 2500 Gramm Quadkopter and put it on my desktop to check every cable.
After some pondering and reading the manual a flash of inspriration went though my brain - does the new software requires the "arm" movements of the sticks?
I carefully selected one of the stick-arm-movement which will keep the throttle below 10% and was surprised: my quad started all rotors.
Unfortunately it started on my desk with my face between the two back - and my monitor, records, keyboads, pills, gadgets and other stuff below the two front engines.
Well - at least my emergency switch worked.
I had a lot of fun with the emergency doctor and the responsible suregon when I told them my story.
They will take care of my scars in my face when they take the stiches off in 20 days.
I am not amused.
Bernd
I think it's necessary to read a manual ............. Is n't it?
nisouck is online now Find More Posts by nisouck
Old Jan 04, 2012, 10:33 AM
Drone Minds is offline
Find More Posts by Drone Minds
@saradroneminds
Drone Minds's Avatar
United Kingdom, York
Joined Apr 2011
Thanks for the head up freebyte, now I know not to arm my drone when my face is in between the props.
Drone Minds is offline Find More Posts by Drone Minds
Discussion Ballistic Recovery System for Multirotors Duck! Aerial Photography 66 Nov 13, 2015 05:37 PM
Discussion DJI - WooKong eStab for Scale sidneyw Scale Helicopters 97 Dec 30, 2012 11:48 AM
Discussion FY3ZT Autopilot for Aerial Photography feiyudz Aerial Photography 116 May 07, 2012 05:58 PM
Discussion DJI AceOne autopilot for sale... hazchem88 Aerial Photography 4 Mar 31, 2011 04:54 AM
Discussion DJI Innovation helicopter autopilot XP.3.1 for European customers JoelT Aerial Photography 2 Sep 24, 2009 12:43 PM
