Groundstation Software won't launch
I just got my WKM Groundstation package and I have run the installs on two different laptops but when I attempt to launch Groundstation it displays the splash screen then hangs with the dialog: DJIGroundStationVer4.exe has stopped working.
Any ideas/thoughts? |
Las Vegas/Lake Tahoe
Joined Feb 2010
Disable your antivirus software and any programs that are running in the background. Also you did not state what operating system that you are using. I am using XP on a dedicated netbook with no A/V. It loads without an issue. Also did you activate the GS in Assistant. You need a new S/N to activate View and Click and Go, if you purchased that option.
Japan, Tokyo, Chiyoda
Joined Oct 2010
llbr22 > thank you for your reply, although I am not very sure if it means DIJ is the proper gear to do AP or not
do you have experience with other FC like MC ? do you build yourself ? do you find DIJ more steady or easier than other rigs ? do you fly with quad/hex or octo ? |
Should I have received the code with the box or is that something my dealer is supposed to be giving me. I couldn't find a manual on the CD-ROM even though it says it includes one. I did find it at the DJI site. I'm clueless about the activation process so any help in this regard would be appreciated. |
Need some help with installing Driver Setup .Bat File
Happy New Year everybody,
I need some help on my initial installation of the Driver Setup. Bat file. I have followed the instructions as they are written here: Software and Driver Installation STEP1: Please download assistant software and driver from our website. If your operating system is 32bit, download 32bit driver; if your operating system is 64bit, download 64bit driver. Then decompress; STEP2: Connect MC and PC via USB cable, power on MC; STEP3: If operating system tries to install driver automatically,cancel it. STEP4: Open folder DJI_Wookong_M_Driver_32bitor DJI_Wookong_Multi_Rotor_Driver_64bit, double click DriverSetup.batfile and follow the steps to finish installation. STEP5: Open the assistant software folder, double click Setup.exefile and follow the steps to finish installation. The problem occurs when I double click on the Driver Setup. Bat file, there is a quick flash of a black DOS window for about a half second then nothing. No other instruction screens are shown. The directions clearly state to follow the steps to finish the installation but there are no further steps presented. I also triued this after disabling my virus protection, but it made no difference. Oh, and I am running Wwindows XP on my laptop. I have installed the Assistant Software, but the button to update the firmware, along with many of the other button on the top of the first screen are darkened & not available. I’m Assuming that this may be because the problem with the Driver Setup. Bat file, but I don’t know for sure. Any help would be appreciated. Thanks, Tom EDIT: Thanks to Steve, Saabguyspg, my problem is solved. I had forgotten to export the unzipped files to a directory OUTSIDE of the Zip program which caused the USB drivers to not install properly. |
http://www.rc-flysoft.com/pages/switch10_e.htm //Frank |
I'm just not sure if any multi will accomplish what you're trying to do "controled composition and sharp focus with low DOF" http://www.rcgroups.com/forums/showthread.php?t=1351104 Often, the best bokeh is achieved by getting close to a subject, and I'm not sure how close you want to get to any given subject. I'd like to try it myself.. maybe later this week using my GH2. Although I don't think it's the best still photography camera, the 20mm lens can look good:
Joined Oct 2010
llbr22 > thank you for your reply again, it is more clear for me
![]() I have some basic FC for training but I am looking for a high end platform to have extra stability. As you have read, I am looking for precise framing and low DOF, that will be trough longer lens, 135mm f2.0 or 85mm 1.8 for example. Due to the long mm I need extra stable platform. I will also shoot wide angle, but in that case no small DOF is possible for sure, I wont get within cm of the subject
| Thread Tools | |
| Discussion Ballistic Recovery System for Multirotors | Duck! | Aerial Photography | 64 | Mar 22, 2013 11:13 AM |
| Discussion DJI - WooKong eStab for Scale | sidneyw | Scale Helicopters | 97 | Dec 30, 2012 10:48 AM |
| Discussion FY3ZT Autopilot for Aerial Photography | feiyudz | Aerial Photography | 116 | May 07, 2012 04:58 PM |
| Discussion DJI AceOne autopilot for sale... | hazchem88 | Aerial Photography | 4 | Mar 31, 2011 03:54 AM |
| Discussion DJI Innovation helicopter autopilot XP.3.1 for European customers | JoelT | Aerial Photography | 2 | Sep 24, 2009 11:43 AM |
