Canada, ON, Toronto
Joined Jul 2011
Since you have a upgraded firmware ( default the gimbal page re-enter values) see if it's works. disconnect all power cycles - Start all over again …. Shiu |
Joined Nov 2011
You may try set the center of the servo in the software. Default is 0. Change the value to make the servo in the middle of its travel range. Then the auto stab may work. |
Southampton, Ontario CA
Joined Feb 2005
Has anyone done any comparrison testing of the WKM with stock escs and SimonK's hex file reflashing? I have 6 stock HK blue series 30a escs that could be reflashed but if they work well as stock, I'll leave them as is and play with some RCT escs.
Not sure it could be fully due to GPS tho it seems to be repeatable as others mentioned but even on older firmware I did see this twitching. One time I accidentally forgot to connect the GPS after remounting it and flew. it was one of my smoothest flight/vid. If you ask why I flew without GPS lock, it just stopped raining and pretty cloudy / gloomy so I thought it was just that it couldn't really get sat. after the flight I did see smooth video but when panning you can see slight twitching. When I relaized i've had my GPS disconnected I tried to prove it, remove the GPS but there are no physical difference maybe slight twitchy with GPS on but could be the wind.
Still waiting for my naza and I plan to try the same mount |
United States, IN, Westfield
Joined Sep 2007
WK-M and X468 camera gimbal
There has been a lot of talk about the gimbal stabilization and twitching. Also saw something about twitching when the GPS signal is set. Below is a boring video that shows the WK-M with the gimbal stabilization set up. I am flying in a lot of wind. Since I've also seen a bunch of people not believe how strong the wind is, I flew this around my weather station instrumentation on the roof. You can also hear the wind. The camera is a GoPro that I Velcro to the camera mount. There is not post production stabilization, just raw video.
Oh yeah, I did have twitching on servos before I changed them out for Savox sh-0262mg servos. Now it is smooth as silk. With a 5000MAH pack I am getting 8:30 flying time on my vector 550 frame.
Lou |
I could be wrong but I think some of the wobble on the video are the twitch 0:41 or 2:10 and some other parts I meant no disrespect it could be that twitch is being masked. But you are quite right the wind is blowing quite hard. I envy you as I see less vibration on your gopro with that wind. If it has been calmer it would have been a smooth.
Joined Sep 2007
There isn't any twitching. I could create another video showing the gimbal but that would be even more boring. I created a video of the twitch when I first saw it, but I can't find it to show you what it looked like. It was a constant stepping back and forth in both axis. The winds today were wild. I attached a view of my weather station for winds. Look bewteen noon and 3:00PM. Not only were they very gusty, but the direction was changing quite a bit. I had the twitch early on when I was using Hitec and futaba servos. The Savox solved the twitch.
Lou |
-- Gary |
Indonesia
Joined Jul 2005
| Thread Tools | |
| Discussion Ballistic Recovery System for Multirotors | Duck! | Aerial Photography | 64 | Mar 22, 2013 11:13 AM |
| Discussion DJI - WooKong eStab for Scale | sidneyw | Scale Helicopters | 97 | Dec 30, 2012 10:48 AM |
| Discussion FY3ZT Autopilot for Aerial Photography | feiyudz | Aerial Photography | 116 | May 07, 2012 04:58 PM |
| Discussion DJI AceOne autopilot for sale... | hazchem88 | Aerial Photography | 4 | Mar 31, 2011 03:54 AM |
| Discussion DJI Innovation helicopter autopilot XP.3.1 for European customers | JoelT | Aerial Photography | 2 | Sep 24, 2009 11:43 AM |
