Old Dec 04, 2011, 07:20 AM
jetbootz is offline
Find More Posts by jetbootz
jetbootz's Avatar
Australia, Lord Howe Island
Joined Jan 2010
thanks for responses. I have decided to dismantle and put the DJI on the x650V again and play around with that.. I am not sure what is causing the problem, maybe an esc ? . I have a spare TX so will change that around too. I did try normal arming mode and nothing happended also. very strange..
jetbootz is offline Find More Posts by jetbootz
Old Dec 04, 2011, 07:42 AM
flashervn is offline
Find More Posts by flashervn
Joined Sep 2011
I got a bad crash today on my new frame. Lost 3 props, 3 arms and 4 motors ( they got clicking noise after the crash) and posibly GPS modul.
DJI WKM, firmware 4.2 on a Hexa, 6 pulsso 2814/20; APC 12x3.8, 30A Mystery Esc,4s 5000, FPV cam + video Tx
I did a test fly yesterday without gimbal and landing gear, all went perfect. I went though 7 packs on it.
Today I installed the landing gear and AV200, a second video TX, took it out and crash on second take off. Here 's what happened:
1.I took it of in GPS mode ( full lock, 1 purple light). Hovered for about a minute, it was solid. Slow flying around, I noticed 2 white flashes, ignored as I ve seen them before on the old frame, flew for another 30 secs and landed. Gimbal was visibly working at this point on both roll and pitch.
2. Took off the second time to about 3 meter above the ground. Immidiately it start flying all over the place and very unresponsive to my stick input, then crashed.
Possibly the second Vtx which I put ontop of the gimbal and right underneath the IMU caused some interference? The 1st Vtx for FPV is on an arm and is 10cm away from the IMU.
After the crash, I dont get a lock anymore eventhough the GPS disc didnot take any direct hit. It got knocked off the pole which was mounted by some adhesive tape. Is there anyway to check if it is still getting or sending signal? Anyone get their GPS working again after a crash?
I ve also noticed for the first time that my IMU has a green flashing led inside the cover. Anyone with a working DJI can confirm that the IMU greenlight flash 9 times with a 3 seconds interval? ( you need to turn all other light off to see it as the green light is flashing inside the IMU case)
Lastly anyone had experience with DJI 's service? Do they offer to test and repair your unit? Can I buy the just the GPS module alone?
Can WKM fly in atti mode without the gps?
Thanks guys
flashervn is offline Find More Posts by flashervn
Old Dec 04, 2011, 09:16 AM
freethy is offline
Find More Posts by freethy
Joined Nov 2007
Having spent some time being fortunate to configure and test a wookong multi for a friend of mine I have to say that the out of the box performance is about the best I've seen.
My last Autopilot used to do whatever it wanted...
Description:
freethy is offline Find More Posts by freethy
Old Dec 04, 2011, 09:52 AM
timecop is offline
Find More Posts by timecop
Joined Dec 2010
Should be able to. For some unknown reason they're not using mag in atti mode (so no yaw/heading hold), so it *should* be flyable without GPS module connected.
When I had it on my desk testing, i saw motor outputs move even without GPS connected. I'd recommend taking the remaining non-broken props off before testing this though
timecop is offline Find More Posts by timecop
Reply With Quote  (Disabled)
Old Dec 04, 2011, 10:00 AM
Joined Sep 2011
Thanks TC.Props are off. New set of 10x4.7 are on now cause I ran out of 12x3.8s.
Hmm, one more thing I should mention is that I had the IMU on the bottom plate and the top half of it prodtrude through the hole on the second plate. Not sure it affected the flight characteristic cause I had it fly just fine during the maiden flight.
Old Dec 04, 2011, 10:05 AM
ScottPhoto is offline
Find More Posts by ScottPhoto
ScottPhoto's Avatar
United States, CT, Broad Brook
Joined Jul 2011
Originally Posted by llbr22 View Post
I totally screwed up my camera exposure and focus, but here is some practice flying from yesterday. Trying to get a series of rehearsed camera motions together.
http://www.youtube.com/watch?v=fp585f9TqrU&sns=em
Wow, nice smooth flight. I'd say the gimbal passed the test!
ScottPhoto is offline Find More Posts by ScottPhoto
Old Dec 04, 2011, 10:06 AM
timecop is offline
Joined Dec 2010
I don't think that matters as long as you entered close enough offsets from CG in the X/Y/Z distances for IMU position. Though I'm not sure how much of a difference a couple cm error can cause. When I was on phone with DJI about getting white flashes, I was told to hard-tie the IMU to the frame - I had it velcro'd and it was getting white flashes, I was told to run a ziptie across it to make sure it doesn't move at all and that fixed white blinks. And yes, green led does blink or light inside the IMU but I forgot how many times - I do remember there was some kinda internal led.
Old Dec 04, 2011, 10:12 AM
Joined Sep 2011
Alright. So the green led doesnt mean that my IMU is giving out some sort of error code. I think my CG measurement was ok when it had no load attached but I think I didnt enter anything different after putting the gimbal and stuff on. Do you ever heard of Video Tx creating problem for flight controls?
Old Dec 04, 2011, 10:13 AM
ScottPhoto's Avatar
Joined Jul 2011
Originally Posted by furyphoto View Post
ScottPhoto, Yank that HDMI converter out of the case, and lose about 150 grams in weight. Just get some 3" shrink wrap to protect it.
http://www.aplanding.com/forums/show...7&postcount=13
-Andrew
Yeah, I should do that. Where can I get some decent heavy duty shrink wrap?
Old Dec 04, 2011, 10:33 AM
keith.uk is offline
Find More Posts by keith.uk
Joined Nov 2011
That's very nice. You have some very fluid movement there. Was that with an AV130 and GH2? Did you do much stabilization in post?
keith.uk is offline Find More Posts by keith.uk
Old Dec 04, 2011, 10:50 AM
exopackshiu is offline
Find More Posts by exopackshiu
Canada, ON, Toronto
Joined Jul 2011
Attachment 4462467
Please! post a Video i would love to watch it….
exopackshiu is offline Find More Posts by exopackshiu
Old Dec 04, 2011, 11:52 AM
VonDougage is offline
Find More Posts by VonDougage
Akron, Ohio
Joined Oct 2009
TimeCop....thanks for your advice. One last question, which OSD do you recommend that works well with the DJI M. I want to get it right the first time.
Doug
VonDougage is offline Find More Posts by VonDougage
Old Dec 04, 2011, 12:24 PM
jovito is offline
Find More Posts by jovito
Trying to understand something
Argentina, CB, Córdoba
Joined Nov 2011
Yes, I have heard about that and the distance fron VTX has to be as much as possible, even when the frequencies are not in the same band. I am almost sure this was the cause of your crash. I am sorry about it.
jovito is offline Find More Posts by jovito
Old Dec 04, 2011, 12:34 PM
RTRyder is offline
Find More Posts by RTRyder
Registered Lunatic
RTRyder's Avatar
Boston, MA
Joined Jul 2010
CineStar 6 at the Sheep Pasture
Sheep Pasture.mts (2 min 31 sec)
CineStar 6 frame, DJI Wookong-M flight controller, AXI 2814-22 motors, Graupner props, PhotoHigher AV130 camera mount, Sony NEX 5N camera
Recorded in Easton, Massachusetts 12-4-2011
RTRyder is offline Find More Posts by RTRyder
Old Dec 04, 2011, 01:45 PM
bendicks is offline
Find More Posts by bendicks
bendicks's Avatar
USA, CA, Pollock Pines
Joined Jan 2011
Originally Posted by RTRyder View Post
http://www.youtube.com/watch?v=qG_BmNcz264
Really nice vid, great scenery, nice background soundtrack. I've used the same one for my nature fly through vids also, adds that nice relaxed feeling to the video.
-Don
bendicks is offline Find More Posts by bendicks
Discussion Ballistic Recovery System for Multirotors Duck! Aerial Photography 66 Nov 13, 2015 04:37 PM
Discussion DJI - WooKong eStab for Scale sidneyw Scale Helicopters 97 Dec 30, 2012 10:48 AM
Discussion FY3ZT Autopilot for Aerial Photography feiyudz Aerial Photography 116 May 07, 2012 04:58 PM
Discussion DJI AceOne autopilot for sale... hazchem88 Aerial Photography 4 Mar 31, 2011 03:54 AM
Discussion DJI Innovation helicopter autopilot XP.3.1 for European customers JoelT Aerial Photography 2 Sep 24, 2009 11:43 AM
