Australia, ACT, Canberra
Joined Apr 2011
Fail safe setup
Can you please run thru how you setup switch "A" on your 9C to enable FS Thanks |
Joined Feb 2007
Hi,
Thanks for posting your video. What happens failsafe-wise if you simulate a Tx faliure by turning off your Tx? Scenario 1 is you have a Rx failsafe setup as you should to put the ch3 throttle to just below hover and all other channels to neutral. Scenario 2 is you lose power to the Rx. What will the DJIWKMQ do? I would suggest a re-think of your module mounting. Having the controller module mounted on top of the IMU no-doubt is inducing vibrations. That and improper neutral stability and prop/motor balance are things to check to get rid of theTBE. Yes TC has now proven that there is a battery backup on the UBLOX GPS. So if you do not get a quick under 30 second lock after re-powering from a flight, then it points to Rf issues (use a shield), or a bad GPS backup battery. Cheers, Jim Quadrocopter and Tricopter Mega Link Index Quote:
Joined Feb 2007
TC,
What is the huge current draw? The LED driver? Cheers, Jim Quadrocopter and Tricopter Mega Link Index |
Joined Feb 2007
Hi,
How did you have your Rx failsafe set? Would it auto-land in this situation? Cheers, Jim Quadrocopter and Tricopter Mega Link Index |
Go to advanced menu 2 select PROG.MIX1-6 select mix 1 (OFST AUX1) put the rate at something around 47% Master = OFST Slave = CH7 Change mix from INH to OFF LINK = OFF Sw (choose what switch you want) I chose SwD POSI = whatever position you want it to be "ON" thats it! |
Latest blog entry: Triggering a Canon camera via usb
LED = almost nothing (surprisingly?), GPS, 100mA, and the rest is BEC in my ESC + MainController, which shouldn't be much really. I've also updated the blog with details about IMU and pressure sensor. |
+1 yep, i checked that I love to see surgery ops_ good job by the way on the analysis of the beast Seems like a well written code and a nice thought assembling design can make the difference (regarding components which seem to be common)Cheers PS: and yes, old PPM input would be great, please! (my TGY9x + frsky stuff are on the way here!) |
Joined Dec 2010
Well was on my way to better results but then one of my esc's fried. I need to wait for the power module.
Would be nice to have two configuration slots so we can choose between windy/calm, light/heavy settings with a spare channel. Or even better have the MC auto select between the two. Anyone with an AV200 pan kit? Do you find that the legs handle the weight of the craft comfortably? I am considering the new retractable legs from Droidworx. |
| Thread Tools | |
| Discussion Ballistic Recovery System for Multirotors | Duck! | Aerial Photography | 64 | Mar 22, 2013 11:13 AM |
| Discussion DJI - WooKong eStab for Scale | sidneyw | Scale Helicopters | 97 | Dec 30, 2012 10:48 AM |
| Discussion FY3ZT Autopilot for Aerial Photography | feiyudz | Aerial Photography | 116 | May 07, 2012 04:58 PM |
| Discussion DJI AceOne autopilot for sale... | hazchem88 | Aerial Photography | 4 | Mar 31, 2011 03:54 AM |
| Discussion DJI Innovation helicopter autopilot XP.3.1 for European customers | JoelT | Aerial Photography | 2 | Sep 24, 2009 11:43 AM |
