Old Sep 23, 2011, 11:52 PM
furyphoto is offline
Find More Posts by furyphoto
Posting, but should be working
furyphoto's Avatar
Brackendale, BC, Canada
Joined Sep 2006
If anyone is interested, here is a video from my failsafe tests a week or so ago.
DJI WK-M Fail Safe RTH Flight Tests (7 min 19 sec)
At the time, a good, but not stellar performance. Better than a crash landing, but I wouldn't want a landing like that with my DSLR on Board.
furyphoto is offline Find More Posts by furyphoto
Old Sep 24, 2011, 12:05 AM
ThaiskyDigital is offline
Find More Posts by ThaiskyDigital
Thailand
Joined Apr 2006
Originally Posted by Kipkool View Post
Dunno if it had been solved already here, but for those who runs Windows 7 64 bit, you can still install the "driver". The so called one is just a fake driver, an inf which define a virtual com port.
You just have to replace the 32bit dpinst.exe by a 64 bit version.
It's on Microsoft Driver software kit, but you can take it from here ( attached ).
Thanks a lot, I search and found this answer, now I can do it.
If any of you can not do it let me know I can make a step by step explain.
Thanks to timecop also.
ThaiskyDigital is offline Find More Posts by ThaiskyDigital
Old Sep 24, 2011, 12:32 AM
redridinghood is offline
Find More Posts by redridinghood
Joined Dec 2010
Have finnaly set up the DJI WKm on a Gaui 500x. One of the stock Gaul 10 amp esc is extremely hot, so only test flown a few times.
I like the vario altitute and the altitute hold. But the GPS hold toilet bowl is a big problem. Have used tv antenna foil on the cables and even a large copper plate to shield the GPS unit. The bowl is still there. I can imagine the side impact force of an auto land you kill most droidworx legs and damage gimbals.
Now if only my droidworx octo was here...
redridinghood is offline Find More Posts by redridinghood
Old Sep 24, 2011, 12:49 AM
Hypam is offline
Find More Posts by Hypam
Joined Jul 2011
@furyphoto: something is def. wrong with your setup.
I triggert the fail-safe for two times because my f***g radio got some drift in the channel and both times it came down perfectly straight, without doing any circles, hell i was so good i might get used to that.
Hypam is offline Find More Posts by Hypam
Old Sep 24, 2011, 01:43 AM
timecop is offline
Find More Posts by timecop
Joined Dec 2010
You need the power module.
Standard current draw of wkm is 600+mA
timecop is offline Find More Posts by timecop
Reply With Quote  (Disabled)
Old Sep 24, 2011, 02:22 AM
protowax is offline
Find More Posts by protowax
Discipulus est prioris posteri
Joined Jun 2011
http://vimeo.com/29513268
I tested it yesterday several times (it was windy) and for me it was very smooth... perhaps it is a question again of motors/esc or gains....
protowax is offline Find More Posts by protowax
Old Sep 24, 2011, 03:15 AM
Borneoben is offline
Find More Posts by Borneoben
United States, TX, Houston
Joined Jan 2005
Is it possible to regain control after the failsafe RTH has been initialised?
e.g.
If the WKM goes into fail safe what happens when you flip OUT of fail safe?
Does the WKM hold its current position or what?
Cheers
Ben
Borneoben is offline Find More Posts by Borneoben
Old Sep 24, 2011, 03:53 AM
quad master is offline
Find More Posts by quad master
UavRotorKing.com
United States, CA, Yorba Linda
Joined Sep 2010
e.g.
Cheers
Ben
that is a great question i would like to know myself /
quad master is offline Find More Posts by quad master
Old Sep 24, 2011, 03:55 AM
sidneyw is offline
Find More Posts by sidneyw
United States, NC, Huntersville
That's about the same from a digital tail servo on Trex 600, less than cyclic servos in FBL setup.
sidneyw is offline Find More Posts by sidneyw
Site Sponsor
Old Sep 24, 2011, 03:59 AM
sidneyw is offline
e.g.
Cheers
Ben
To regain radio control, flip the mode switch from manual to GPS.
Site Sponsor
BorisSA is offline
Find More Posts by BorisSA
Austria, Wien, Vienna
Joined May 2011
Hmm now i am confused. Got myself a S-bus setup yesterday Futaba R6208 SB and a HFM12-MX RASST for my Graupner MX-22, luckily I can trade this stuff in again. I don't see a usable failsafe option for WK-M that the Futaba R6208 SB actually supports.
The R6208 gives two options for FS/Hold-Mode.
1. Holde mode on all channels - not usable.
2. Programmable throttle position dedicated to the throttle channel - cant assign this to channel 5 for flight modes Manual / Attitude / GPS incase of signal loss FS.
So this whole statement S-bus futuba is the way to go for Failsafe hmm anyone got a clue were I am wrong or misunderstood something?
Boris
BorisSA is offline Find More Posts by BorisSA
Old Sep 24, 2011, 04:13 AM
llbr22 is offline
Find More Posts by llbr22
llbr22's Avatar
USA, CA, Oakland
Joined Nov 2009
e.g.
Cheers
Ben
It goes back to the throttle and control input your giving it. I tested this by Turning my tx off, letting it hover a bit, then turning it back on.
llbr22 is offline Find More Posts by llbr22
Old Sep 24, 2011, 04:23 AM
llbr22 is offline
llbr22's Avatar
USA, CA, Oakland
Joined Nov 2009
Boris
For s-bus, my 'non hold' parameters are set in the radio (8fg) itself, not the receiver. Does the graupner support failsafe settings?
Old Sep 24, 2011, 04:28 AM
BorisSA is offline
Joined May 2011
It does but it does not give a menu for failsafe in PPM mode only PCM or SPCM. With the Jeti although PPM it was easy over the Jeti Box.
Old Sep 24, 2011, 04:30 AM
timecop is offline
Joined Dec 2010
Looks like yet more reasons to implement PPM.
Discussion Ballistic Recovery System for Multirotors Duck! Aerial Photography 66 Nov 13, 2015 04:37 PM
Discussion DJI - WooKong eStab for Scale sidneyw Scale Helicopters 97 Dec 30, 2012 10:48 AM
Discussion FY3ZT Autopilot for Aerial Photography feiyudz Aerial Photography 116 May 07, 2012 04:58 PM
Discussion DJI AceOne autopilot for sale... hazchem88 Aerial Photography 4 Mar 31, 2011 03:54 AM
Discussion DJI Innovation helicopter autopilot XP.3.1 for European customers JoelT Aerial Photography 2 Sep 24, 2009 11:43 AM
