Thanks Endofdays, I've been looking at those same motors (HK), think I saw them in one of your other posts, what a shame about not having a good solution for mounting a prop on them. So close to pulling the trigger on 4, was thinking for my Eciolp!? Running 6s with 14x8 props.
Have you had a chance to fly that set-up yet? I wonder how they compare to my TM2814-10? |
Here the maiden:
and here as part of a "special operations" team carrying the Z15:
best regards Ferdinand |
![]() All using them same motors!? Any reason you don't use the supplied prop adaptor? |
Yes, most of my copter have these motors, I like them, the never failed so far, so there is no reason for me to switch.
You will not get happy when mounting a 14" prop with an adapter on a 3mm shaft. You also can balance the props as good as possible, but these adapters are a reasonable source for vibrations, since they are not centered enough (not for a 14" prop). The more direct the prop is mounted on the motor-bell, the better. Also the lower the props are above the mounting on the arms, the less torsion (caused by vibration) can be induced. best regards Ferdinand |
Joined Feb 2011
Today I had a crash with my S800 and Z15g onboard. WKM had 5.18 FW loaded.
Here is the video of the crash. It started to spin so violently that 2 battery packs were thrown out of the tray. Thats why camera stopped recording and copter fell on the ground. Anyone have any idea what could be the cause of the spin? It was in GPS mode, when spinning I went to ATTI and manual, but it didn't help.
| Thread Tools | |
| Discussion Ballistic Recovery System for Multirotors | Duck! | Aerial Photography | 64 | Mar 22, 2013 11:13 AM |
| Discussion DJI - WooKong eStab for Scale | sidneyw | Scale Helicopters | 97 | Dec 30, 2012 10:48 AM |
| Discussion FY3ZT Autopilot for Aerial Photography | feiyudz | Aerial Photography | 116 | May 07, 2012 04:58 PM |
| Discussion DJI AceOne autopilot for sale... | hazchem88 | Aerial Photography | 4 | Mar 31, 2011 03:54 AM |
| Discussion DJI Innovation helicopter autopilot XP.3.1 for European customers | JoelT | Aerial Photography | 2 | Sep 24, 2009 11:43 AM |
