Old Feb 05, 2013, 08:16 AM
archet is offline
Find More Posts by archet
Mozambique, Maputo City, Maputo
Joined Sep 2012
Originally Posted by Psionic001 View Post
One or more motors are not vertical, inducing a yaw. The two opposite motors of your quad that heat up are spinning much harder to fight that yaw.
Straiten your motors and they will cool down.
I checked the motors but they are almost perfectly vertical, I cannot see any visible relevant angle with the vertical axes of all motors.
archet is offline Find More Posts by archet
Old Feb 05, 2013, 08:27 AM
MCrites is offline
Find More Posts by MCrites
I never finish anyth
United States, TX, Houston
Joined Jan 2012
Is it perfectly balanced?
MCrites is offline Find More Posts by MCrites
Old Feb 05, 2013, 11:04 AM
jjos99 is offline
Find More Posts by jjos99
Joined Jan 2009
dont know if this is of any help but I was reading way back in this thread of an issue with some of the software versions that were causing some of the motors/esc to overheat and causing crashes.
jjos99 is offline Find More Posts by jjos99
Old Feb 05, 2013, 01:23 PM
Buffythesaint is offline
Find More Posts by Buffythesaint
Joined Feb 2005
I'd have to agree with you too. On my MK hexa, all the CCW motors were running warmer then the CW motors. One motor was slightly off vertcal. I just shimmed it up level and now they are all about the same temp.
Buffythesaint is offline Find More Posts by Buffythesaint
Old Feb 05, 2013, 03:15 PM
crashtested is offline
Find More Posts by crashtested
crashtested's Avatar
USA, RI, East Providence
Joined Jun 2010
Can someone with ground station software CD PM me a URL of the download link on the cd? I have contacted DJI, but no response.
crashtested is offline Find More Posts by crashtested
Old Feb 05, 2013, 04:56 PM
cbergen is offline
Find More Posts by cbergen
Joined Jun 2004
As far as I know, There is no internet download of the ground station software. You have to get it from the CD.
cbergen is offline Find More Posts by cbergen
Old Feb 05, 2013, 05:15 PM
badbill is offline
Find More Posts by badbill
Soylent Green is PEOPLE
badbill's Avatar
USA, GA, Centerville
Joined Dec 2002
This is the 64bit, maybe not the newest?
Bill Davenport
AMA 28141
badbill is offline Find More Posts by badbill
Old Feb 05, 2013, 05:18 PM
hadawayj is offline
Find More Posts by hadawayj
hadawayj's Avatar
United States, FL, Wildwood
Joined Jun 2012
DJI iOSD MarkII upgrade
Anyone have anymore information on upgrading the DJI iOSD to a Mark II?
hadawayj is offline Find More Posts by hadawayj
Old Feb 05, 2013, 05:27 PM
pokmon is offline
Find More Posts by pokmon
pokmon's Avatar
Slovenia, Ljubljana
Joined Feb 2011
Read post number 16807 on http://www.rcgroups.com/forums/showt...6386&page=1121
pokmon is offline Find More Posts by pokmon
Old Feb 05, 2013, 08:17 PM
Tahoe Ed is offline
Find More Posts by Tahoe Ed
DJI Support
Tahoe Ed's Avatar
Las Vegas/Lake Tahoe
Joined Feb 2010
A whole thread on the iOSD MK I and MK II just for you:
http://www.rcgroups.com/forums/showthread.php?t=1738864
Tahoe Ed is offline Find More Posts by Tahoe Ed
Site Sponsor
Old Feb 06, 2013, 05:22 AM
archet is offline
Joined Sep 2012
motors overheating
I tweaked with motors, trying to put them as vertical as possible, doing very small movements to one side or the other and the result now is that the motors 2 and 4, on the other axis, are overheating, while before were motors 1 and 3.
So it really seems that this could be the reason of my motor's overheating.
What I cannot understand is that I have used the quadcopter many times and never had to be so precise to align the motors vertically because of overheating them.
I will do other tries.
Old Feb 06, 2013, 05:55 AM
IconFlyer is offline
Find More Posts by IconFlyer
Joined May 2011
Make sure that each one of the CW and CCW motors are slightly offest(maybe 3-5 degrees) so that the resulting sideway thrust(from the tilt) supports their yaw command. For example a CW motor rotates the copter CCW if it spins faster than all other motors, tilt that motor slightly so the resulting thrust vector in the horizontal direction pushes the frame in the CCW direction. I use a magnetic angle locator like this one http://www.acehardware.com/product/i...ductId=1285951 to align all motors within 1-2 degrees but having them tilted in the right direction compensates for any angle measurement differences.
The problem I face is always with my coaxial setups where each arm becomes torque neutral which would imply the need to tilt each motor on the same arm in a different direction...the mikrocopter site has a small shim that can be used to achieve that but I've never used it and instead created a custom motor mix for the WKM to allow motors on each coaxial arm to spin in the same direction. There are of of course disadvantages of having the coaxial props spin air in the same direction but the props I use don't suffer from that.
IconFlyer is offline Find More Posts by IconFlyer
Old Feb 06, 2013, 06:13 AM
Psionic001 is offline
Find More Posts by Psionic001
Psionic001's Avatar
Australia, NSW, Sydney
Joined Apr 2006
Hmmmm, its strange they are so sensitive.
Line up adjacent prop tips to ensure that the actual motor shaft is vertical, regardless of how it might look with a visual inspection. Looks can be deceiving depending on whats mounted on the copter. Hope that makes sense.
Also, a longshot, but I guess your if your yaw gains are a bit on the high side then it could become overly sensitive to a slightly offset motor. My Yaw gains normally run somewhere around 130-140 (on an octa)
Cheers
Matt
Psionic001 is offline Find More Posts by Psionic001
Old Feb 06, 2013, 07:11 AM
pokmon is offline
pokmon's Avatar
Slovenia, Ljubljana
Joined Feb 2011
Did you have a link ?
Thank you
Old Feb 06, 2013, 07:37 AM
Sid3ways is offline
Find More Posts by Sid3ways
DJI Supporter
Sid3ways's Avatar
Swanton, OH
Joined Jul 2007
Thank you
http://www.quadrocopter.com/Motor-an...ter_p_263.html
Sid3ways is offline Find More Posts by Sid3ways
Discussion Ballistic Recovery System for Multirotors Duck! Aerial Photography 66 Nov 13, 2015 04:37 PM
Discussion DJI - WooKong eStab for Scale sidneyw Scale Helicopters 97 Dec 30, 2012 10:48 AM
Discussion FY3ZT Autopilot for Aerial Photography feiyudz Aerial Photography 116 May 07, 2012 04:58 PM
Discussion DJI AceOne autopilot for sale... hazchem88 Aerial Photography 4 Mar 31, 2011 03:54 AM
Discussion DJI Innovation helicopter autopilot XP.3.1 for European customers JoelT Aerial Photography 2 Sep 24, 2009 11:43 AM
