Old Jan 14, 2013, 06:03 AM
bcollydas is offline
Find More Posts by bcollydas
bcollydas's Avatar
Canada, QC, Laval
Joined Apr 2008
If is the same motor all the time check your throttle range.
Do throttle calibration again.
bcollydas is offline Find More Posts by bcollydas
Old Jan 14, 2013, 09:00 AM
squigg is offline
Find More Posts by squigg
What goes around comes around.
squigg's Avatar
Joined May 2011
Thanks, thought it was esc related, just checking here in-case there was some dji m6 thing going on i wasnt aware of.. things been going so well lately ..fw5.16 is the best yet.
squigg is offline Find More Posts by squigg
Old Jan 14, 2013, 12:13 PM
Aviator1 is offline
Find More Posts by Aviator1
Aviator1's Avatar
United Kingdom, England, Surrey
Joined Jan 2012
You will find sometimes on start up some motors will spin faster than others? its pretty random and why.. I dont know, it`s all in the firmware, just raise your idle speed and it should cure the one motor not firing up
Aviator1 is offline Find More Posts by Aviator1
Old Jan 14, 2013, 04:58 PM
Psionic001 is offline
Find More Posts by Psionic001
Psionic001's Avatar
Australia, NSW, Sydney
Joined Apr 2006
My yellow flash for normal flight turns to a light yellow rapid flash at first level of battery warning. It's not quite green, but it's definitely not the dark yellow and definitely not the white.
FWIW, I remember it used to rapid flash the darker yellow and seems like I've lost an LED at some point in time.
Originally Posted by hstaniloff View Post
Trying to set up my Voltage protection. Maybe I'm going color blind, but does the yellow LED kind of look green? I later got the flashing red LED and the hex starting descending at the second level battery protection. So I think it's the LED light color that's slightly off.
Else, if it is green that would signal an IMU data lost error. What does that exactly mean and how would I correct the problem?
Thanks.
Psionic001 is offline Find More Posts by Psionic001
Old Jan 14, 2013, 05:18 PM
Psionic001's Avatar
Joined Apr 2006
It's definitely an IMU Issue and not "inadequate gps reception".
I can see triple white flash in both GPS and atti mode too.
If you took that footage with a gopro, it should have been much smoother IMO being hard mounted to an s800, so check prop balance on all props and make sure they are perfect. Hub balance them too with CA if required.
If that does not work, then reset your WKM to default, check your mounting, recalibrate your mag, and try again.
HTH
Matt
Originally Posted by Michiel van Son View Post
Just finished another little test-flight.
Notes:
- Mechanically it's perfect: when I put it in manual mode it almost stays hovering level without touching the controls (see 5:00)
Also gives me white flashes in manual though..
- In GPS-atti it's stays pretty tight in it's 2m diameter, but it does drift of a bit when yawing, flies back to original location after yaw though. Also, frequent triple white led flashed, possibly inadequate gps reception?
- In atti-mode there is a SERIOUS drift to the left! I have to keep on giving it counter-aileron to the right to keep it from flying of.. This is what's bugging me the most. It must be a IMU problem since it stays perfectly stable in Manual-mode...
Also occasional triple white flashes, maybe a compass misreading? I did do a succesfull and clean calibration just before this flight though... The IMU is not touching the sides op the top-plate...
What could be wrong?
How can I get rid of the sideways drift in atti- mode? This is my main concern, since it flies pretty good and I don't notice a difference in flying-characteristics with the white flashes or without.
here are my settings (it's a basic S800 with the gps mounted on the longest pole fairly in the center, and with one Gens Ace 10ah 6S attached underneath the centerplate.)
Old Jan 15, 2013, 09:28 PM
DJI INNOVATIONS is offline
Find More Posts by DJI INNOVATIONS
Joined Jul 2011
It's normal, all motors will keep same spin speed unless an absolute horizontal is guaranteed.
DJI INNOVATIONS is offline Find More Posts by DJI INNOVATIONS
Site Sponsor
Old Jan 16, 2013, 12:39 AM
Joined Jul 2011
A fresh overview and Depth Walkthrough of WKM. Maybe a little bit late, hope could help some of fresh guys anyway
Presented by Colin, DJI USA
Wookong M Overview CH 1 Components and Functions 1
Wookong M Overview CH 1 Components and Functions 1 (3 min 0 sec)
Wookong M Overview CH 2 Recievers 1
Wookong M Overview CH 2 Recievers 1 (2 min 56 sec)
Wookong M Overview CH 3 Flight Modes
Wookong M Overview CH 3 Flight Modes (4 min 42 sec)
Programming the Wookong M CH 2 Software Overview
Programming the Wookong M CH 2 Software Overview (4 min 52 sec)
Programming the Wookong M CH 3 In Depth Walkthrough
Programming the Wookong M CH 3 In Depth Walkthrough (7 min 52 sec)
Site Sponsor
Old Jan 16, 2013, 01:15 AM
Tahoe Ed is offline
Find More Posts by Tahoe Ed
DJI Support
Tahoe Ed's Avatar
Las Vegas/Lake Tahoe
Joined Feb 2010
Colin, CEO of DJI NA, does a great job at explaining the WKM. The videos are much more professional than those that users have done. I hope that DJI posts links on their website. It will be of great use to new users. Thanks, Colin.
Tahoe Ed is offline Find More Posts by Tahoe Ed
Site Sponsor
Old Jan 16, 2013, 01:33 AM
crcr is offline
Find More Posts by crcr
Joined Dec 2008
I agree, just videos and as I'm about to purchase the WKM it is very good timing.
One thing I didn't completely understand from the flight modes video was the stabilization.
If you let go of the sticks in manual mode, does the WKM keep the copter level?
crcr is offline Find More Posts by crcr
Old Jan 16, 2013, 01:38 AM
Tahoe Ed is offline
DJI Support
Tahoe Ed's Avatar
Joined Feb 2010
crcr,
Not in Manual mode, in ATTI and GPS/ATTI only.
Site Sponsor
Old Jan 16, 2013, 02:16 AM
crcr is offline
Joined Dec 2008
crcr,
Thanks, So in ATTI mode its auto leveling but means the Altitude hold is always on?
So there is no way to have the altitude hold switched off but still have auto level?
If you wanted to take some photos at various heights and raise altitude slowly on the same spot you would need to be in GPS/ATTI mode. Is it easy to raise the altitude slowly without the WKM trying to fight to keep the same original altitude?
Craig
Old Jan 16, 2013, 02:25 AM
EndOfDays is offline
Find More Posts by EndOfDays
EndOfDays's Avatar
Austria, Niederösterr., Eggenburg
Joined Jan 2010
if you move the throttle stick above 50% (in Atti and GPS-Atti) the copter climbs (climb speed dependent on your stick position)
if you move the throttle stick below 50% (in Atti and GPS-Atti) the copter descents (descent speed dependent on your stick position)
(this you can also read in the manual)
best regards
Ferdinand
EndOfDays is offline Find More Posts by EndOfDays
Old Jan 16, 2013, 05:20 AM
Aviator1 is offline
Aviator1's Avatar
Joined Jan 2012
Sorry I do not understand? do you mean to say that after the CSC input the motors should all run at the same speed? without throttle input... If that is the case, mine do not, at least on the S800 they don`t. There are two motors that always spin much slower than the other 4 until takeoff when the imu notices an imbalance and corrects it.
Old Jan 16, 2013, 07:22 AM
Sniperp is offline
Find More Posts by Sniperp
FPV addict
Joined Mar 2011
I had that issue with my NAZA. It ended up being my ESC's were not all calibrated to the same end points. Try recalibrate and see if that helps.
Sniperp is offline Find More Posts by Sniperp
Old Jan 16, 2013, 08:12 AM
Davebbb is offline
Find More Posts by Davebbb
Joined Aug 2011
never had real problems anyway with my Quad on other firmwares, but, must say i can see an feel a very big improvement since putting 5.16 on it.
Davebbb is offline Find More Posts by Davebbb
Discussion Ballistic Recovery System for Multirotors Duck! Aerial Photography 66 Nov 13, 2015 04:37 PM
Discussion DJI - WooKong eStab for Scale sidneyw Scale Helicopters 97 Dec 30, 2012 10:48 AM
Discussion FY3ZT Autopilot for Aerial Photography feiyudz Aerial Photography 116 May 07, 2012 04:58 PM
Discussion DJI AceOne autopilot for sale... hazchem88 Aerial Photography 4 Mar 31, 2011 03:54 AM
Discussion DJI Innovation helicopter autopilot XP.3.1 for European customers JoelT Aerial Photography 2 Sep 24, 2009 11:43 AM
