Las Vegas/Lake Tahoe
Joined Feb 2010
I don't think this is available yet and when it its, it is my understanding that it will take the iOSD to make it work. That is the only DJI accessory that has any appreciable amount of available memory. If someone knows differently or more please chime in here.
Canada, QC, Montreal
Joined Feb 2011
Hi all,
i'm trying to update my firmware and i'm not sure what is wrong but it doesn't seem to work. I went with the procedure stated on wiki, what do they mean but .power cycle the controller? and should i power cycle when promted and then click ok or when prompted click ok and the power cycle? How will I know if the power cycle was succesfull? a lot of questions for something that seems simple but since I try to updated without power cylcling (cause I wasn't sure how to do that) my wookong can't fly as it responds with hard twiches that almost makes me crash! thanks for any help |
I am interested to hear an answer... |
I'm flying with 2 x 5000mah 45C packs. Any recommendations on First Level and Second Level Protection settings on the voltage monitor?
I've heard that you do not want to go below 3.2V/cell under load. Is that correct? If so, then it seems like the Second Level Protection settings should be13.2V and First Level would be 13.4V? |
Australia, NSW, Mt Hutton
Joined Jul 2007
I gave up on the Battery protection settings
now fly 10mins 2x4s 6000 packs but a heavy machine Warning would kick in after about 3-4mins when packs were still at 70% - suspect voltage sag from the Turnigy Nanos leaves me at between 30-40% left in pack with a buffer to go as low as 20% if I need to Cheers Joe |
Joined Aug 2011
i time tested, and now run with a timer from 8 minutes 30 seconds, done that for a while now, never had any unwanted landings and batteries are all fine. now on latest FW, so may try again, but have been quite happy with the timer so far. |
I just gave up on the voltage settings too last week after a long exercise in voltage monitoring during flight when i was getting inconsistent alarms with consistent batteries. Now I'm using an audible voltage alarm and (still) using a timer. Also found a sweet app called RCLogbook to keep track of my battery cycles, IR and other stuff as a result of the exercise - has a cool timer too rather than just using the simple stopwatch feature if you use an iPhone.
Once it's completed, I then tend to unplug everything after this (batt + USB) Turn off TX, then turn TX back on and plug Batt + USB back in and confirm everything is right in the software, I will also type my settings back in to the software.. (this is just a habit that I do this) |
Hello guys,
Just finished my X16 and had maiden a few minutes ago ... FW 5.08 more details you can find in this thread: http://www.rcgroups.com/forums/showthread.php?t=1763685 best regards Ferdinand |
| Thread Tools | |
| Discussion Ballistic Recovery System for Multirotors | Duck! | Aerial Photography | 64 | Mar 22, 2013 11:13 AM |
| Discussion DJI - WooKong eStab for Scale | sidneyw | Scale Helicopters | 97 | Dec 30, 2012 10:48 AM |
| Discussion FY3ZT Autopilot for Aerial Photography | feiyudz | Aerial Photography | 116 | May 07, 2012 04:58 PM |
| Discussion DJI AceOne autopilot for sale... | hazchem88 | Aerial Photography | 4 | Mar 31, 2011 03:54 AM |
| Discussion DJI Innovation helicopter autopilot XP.3.1 for European customers | JoelT | Aerial Photography | 2 | Sep 24, 2009 11:43 AM |
