Old Nov 03, 2012, 03:49 AM
Florentf31 is offline
Find More Posts by Florentf31
France, Midi-Pyrénées, Toulouse
Joined Nov 2011
I love my FPV quad, I use FW 5.14 since few week it is perfect with my plateform
FPV vidéo with Gopro HD1 , the DJI OSD is perfect too.
Mon Film 6 1 enhanced (3 min 4 sec)
Florentf31 is offline Find More Posts by Florentf31
Old Nov 03, 2012, 09:01 AM
pokmon is offline
Find More Posts by pokmon
pokmon's Avatar
Slovenia, Ljubljana
Joined Feb 2011
Seems to be a problem only with heavy multicopters and firmware 5.14. Motor stopped without reasons.
pokmon is offline Find More Posts by pokmon
Old Nov 03, 2012, 10:48 AM
worms is offline
Find More Posts by worms
Romania
Joined Mar 2010
wookong flight test
frame - 800mm hexa plus
firmware - 5.06
camera mount - av130 only roll stabilized
camera -sony cx730.
test nou (7 min 8 sec)
worms is offline Find More Posts by worms
Old Nov 03, 2012, 11:40 PM
Twister773 is offline
Find More Posts by Twister773
Private Pilot
Twister773's Avatar
United States, CA, San Luis Obispo
Joined Jul 2009
Did anyone ever come to a conclusion what could cause someone to have multiple flights without issue, then one random flight be hovering in atti and it starts drifting for maybe 1 second then drifts even more extreme to the point it would crash if you dont flip to manual and fly it on your own? I was flying tonight from probably 400-500 yards away or more, over a river, filming a bridge. Start at one end and go the entire length of it and the multi was definitely at its max distance of being able to see it and was still tough to see. Multiple good flights then one of the night flights it did the dive and it was so far away and dark I couldnt see its orientation...long story short it was the scariest 3 minutes of my life and I need to figure out what is up with my wkm or wkm in general if anyone else has had this issue. Ill upload the footage the 5dmarkiii got during the ordeal when i get home from this shoot.
Twister773 is offline Find More Posts by Twister773
Old Nov 04, 2012, 01:21 AM
CONCEP60 is offline
Find More Posts by CONCEP60
L´Amposti
CONCEP60's Avatar
Amposta (Spain)
Joined Feb 2006
I spend the same, hover without control and translation, 500m crashed into a tree.
Consult Dji (Ophelia) and got no solution.
With how expensive it is, might be safer.
Continuous Testing before hanging 7D
CONCEP60 is offline Find More Posts by CONCEP60
Old Nov 04, 2012, 01:08 AM
pokmon is offline
pokmon's Avatar
Slovenia, Ljubljana
Joined Feb 2011
Twister773 & CONCEP60
Which firmware version have on your multicopters?
Old Nov 04, 2012, 01:27 AM
CONCEP60 is offline
L´Amposti
CONCEP60's Avatar
Amposta (Spain)
Joined Feb 2006
Crash day V1.30, today V1.40
Old Nov 04, 2012, 02:07 AM
pokmon is offline
pokmon's Avatar
Slovenia, Ljubljana
Joined Feb 2011
DJI wake up!!!
We aren't paid for test pilots.
hexa is offline
Find More Posts by hexa
hexa's Avatar
United Kingdom, Scotland, Edinburgh
Joined Nov 2010
Dji products is s ticking time bomb. Stay away
hexa is offline Find More Posts by hexa
Old Nov 04, 2012, 04:22 AM
Paul@SCC is offline
Find More Posts by Paul@SCC
Chalfont St Giles, Bucks, UK
Joined Jan 2007
Atti mode does not stop drift. It keeps the craft level and at a certain altitude within a meter or so. You still need to give stick input to keep it in place.
On a couple of occasions I have had my quad dive off to the right and down. That was due to a low lipo.
Paul@SCC is offline Find More Posts by Paul@SCC
Old Nov 04, 2012, 08:06 AM
Aviator1 is offline
Find More Posts by Aviator1
Aviator1's Avatar
United Kingdom, England, Surrey
Joined Jan 2012
Originally Posted by STASID View Post
I found this and it's works !!
"hi
i have the same problem. many email between me and dji. maybe, we found the solution:
Pls try install the plugin from CD again then
1) Open file: C:\Windows\System32\Drivers\etc\hosts
2) remove all entries from the file containing "google.com." Then save the file. Leave all the other entries the way they are
3) Then open a command prompt and type "ipconfig /flushdns"
4) Close the command prompt after the DNS resolver cache flushes successfully and Google Earth should work fine.
i hope, this work by you."
Thanks for the tip I have tried this but it always says access denied? what program do you use to edit it? I tried notebook and dreamweaver but both will not allow me to save the file after the edit, any ideas?
Aviator1 is offline Find More Posts by Aviator1
Old Nov 04, 2012, 08:09 AM
marchino65 is offline
Find More Posts by marchino65
marchino65's Avatar
Florence, IT
Joined Oct 2006
disable antivirus, run command prompt in administrator mode
marchino65 is offline Find More Posts by marchino65
Old Nov 04, 2012, 09:10 AM
Private Pilot
Twister773's Avatar
Joined Jul 2009
I am well aware of this. It dived so hard the booms where facing straight down at one point. Mine has done this on the last two firmwares. The one that crashed octos using traditional rx and the newest one. I think my dji wkm will be up for sale soon. It's just not worth the risk. Also when it drifts and starts its hard tilt in whatever direction full stick input the other way is not enough to stop it and really doesn't help at all. My batteries where fully charged it happened 2 minutes into flight. You will be in shock when you see the video.
Old Nov 04, 2012, 09:18 AM
squigg is offline
Find More Posts by squigg
What goes around comes around.
squigg's Avatar
Joined May 2011
Twister have you had your MC replaced? & are you flying on the old "safe" gps unit?
squigg is offline Find More Posts by squigg
Old Nov 04, 2012, 09:48 AM
vip is offline
vip
Find More Posts by vip
vip
United States, WA, Seattle
Joined Jan 2012
Yes I have Contacted DJI about a month ago with mine that if I install 5.14 I get all white flashes then purple or yellow ( no red any more) as soon as I power up.
white white purple and never locks. Constant white flashes if I fly it.
Never locks GPS
No resolution.
On 5.12a I get the normal red red purple, then locks,,,,or red red yellow., then constant yellow. Flies fine so I stay here but!!!
Sure would be nice to hear from them
vip is offline Find More Posts by vip
Discussion Ballistic Recovery System for Multirotors Duck! Aerial Photography 66 Nov 13, 2015 04:37 PM
Discussion DJI - WooKong eStab for Scale sidneyw Scale Helicopters 97 Dec 30, 2012 10:48 AM
Discussion FY3ZT Autopilot for Aerial Photography feiyudz Aerial Photography 116 May 07, 2012 04:58 PM
Discussion DJI AceOne autopilot for sale... hazchem88 Aerial Photography 4 Mar 31, 2011 03:54 AM
Discussion DJI Innovation helicopter autopilot XP.3.1 for European customers JoelT Aerial Photography 2 Sep 24, 2009 11:43 AM
