Old Oct 23, 2012, 07:38 AM
apvxtreme is offline
Find More Posts by apvxtreme
aka RacingFPV aka HAMM3RDOWN
Canada, ON, Toronto
Joined Sep 2012
Originally Posted by furyphoto View Post
You have set a switch on your tx to be the "DJI failsafe" (a return to home switch), and then turn on that switch, and then record that as fail safe on your Receiver.
The frsky has a customizable failsafe, so if you turn off the Tx the DJI does not see "no TX signal", instead it sees the failsafe positions from the receiver. The DJI thinks the Tx is still on, and it thinks that the Rx failsafe signals are actually signals from the Tx.
So you have to set your Rx failsafe to the TX positions that your sticks/switches would be in to activate the DJI failsafe if the TX was on.
Clear as mud? ask more questions if you want, I think I confused myself
Thanks for the tip, made sense to me. I am having the same issue, I will have to try that.
apvxtreme is offline Find More Posts by apvxtreme
Old Oct 23, 2012, 07:39 AM
Pack AE is offline
Find More Posts by Pack AE
Pack AE's Avatar
Joined Dec 2006
Originally Posted by Capo Creative View Post
That's awesome! Where would I plug in my Zenmuse though... hmmm.
Can't help you there, I don't fly with a Zenmuse. Waiting for you guys to help them work out their bugs before I put that rig in the air
Pack AE is offline Find More Posts by Pack AE
Old Oct 23, 2012, 07:53 AM
Canada, ON, Toronto
Joined Sep 2012
Originally Posted by Panza View Post
Sorry Tom, yes i have skipped. But i'ts not it the good topic.
Of course i know the problems are not for every body. I had myself 50 clean flights.
It may be more intresting if you talked about your FW version.
To DJI US ressellers : do you know the time for delivering and upgrading bad antenna to dji, and return ?
They got mine yesterday, let's see how long it takes to get back to me, I'll keep you posted.
Old Oct 23, 2012, 09:52 AM
Manuel Silva is offline
Find More Posts by Manuel Silva
Oporto Portugal
Joined Sep 2007
Tx/Rx number of channels
Hi!
According to the Wookong-M multirotor users manual we need a 7 channels minimum Tx/Rx:
- 4 for normal functions.
- 1 for a 3 position switch.
- 1 for a 2 position switch.
- 1 for gimbal control.
My question is: if I have a 8 channel PPM Tx/Rx, how we can use the extra channel to control the shutter camera?
Manuel
Manuel Silva is offline Find More Posts by Manuel Silva
Old Oct 23, 2012, 09:54 AM
badbill is offline
Find More Posts by badbill
Habitual Freeloader
badbill's Avatar
USA, GA, Centerville
Joined Dec 2002
Here's my first flight with the new Sony action cam.
Bill Davenport
AMA 28141
First Flight- Sony Action Cam on DJI Hexa (9 min 50 sec)
badbill is offline Find More Posts by badbill
Old Oct 23, 2012, 10:03 AM
Panza is offline
Find More Posts by Panza
Panza's Avatar
France, Midi-Pyrénées, Toulouse
Joined Jun 2012
Originally Posted by Knilch View Post
Now what's going on with the recent GPS issue? You guys still flying with the current GPS antenna or did you all disconnect it and shipped it to DJI? Is it or is it not safe to fly with something else than an S800 with the completely white GPS antenna?
The WK New Antenna problem is the same for those on S800 and the others.
Does DJI think european and american people is so stupid to beleive the problem only on S800 ?
LOL
You can fly with ,a disconnected antenna. You will just have permanently 3reds flash, but it fly great.
Dont try an RTH, thats all...
Folks ?
Panza is offline Find More Posts by Panza
Old Oct 23, 2012, 10:06 AM
MCrites is offline
Find More Posts by MCrites
I never finish anyth
United States, TX, Houston
Joined Jan 2012
This is something I wish DJI would fix. If we would reprogram the default channels on the WKM/Naza to the higher channels in the SBUS/PPM then we could use the lower numbered traditional channels. As of right now it isn't possible from what I could find.
MCrites is offline Find More Posts by MCrites
Old Oct 23, 2012, 10:40 AM
albertog is offline
Find More Posts by albertog
albertog's Avatar
Panama, San Miguelito
Joined Apr 2011
Perfect!
Got it working.
Thanks.
albertog is offline Find More Posts by albertog
Old Oct 23, 2012, 11:50 AM
Oporto Portugal
Joined Sep 2007
MCrites,
Thanks for the information. I know a little of AVR asm, I am going to try if I am able to split the last pulse from the PPM stream, and use it for the camera shutter.
Thanks again for the information.
Manuel
Old Oct 23, 2012, 02:26 PM
Knilch is offline
Find More Posts by Knilch
Joined Nov 2011
LOL
Folks ?
Yes, I did fly with disconnected GPS for some time earlier this year and know that it works but I somehow am led to believe that when the LED flashes 3 times red to show for the missing GPS it is not putting out the white LED code for a problem with the atti status.
Then back it goes, my brand new replacement GPS antenna… .
Knilch is offline Find More Posts by Knilch
Old Oct 23, 2012, 02:29 PM
Panza is offline
Panza's Avatar
Joined Jun 2012
No, 3 red flash did not hide white. I had some. It does : red red red white redredred white ....
or redredred whitewhite ...
They said when they will update our antenna, they will put some new code for new functions...
hope we'll not again be some beta innovators....
Old Oct 23, 2012, 02:31 PM
Knilch is offline
Joined Nov 2011
Sure about that? Normal is 3red, then 1 or 2 yellow or purple to who which mode it's in (only makes sense with atti obviously). Would it show 3 red, then white and then the yellow for the mode? Are you certain about that?
Old Oct 23, 2012, 02:38 PM
Panza is offline
Panza's Avatar
Joined Jun 2012
yes i am,
if there is white, white replace the normal atti yellow.
And more : white id FROM Imu, no relation with gps/compas miss
This configuration make you led never sleep.... redredredyelloyelloredredredyelloyelloredredredyel loyelloredredredyelloyelloredredredyelloyelloredre dredyelloyelloredredredyelloyelloredredredyelloyel loredredredyelloyelloredredredyelloyello
But it works withOUT flips, drifts.... ☹ (and perhaps HEADS CUT if DJI does not do something quickly, and, in a SURE version).
Old Oct 23, 2012, 04:16 PM
albertog is offline
albertog's Avatar
Joined Apr 2011
Rusty Frame Hexa
Hi.
I just powered today to test the new firmware on my rusty
frame hexa, avrotos 2814-11,plush 60a esc,6000mah lipo,
apc 12x3.8 and it can hardly fly. It wobbles
just 1 feet or 2 to the point where it is unflyable.
I have flow this with previous firmware and no problems.
What could be some startup value gains???
Old Oct 23, 2012, 04:18 PM
Pack AE is offline
Pack AE's Avatar
Joined Dec 2006
I suspect their attitude filter uses the GPS/compass data, when present, in the attitude solution. So yes, hooking up the GPS can affect the IMU. In my case, I have only ever seen white flashes with the GPS hooked up. If you're seeing white flashes without the GPS hooked up, I would tend to think that's a good indicator that you are in fact seeing too much vibration in the IMU.
It's possible they don't use the GPS data in their attitude filter, but I would find that a bit hard to believe. That's pretty standard for airborne kalman filters as I understand things.
Discussion Ballistic Recovery System for Multirotors Duck! Aerial Photography 66 Nov 13, 2015 04:37 PM
Discussion DJI - WooKong eStab for Scale sidneyw Scale Helicopters 97 Dec 30, 2012 10:48 AM
Discussion FY3ZT Autopilot for Aerial Photography feiyudz Aerial Photography 116 May 07, 2012 04:58 PM
Discussion DJI AceOne autopilot for sale... hazchem88 Aerial Photography 4 Mar 31, 2011 03:54 AM
Discussion DJI Innovation helicopter autopilot XP.3.1 for European customers JoelT Aerial Photography 2 Sep 24, 2009 11:43 AM
