Old Sep 27, 2012, 10:46 PM
kd4wen is offline
Find More Posts by kd4wen
Just a yard bird
kd4wen's Avatar
United States, TN, Springfield
Joined Mar 2007
Originally Posted by Estiavilla View Post
I tried using expo on the rudder stick, it does feel better....but we are avoiding the problem and not solving it, cos sometime it mid air, i needed more rudder command, and it wobbles again due to my near max end limit on my rudder stick.
I also did lower the Yaw gains till the point it felt sluggish, but it takes the joy out of the turn, so in aerial video taking, i got to fly and turn very slowly, there is no way i can take scene like car chasing or tight turns.
There are too many near miss and almost sacrificed my cinestar and 5d3.
I feel that i will be running out of luck soon, that's why i quickly swapped the WK-m out before something bad happened.
So what did you put into its place and does it do a better job in keeping you happy flight wise.
kd4wen is offline Find More Posts by kd4wen
Old Sep 27, 2012, 11:40 PM
Tahoe Ed is online now
Find More Posts by Tahoe Ed
DJI Support
Tahoe Ed's Avatar
Las Vegas/Lake Tahoe
Joined Feb 2010
Can you show us your set up? Photos, gain settings, etc. We may be able to help you. I rotate my WKM in GPS ATTI at max yaw and it just sits there. I have done this on my F450, F550 and now my S800. They were all DJI, escs and motors. You may have a bad MC or IMU or GPS. It is impossible to tell unless we have more info. Also have you contacted DJI with your problems?
Tahoe Ed is online now Find More Posts by Tahoe Ed
Site Sponsor
Old Sep 28, 2012, 09:27 PM
isaacintheclouds is offline
Find More Posts by isaacintheclouds
Nevermind...
isaacintheclouds's Avatar
United States, CA, Carnelian Bay
Joined May 2011
I had something strikingly similar happen with one of my quads recently. When I would rotate too quickly it would suddenly wobble. After much investigation I discovered that the #2 motor would vibrate wickedly at high rpm causing the wobble. I was able to replicate the wobble by applying full throttle for a quick burst while holding the quad on the ground, and I could see the prop/motor vibrate and oscillate. You might try checking that.
isaacintheclouds is offline Find More Posts by isaacintheclouds
Old Sep 28, 2012, 09:32 PM
Nevermind...
Joined May 2011
gps hold(wanderoff)
I just went to 5.14 from 5.12a and now the gps takes forever to get lock and will absolutely not hold position in gps hold. Before I changed fw versions it was holding quite well. Anyone have this? Cheers!
Edit:
Found a site that has previous versions and downgraded to 5.12a. Still wandered a little until I put on a cover lined with carbon fiber that seems to shield the gps from electrical noise. More trials tomorrow...
Old Sep 29, 2012, 01:43 AM
ViperAT is offline
Find More Posts by ViperAT
Joined Jan 2012
Yeah same props here !
ViperAT is offline Find More Posts by ViperAT
Old Sep 29, 2012, 08:59 AM
squigg is offline
Find More Posts by squigg
What goes around comes around.
squigg's Avatar
Joined May 2011
How many of you are using Maytech v1 esc's,? reading mixed results on other forums, any experiences, recommendations?
thanks in advance.
squigg is offline Find More Posts by squigg
Old Sep 29, 2012, 05:39 PM
Kiwidrone is offline
Find More Posts by Kiwidrone
Joined Jul 2012
Wookong M Ground Control Station - Data-logging.
Update on this as said would post when heard back from DJI (Note this disccusion has been over at DJI Wookong-M Owners Thread):
Issue (Presented to DJI):
No data-logging on GCS/Wookong (Heading,GPS Bearing, Alt etc), so renders photogrammetry (Tools unlocked at 50 waypoint WKM) useless (for eg.) without using a 3rd party GPS Datalogger to acquire this data.
Response (DJI):
The GCS log is only recording limited data (not sufficient for photogrammetry), due to limitations of datalink (Note - I bought 900 Mhz but same for 2.4).
Firmware could be upgraded to make it log data required, but datalink connection would be too intermittent and data-log incomplete.
Best solution recording is record everything to SD on multi, the OSD module (DJI) released already has a SD internally, users will be able to access data-logs when a new firmware is released for OSD.
Top stuff DJI, thanks for the response. Looks like I'm buying the new DJI OSD, for the data-log features I need so badly but also looks to be a sweet video switcher/OSD
Kiwidrone is offline Find More Posts by Kiwidrone
Old Sep 29, 2012, 08:46 PM
Estiavilla is offline
Find More Posts by Estiavilla
Taka
Joined Dec 2010
It's the previous MK Fc now back into place. Yaw issue solved, but i missed the fabulous height holding and gps lock of the wkm.
Estiavilla is offline Find More Posts by Estiavilla
Old Sep 29, 2012, 08:50 PM
Taka
Joined Dec 2010
Ok, let me go take a video of the wkm in the f450 frame, and post my settings later. I have also found out that my MC is the first batch production from a youtube link showing how to test the output pin resistance, my M1 resistance is same as F1&F2, but different from M2 to M6. So these means its the older batch.
Old Sep 30, 2012, 06:48 AM
Harpia is offline
Find More Posts by Harpia
Harpia's Avatar
Brasil, PE, Gravatá
Joined Apr 2004
Response (DJI):
This means that now the tool of photogrammetry WKM waypoint will work as it should?
Who bought the upgrade to use the waypoint tool photogrammetry and can not use lack of sdcard to write to the log (Heading, GPS Bearing, Alt etc) for $ 1300 will get some discount on OSD?
Photogrammetry of the WKM is incomplete for lack of logging, but DJI sold as a complete tool, DJI should now do justice and give a discount.
Edson
Harpia is offline Find More Posts by Harpia
Old Sep 30, 2012, 03:16 PM
Tarro is offline
Find More Posts by Tarro
Long Island, New York
Joined Jun 2008
I have a new octo with QC 3328 motors and DYS 30a ESC flashed with SimonK. When I arm the octo not all the motors start up and some of them don't start to spin until the copter is about to take off. Today one of the motors stop in midflight. What could be causing this?
Thanks.
Tarro is offline Find More Posts by Tarro
Reply With Quote  (Disabled)
Old Sep 30, 2012, 03:38 PM
Harpia is offline
Harpia's Avatar
Brasil, PE, Gravatá
Joined Apr 2004
Thanks.
It may have been overheating the ESC.
I also have a Octo with Avroto motors and Simonk firmware ESC and the motors do not start spin at the same time.
Old Sep 30, 2012, 04:25 PM
Tarro is offline
Joined Jun 2008
The esc's are not hot and these are not Avrotor motor they are Quadrocopter QC3328 motors. The motor cutting out has not happened again but is it concerning me.
One good thing is that I have confirmed the redunancy for this design.
Old Sep 30, 2012, 04:45 PM
Drone Minds is offline
Find More Posts by Drone Minds
@saradroneminds
Drone Minds's Avatar
United Kingdom, York
Joined Apr 2011
Thanks.
Have you set the throttle range for each motor separately?
Drone Minds is offline Find More Posts by Drone Minds
Latest blog entry: Drone Speed Gun Shootout
Old Sep 30, 2012, 04:52 PM
Tarro is offline
Joined Jun 2008
I was told that the Re- Flashed ESC's don't need to be calibrated. Is that true?
Other then this issue it is flying great.
Discussion Ballistic Recovery System for Multirotors Duck! Aerial Photography 66 Nov 13, 2015 04:37 PM
Discussion DJI - WooKong eStab for Scale sidneyw Scale Helicopters 97 Dec 30, 2012 10:48 AM
Discussion FY3ZT Autopilot for Aerial Photography feiyudz Aerial Photography 116 May 07, 2012 04:58 PM
Discussion DJI AceOne autopilot for sale... hazchem88 Aerial Photography 4 Mar 31, 2011 03:54 AM
Discussion DJI Innovation helicopter autopilot XP.3.1 for European customers JoelT Aerial Photography 2 Sep 24, 2009 11:43 AM
