Old Sep 13, 2012, 09:20 PM
jabtyler is offline
Find More Posts by jabtyler
jabtyler's Avatar
United States, CO, Denver
Joined Jun 2011
I had my gains up to 120 but it was erratic and would make violent shifts left and right so I started lowering them until I got to 90 and a much smoother hover and that is where this happened.
this is the second time I have heard of bullet connections being bad, so Im still learning about that. i was using this kit for motors and ESCs.
http://www.cnchelicopter.com/servlet...-carbon/Detail
I always say there is no point in replacing parts when you can upgrade so, what do you use for motors ESCs and instead of bullet connectors? also what do you recommend for AP?
thanks
Originally Posted by MCrites View Post
My money is on a bullet connector/motor/esc failure. It was failing and giving you signals something was wrong, why didn't you land? I'm not positive how it works but doesn't it kill the motors when you tip over 45degrees? If it failed and you tipped at 1:20 it explains the motors all but stopping and it just carried the momentum till you hit the ground.
Also could have been a failed battery/cell. I accidentally ran one down too much and I lost power similar to that.I was coming in to land and I lost power then gained some back then lost more. Good thing I was 6ft off the ground but I can see it ending like this with a battery failure because once on the ground I had the juice to spin the motors, just not fast enough to climb. Multiple motors lose power, tips and sends it forward, then all lose power, then you get some juice to slowly spin the motors and level itself before impact.
Now that I walk through it... I can almost guarantee it was battery.
jabtyler is offline Find More Posts by jabtyler
Old Sep 13, 2012, 10:30 PM
RedSky is offline
Find More Posts by RedSky
Australia, SA, Renmark West
Joined Sep 2011
thanks
After a couple of motor failures (fortunately on an octocopter) I've given up on bullet connectors between the ESC and motor - I solder everything now. More trouble to undo but never any doubt of the connection.
RedSky is offline Find More Posts by RedSky
Old Sep 13, 2012, 11:36 PM
tigar is offline
Find More Posts by tigar
tigar's Avatar
Athens, Greece
Joined Sep 2001
What do you use for motors ESCs and instead of bullet connectors?
thanks
Solder!
tigar is offline Find More Posts by tigar
Old Sep 14, 2012, 02:31 AM
apeman88 is offline
Find More Posts by apeman88
Joined Jul 2007
I had the same problem with 5.14a when I switched to new lower kV motors. Fixed my problem by raising the idle RPM one notch and now they all spin up at the same time. See if this will fix your problem.
Ken
Originally Posted by Davebbb View Post
Out of interest, just tried 1.32 assistant and 5.14a,
Well, the Assistant seemed to have loads of issues, one main one being TX calibration, it just would not calibrate the sticks at all, everytime 3 or 4 points away from centre, when it did finally calibrate, i reset the gains to default, and took the Quad out back, useless, one motor started up very late and near flipped it, 2nd to 3rd try two motors were late starting up, and on default settings, was wandering all over the place, raised them, seemed better.
went back to 130 with 5.12, all good again, except i still now have one motor starting a little to late, but its not always the same motor, any ideas on why this is happening?
cheers
apeman88 is offline Find More Posts by apeman88
Old Sep 14, 2012, 04:00 AM
Panza is offline
Find More Posts by Panza
Panza's Avatar
France, Midi-Pyrénées, Toulouse
Joined Jun 2012
Originally Posted by jerrymeister View Post
I still am not getting failsafe to work. I made sure to bind my spectrum D8 for failsafe with switch in failsafe position. Everything works great, however when I hit the failsafe switch, blue light comes on and within 5 seconds it makes a rapid assent. Any ideas at all would be helpful. Jasper I read your last post and have no ideas, but will keep thinking about why you get just red lights outside.
Jerry
Lol
Blue is for TX off
The multi stay 30 s hover
than go higter for the return way
just wait
you can retake control on manual or atti only
Panza is offline Find More Posts by Panza
Old Sep 14, 2012, 06:45 AM
Davebbb is offline
Find More Posts by Davebbb
Joined Aug 2011
Ken
Ok Ken, will try this later today, Thanks, will let you know
Davebbb is offline Find More Posts by Davebbb
Old Sep 14, 2012, 03:00 PM
sameer is offline
Find More Posts by sameer
Joined Sep 2012
Missing GCS CD
Hello everyone. I have the same problem where I bought the datalink but I assumed that all the software was on the DJI web page so I think I may have discarded the CD before I realized that the DJI web page did not actually have the ground control software. I installed the software at the link posted in this thread, which was a great help, but I am still missing the DJI Google Earth plugin and the Datalink USB Driver. Would someone mind uploading?
Thanks!
sameer is offline Find More Posts by sameer
Old Sep 14, 2012, 10:57 PM
jabtyler is offline
jabtyler's Avatar
Joined Jun 2011
so it seems like I need to get rid of the bullets and work on my gains. any other ideas?
I did some searching and I couldent find exactly what I was looking for so Ill as here can someone explain in detail how to adjust gains, I want to make sure I am not missing something. or point me in the direction of the thread with that info please
thanks
Old Sep 15, 2012, 05:09 PM
quadslo is offline
Find More Posts by quadslo
Slovenia
Joined Feb 2011
Anyone knows if DJI software and m-view can be used on a tablet running Windows 7? (Asus tablet)
quadslo is offline Find More Posts by quadslo
Old Sep 15, 2012, 10:24 PM
kuau is offline
Find More Posts by kuau
United States, UT, Park City
Joined Sep 2011
quick question
on my gimbal I am running HITEC HS-5245MG digital servos.
I am running the latest FW and 1.32 assistant.
In the Gimbal setting "OUTPUT FREQUENCY" should I set it to 200hz or 400hz?
thanks
kuau is offline Find More Posts by kuau
Old Sep 15, 2012, 10:31 PM
MCrites is offline
Find More Posts by MCrites
I never finish anyth
United States, TX, Houston
Joined Jan 2012
Originally Posted by kuau View Post
quick question
thanks
Quick answer: try them both and see which works best.
MCrites is offline Find More Posts by MCrites
Old Sep 15, 2012, 10:35 PM
MCrites is offline
Joined Jan 2012
thanks
I wouldn't trust that battery or the connectors. Test that battery and check for a cold solder on all of the connectors. The way it had no power at the end seemed more like a power issue. Erratic tipping can be bullet connectors, power loss is bigger.
Old Sep 16, 2012, 07:01 AM
zolpot is offline
Find More Posts by zolpot
Joined May 2012
zolpot is offline Find More Posts by zolpot
Old Sep 16, 2012, 09:59 AM
vip is offline
vip
Find More Posts by vip
vip
United States, WA, Seattle
Joined Jan 2012
wkm data link
Originally Posted by zolpot View Post
Does it have a maximum flight speed with click & go or keyboard control ?
maybe we should start a new thread just for WKM data link.
Our subject will get lost in this thread, I am hooking mine up today..
vip is offline Find More Posts by vip
Old Sep 16, 2012, 02:22 PM
Rockdw is offline
Find More Posts by Rockdw
United States, PA, Lancaster
Joined Jan 2012
One and all, advice is requested
I am flying as follows:
DROIDWORX ADX-3 HEAVY LIFT AIR FRAME a Y-6
DJI-WKM, V5.03beta
6- AVROTO 2814-11S
6-HobbyWing FlyFun Brushless ESC 40A
6-GRAUPNER E-Prop 11x5
2-Turnigy 5000mah, 4S
Photohigher AV130
All up weight, without camera, is 9lb.
Basic parameters are 230, 230, 220, 140, 60, 60
Here's the scenario, while in ATTI. As long as manuevers are limited to mild hovering inputs the unit is stable, and predictable. As soon as any stick commands are given that induce roll, pitch, or altitude changes an uncontrollable YAW results, typically to the left. Given enough altitude, and returning the sticks to neutral positions, the MR will settle down, and will respond at that point to rudder commands. When it first starts Yawing action, it does not respond to rudder stick commands. Initially, it will not respond at all to rudder inputs.
Rockdw is offline Find More Posts by Rockdw
Discussion Ballistic Recovery System for Multirotors Duck! Aerial Photography 66 Nov 13, 2015 04:37 PM
Discussion DJI - WooKong eStab for Scale sidneyw Scale Helicopters 97 Dec 30, 2012 10:48 AM
Discussion FY3ZT Autopilot for Aerial Photography feiyudz Aerial Photography 116 May 07, 2012 04:58 PM
Discussion DJI AceOne autopilot for sale... hazchem88 Aerial Photography 4 Mar 31, 2011 03:54 AM
Discussion DJI Innovation helicopter autopilot XP.3.1 for European customers JoelT Aerial Photography 2 Sep 24, 2009 11:43 AM
