Old Sep 04, 2012, 11:06 AM
Panza is offline
Find More Posts by Panza
Panza's Avatar
France, Midi-Pyrénées, Toulouse
Joined Jun 2012
Jet, are you in traditional or sbus ?
Where you in ATTI ? (Motor loose stab don't works in manual mode)
Panza is offline Find More Posts by Panza
Old Sep 04, 2012, 11:20 AM
jetbootz is offline
Find More Posts by jetbootz
jetbootz's Avatar
Australia, Lord Howe Island
Joined Jan 2010
I am using futaba sbus. Also I was in gps mode. It was pretty scary , only that it happened at 3 m and over soft grass.... Only one single prop damaged. Could have been far worse.. Still I'm using 5.12a again and it seems ok... I would be interested to hear from any others who may have similar problems
jetbootz is offline Find More Posts by jetbootz
Old Sep 04, 2012, 11:33 AM
saabguyspg is offline
Find More Posts by saabguyspg
saabguyspg's Avatar
Calgary Canada
Joined Jun 2006
you can't expect a hexa to fly with one motor down... the fact that it landed is quite impressive on it's own... next time dont counter act the yaw too much becuase then you will lose lift... just let it spin down... and you will have more lift as it decends.
Steve
saabguyspg is offline Find More Posts by saabguyspg
Panza is offline
Panza's Avatar
Joined Jun 2012
What is DJI answer ? explanation ?
Old Sep 04, 2012, 02:02 PM
MCrites is offline
Find More Posts by MCrites
I never finish anyth
United States, TX, Houston
Joined Jan 2012
I just landed a F550 with one prop completely off... story in the Naza FC thread. I will post a video soon, it's being worked on right now. It wasn't easy but i did it in ATTI. I let it fall but in a controlled manner, a giant circular glide slope. From 100ft, nothing broken but the prop that came off never to be found again.
MCrites is offline Find More Posts by MCrites
Old Sep 04, 2012, 02:41 PM
saabguyspg's Avatar
Calgary Canada
Joined Jun 2006
you were not likely heavily loaded either and yes if you tried to counter act that spinning... it would have dropped an arm so you did well to let it spin...
steve
Old Sep 04, 2012, 02:54 PM
MCrites is offline
Joined Jan 2012
steve
5.25 lbs... I am running a 5000mah 4s battery, glassfiber landing gear with a homemade plexiglass mounting plate and way too heavy bolts for the application
Old Sep 04, 2012, 02:55 PM
MCrites is offline
Joined Jan 2012
Volume Warning:
DJI F550 Naza GPS - Lost a prop midflight (2 min 0 sec)
Old Sep 04, 2012, 03:34 PM
saabguyspg's Avatar
Calgary Canada
Joined Jun 2006
then I am impressed!
I am a fair bit heavier than that myself though... I doubt I would have fared as well as you
steve
Old Sep 04, 2012, 04:41 PM
Knilch is offline
Find More Posts by Knilch
Joined Nov 2011
Don't know why everyone is having problems with the voltage monitor. Mine works fine with all of my batteries, leaving enough time to land the machine.
What I found out is that the Zippy batteries I use have plenty more capacity then written on them. I don't recall what I have my warning levels at but they are pretty safe on the batteries and SHOULD lead to a battery usage of around 80%. When recharging though, the batteries constantly have less than 10% of charge left (i.e. the voltage stays above the warning level until they have used up more than 90% of their labeled capacity).
Knilch is offline Find More Posts by Knilch
Old Sep 04, 2012, 05:10 PM
Panza is offline
Panza's Avatar
Joined Jun 2012
recall please Knilch...
you should have the same meanings : when red flash -> autolanding
Old Sep 04, 2012, 05:23 PM
Knilch is offline
Joined Nov 2011
Sure but I never let it get to autoland but bring the bird down when blinking yellow (what means low voltage, time to end the flight).
Old Sep 04, 2012, 05:28 PM
Panza is offline
Panza's Avatar
Joined Jun 2012
You surely adjust voltage values in assistant, because on mine, yellow flash come before cell at 3,75 v
Old Sep 04, 2012, 05:32 PM
Knilch is offline
Joined Nov 2011
I did adjust them somewhere around 3,3V if I recall correctly. Don't know anymore, that is one of the few settings I have never messed with since I set them the first time .
What could lead to your yellow flashing is a collapsing voltage under load due to overstressed/overused or overaged batteries. I am flying two packs in parallel so there is some relief on that end, too.
Old Sep 04, 2012, 09:26 PM
Lovingflying is offline
Find More Posts by Lovingflying
Joined Jan 2012
I got a chance with great interest to call DJI today about the new firmware version 5.14a. It's a safe and valuable function, but I do hope it only works as a bodyguard not a terminator.
Actually, I am so stupid, 'cause I expected to have a try and get one of my motors stopped to simulate it.
They told me, it's only a protection function inside WKM.And the protection function only be triggered once one power output failed.
After talking with the technical support, I understand like this, WKM (5.14a) can still try to stablize the attitude once the emergency happens, but most of times, the aircraft will rotate around the frame arm without power output, and rotating and speed caused by payload and external environments.
Two ways to deal with it:
A. Lower your throtter slowly to land the aircraft upright.
B. You can use Course Lock and Home Lock modes of WKM to control aircraft to reach an acceptable landing place. You should have the course and home point recorded in advance.
They will make a video released soon. Waiting~~~~~~~~
And another important thing, the rudder is out of control and absobutely no use once the aircraft rotating, and now it only supports for V6 multi-rotor, can't work for Quad, work well for Octo.
Lovingflying is offline Find More Posts by Lovingflying
Site Sponsor
Discussion Ballistic Recovery System for Multirotors Duck! Aerial Photography 66 Nov 13, 2015 04:37 PM
Discussion DJI - WooKong eStab for Scale sidneyw Scale Helicopters 97 Dec 30, 2012 10:48 AM
Discussion FY3ZT Autopilot for Aerial Photography feiyudz Aerial Photography 116 May 07, 2012 04:58 PM
Discussion DJI AceOne autopilot for sale... hazchem88 Aerial Photography 4 Mar 31, 2011 03:54 AM
Discussion DJI Innovation helicopter autopilot XP.3.1 for European customers JoelT Aerial Photography 2 Sep 24, 2009 11:43 AM
