Old Aug 09, 2011, 08:20 PM
Go4it is online now
Find More Posts by Go4it
Go4it's Avatar
United States, FL
Joined Mar 2004
Question
Moki 30 hd vs mark g180
The Moki 30HD is a 30cc gas motor and the Mark/ Moki G180 is 30cc and a gas motor. One is front induction and the other is rear induction.
Mark Engines (Powered by Hungarian-Moki), made in Hungary, has provided only the best-quality miniature aircraft engines since 1957. Recognized the world-over for their high-performance and beautiful machining, Mark Engines has established themselves as a fine model engine maker.
My question is ; what would be the deciding factor of one motor over the other? The only thing I can see if you needed more nose weight you would go with the 30HD do to it weights 51oz vs 42oz. Both will turn a 20/8 or 10 prop. Both or good for 10,500 rpm @3.9hp.
Go4it is online now Find More Posts by Go4it
Old Aug 09, 2011, 10:10 PM
jjkupinski is offline
Find More Posts by jjkupinski
TigreJohn
United States, CA, Corona
Joined Aug 2008
I would be more prone to go with the 30HD over the G180 given identical performance specs. The G180 is a converted nitro engine and is a rotary valve induction with the carb mounted ahead of the cylinder. The 30HD was designed as a gas engine with a rear mounted carb. From the pictures, it appears to be a reed valve induction.
The deciding factor, in my own mind and excluding the weight factor would be the possible longevity of the engine is the case of an uncontrolled landing (crash is a dirty word). The possibility of damage to the crab and/or the carb mount appears to be more of a problem with the G180.
jjkupinski is offline Find More Posts by jjkupinski
Old Aug 10, 2011, 12:38 AM
Go4it is online now
Go4it's Avatar
United States, FL
Joined Mar 2004
The Mark G180 is made more like the EVO 35GT with the carb in front. You are correct a crash in the dirt would be a bad thing .
Poll GoPro HD vs. ContourHD Vapor Trails Atlanta Area RC 8 Jul 15, 2011 09:57 AM
For Sale Moki 1.8 engine NIB with accessories (Original Moki) $325.00 Gravyzrx Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jun 29, 2011 09:51 PM
For Sale New mark 180 2 stroke same as moki bipe22 Aircraft - Fuel - Engines and Accessories (FS/W) 0 Apr 01, 2011 12:44 PM
Discussion MARK [ MOKI ] engines PHILLCO Toledo Weak Signals RC Expo 0 Apr 09, 2006 08:00 PM
Wanted moki 2.10 or mark 2.10 qwazyone2 Aircraft - Fuel - Engines and Accessories (FS/W) 4 Feb 27, 2006 01:02 PM
